Traub Bosch cc100 retrofit
11 Feb 2015 02:25 #55875 by andypugh
Replied by andypugh on topic Traub Bosch cc100 retrofit
There is any one that made a HASS vf3 from 93 whir DC motors with LNXcnc ?
Someone is doing a VF1.
www.linuxcnc.org/index.php/english/forum...t?limitstart=0#49111
  • aventtini
  • aventtini's Avatar Topic Author
  • Visitor
  • Visitor
14 Feb 2015 14:05 #55970 by aventtini
Replied by aventtini on topic Traub Bosch cc100 retrofit
10x for the info.
when i press Pause why i cant jog the machine ? Like mach3 ? i cant jog when paused in a job .
15 Feb 2015 03:57 #55978 by andypugh
Unfortunately jogging while paused isn't supported. Pause stops all motion.
Version 2.7 will have a "move-off" component that will at least allow you to move the tool out of the cut and back again, but a full jog-while-paused ability is some way off.
  • aventtini
  • Visitor
  • Visitor
16 Feb 2015 01:33 #55991 by aventtini
some times when you make some precision parts and you recenter on a hole you need to get the tool out . Or maybe retract only . Its a must !
16 Feb 2015 22:33 #56011 by andypugh
I am afraid that if you _have_ to have Jog-While-Paused then you won't be able to use LinuxCNC.
If you just need to retract then you should be able to use the "moveoff" component that is in version 2.7.
www.linuxcnc.org/docs/2.7/html/man/man9/moveoff.9.html
linuxcnc.org/docs/devel/html/config/moveoff.html
Alternatively you could consider using the Machinkit project, which is a fork of LinuxCNC
blog.machinekit.io/2014/11/jog-while-paused.html
  • aventtini
  • Visitor
  • Visitor
17 Feb 2015 04:17 #56026 by aventtini
10x for the info , Im not at that level now . Still learning on basics . Now some of 7i77 came and some axor minispeed drive that i want to retrofit the hardinge . Now its time damage something :D.
Andy do you know about Dave ? Something happened? He is ok ? Its unusual to not see him online for 3 weeks and not on the forum.
17 Feb 2015 04:28 #56028 by andypugh
cncbasher? He was online yesterday:
linuxcnc.org/index.php/english/my-profil...serprofile/cncbasher
  • aventtini
  • Visitor
  • Visitor
17 Feb 2015 05:40 #56037 by aventtini
yep . 10x
  • aventtini
  • Visitor
  • Visitor
18 Feb 2015 22:44 #56076 by aventtini
Andy i have tuned the motors exept D at the moment , The machine is 24000mm/ min problem is i have on the servo drives P so im a little confused
18 Feb 2015 23:03 #56077 by andypugh
I am confused too, as your description of what is confusing you was confusing :-)
Time to create page: 0.108 seconds
