5Axis Kinetic from 2.8 on 2.7x
- Thank you received: 2176
26 Nov 2020 01:59 #190309
Replied by Aciera on topic 5Axis Kinetic de 2.8 en 2.7x
@JackRay
Please provide information about the breakout board and how it drives your spindle and your hal and ini
@Profed
I don't understand what you are trying to do. Please explain the situation in more detail.
@Profed
- Profed81
- Visitor
26 Nov 2020 02:54 #190312
by Profed81
Replied by Profed81 on topic 5Axis Kinetic de 2.8 en 2.7x
Can I edit xyzac-trt for the bridge type mill? The kinematics is the same? I would like to do switchkins, or else tcp at least
26 Nov 2020 03:10 - 26 Nov 2020 03:20 #190313
No that won't work. The kinematic has to reflect the axis setup of the machine. But there is a xyzac-trt kinematic in linuxcnc.
linuxcnc.org/docs/2.8/html/motion/5-axis-kinematics.html
If you have a xyzac-trt setup but with a gantry using two motors for the same axis say xyyzac then you will need to adjust the kinematics file and rebuild linuxcnc.
[edit]
This is for changing xyzbc to xyzzbc kinematic but it's the same (fairly straight forward) procedure:
forum.linuxcnc.org/10-advanced-configura...-kins-module?start=0
[edit]
Last edit: 26 Nov 2020 03:20 by Aciera.
- Profed81
- Visitor
26 Nov 2020 03:27 #190314
by Profed81
In which folder is this configuration for tilting spindle found?
- Profed81
- Visitor
26 Nov 2020 03:28 #190315
by Profed81
Build means, compile?
- Profed81
- Visitor
26 Nov 2020 04:48 #190317
by Profed81
"Trt" means, tilting table, I need to convert to tilting spindle (srt) Spindle rotating tilting
26 Nov 2020 08:30 #190319
Ah, I see, -trt won't work for a tilting head setup. As far as I know Bridgemill is the only kinematic where the spindle does both rotations.
So really in your case it's just that x and y axis are swapped compared to the "bridgemill" simulation?
- Profed81
- Visitor
26 Nov 2020 17:40 #190342
by Profed81
In this document it says that it is in the git tree, but what is "git tree?" is that on the internet? Or in some directory on my computer?
26 Nov 2020 19:33 - 26 Nov 2020 19:40 #190356
It seems to me that the XYZBC-SRT kinematics is what is used in the bridgemill simulation you posted. So that is already there. You seem to need a XYZAC-SRT kinematic which means that your spindle pivot is parallel to the X and Z axis while the bridgemill kinematics is made for a machine where the spindle pivots are parallel to the Y and Z axis. So I wonder if you couldn't just swap the X and Y axis of your machine in the INI and use the bridgemill kinematic in LinuxCNC.
Can you elaborate a bit where you are at with your project?
What does your machine look like?
Do you have LinuxCNC installed?
[edit]
Just checked, the bridgemill config uses a different code for its kinematic that seems to predate the one in your pdf document:
github.com/LinuxCNC/linuxcnc/blob/master...nematics/5axiskins.c
[edit]
Last edit: 26 Nov 2020 19:40 by Aciera.
- Profed81
- Visitor
26 Nov 2020 21:16 #190374
by Profed81
How should I load that kinematic?
Time to create page: 0.139 seconds
