Ethercat HAL driver
02 Apr 2018 01:49 - 03 Apr 2018 04:06 #108251 by Ilya
Replied by Ilya on topic Ethercat HAL driver
Hello all
I installed your driver using deb repo.modusoft.de/linuxcnc/wheezy ./
My problem is running the program using "loadrt lcec" in the hal file.
I getting that:
Error: could not insert module /usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/lcec.ko: Unknown symbol in module
I know little about this and I hope for Your help. Would you mind pointing me in the right direction?
ilya
__________________________________________
decided
I used a RTAi, whereas it was necessary to use RT-PREEMPT
Last edit: 03 Apr 2018 04:06 by Ilya.
14 Apr 2018 14:00 - 14 Apr 2018 14:09 #109007 by ChrisB
Replied by ChrisB on topic Ethercat HAL driver
Thank you for your help.
i cant figure out the problem.
Datatype complex makes more sens, but this is not the problem.
i have two scenarios.
the first one is, if i use configpdos = false
Then linuxcnc does not stars and the debuginfo says failed to set safeop. 0x0017 invalid sync manager configuration.
The other one is configpdos = true
then the drives gets an error F29 invalid ECAT command-value mapping length.
can you imagine what the problem is?
Tanks
Last edit: 14 Apr 2018 14:09 by ChrisB.
14 Apr 2018 22:52 #109050 by sirop
Replied by sirop on topic Ethercat HAL driver
Tanks
Hard to guess for me.
However, I noticed one inconsistent thing in your configs:
if
<Entry>
            <Index>#x606b</Index>
            <SubIndex>0</SubIndex>
            <BitLen>32</BitLen>
            <Name></Name>
            <DataType>UINT32</DataType>
          </Entry>
then its haltype should be "u32"?
That which is more questionable for me is:
SM1: PhysAddr 0x1c00, DefaultSize  512, ControlRegister 0x22, Enable 1
SM2: PhysAddr 0x1100, DefaultSize    0, ControlRegister 0x24, Enable 1
the default size of a non mailbox sync manger is 0.
Quick google search yields:
The buffered mode is typically used for cyclic data exchange, i.e. process data (PDO) since the buffered mode allows access to the communication buffer at any time for both sides [...]
It can be noted that SyncManagers running in buffered mode need three times the process data size allocated in the DPRAM (fig. A.5).
sir.upc.edu/wikis/roblab/index.php/Development/Ethercat
Is the EEPROM correct?
15 Apr 2018 07:32 - 15 Apr 2018 08:44 #109066 by ChrisB
i red this article sir.upc.edu/wikis/roblab/index.php/Development/Ethercat.
But now i don't know how to check the EEPROM
Last edit: 15 Apr 2018 08:44 by ChrisB.
15 Apr 2018 10:16 #109072 by sirop
I can not tell you more than :
A quick solution for the missing information is to generate the SII contents from the slave description XML file using Beckhoff's TwinCAT, and write them to the slave.
www.etherlab.org/en/ethercat/faq.php
16 Apr 2018 02:53 - 16 Apr 2018 03:06 #109113 by Automata27
Replied by Automata27 on topic Ethercat HAL driver dc synch issue solved...
Hi All,
First of all Thank you very much to Sascha Ittner for adding pll patch for linuxcnc in ethercat hal driver of lcec...
I have tried with linuxcnc-ethercat hal driver with pll patch applied to linuxcnc v2.7.11 branch and my dc issue is solved...
after applying pll patch to linuxcnc i had to use isolcpus in my boot command line, using isolcpus had solved the problem of dc synchronization...
i have attached my hal file and xml file for reference...
Any comment/ suggestion on attached file or result are most welcome...:):) :)
FYI...
linux ketnel is stretch rt-preempt:- Linux automata 4.9.0-3-rt-amd64 #1 SMP PREEMPT RT Debian 4.9.30-2+deb9u2 (2017-06-26) x86_64 GNU/Linux
linuxcnc :- linuxcnc v2.7.11
motors & Drives :- Panasonic minas- A6 400W(Ethercat) & panasonic Minas- A5 400W (Ethercat)
File Name: autocnc_20...4-16.ini
File Size:10 KB
File Name: axisPin_20...4-16.hal
File Size:8 KB
File Name: lcec_ecat_...4-16.hal
File Size:3 KB
File Name: lcnc_ecat_...4-16.xml
File Size:5 KB
File Name: motionPin_...4-16.hal
File Size:16 KB
Thank You,
Regards.
Last edit: 16 Apr 2018 03:06 by Automata27. Reason: attachments were not shown...
The following user(s) said Thank You: chimeno, serdigi
16 Apr 2018 03:08 - 16 Apr 2018 03:12 #109114 by Automata27
attached here is the video with 3 motors on linuxcnc v2.7.11 with pll patch applied...
3 axis with ethercat drives and motors on linuxcnc v2.7.11 with pll patch
velocity & pos plot without isolcpus
Last edit: 16 Apr 2018 03:12 by Automata27.
The following user(s) said Thank You: chimeno, Nico2017
16 Apr 2018 18:19 #109146 by sqmathlete
Replied by sqmathlete on topic Ethercat HAL driver dc synch issue solved...
@Automata27
Nice work! Are you planning on using the internal homing routine of the servo amps?
Dan
17 Apr 2018 01:08 #109170 by ChrisB
@Sirop
Thank you. Some weeks ago i updated the plugin Ethercatcard with the kollmorgen xml file. So i think it was the wrong file or kollmorgen has a wrong config in it. Now extracted a old configuration form another card and now it works for the first moment.
17 Apr 2018 08:48 #109184 by Automata27
Hi sqmathlete,
right now i am planning to use linuxcnc homing only with modification as per requirement because i am using absolute encoder motor...but i will definitely try servo amp homing too... :)
Regards.
Time to create page: 0.212 seconds
