  • Aciera
  • Aciera's Avatar
08 Jun 2025 15:06 - 08 Jun 2025 15:08
Replied by Aciera on topic G0 not zero? (more info)
A bit of a long shot, delete the .var and .var.bak files in your config and try again.
[edit]
Actually I'm not sure if ProbeBasic uses .var files at all.
  • PCW
  • PCW's Avatar
08 Jun 2025 14:55 - 09 Jun 2025 18:09
Replied by PCW on topic Mesa 7i92T - compiling firmware
Category: Driver Boards
I just built this config using the current 7i92t-hm2.zip source and made a new pinout filefor G540 on P2 and 7I76 on P1. The 7I76 works for me.
File Name: 7i92t_g540_7i76d.zip
File Size:284 KB
  • poesel
  • poesel
08 Jun 2025 14:55
Interface to LightBurn (is pylib a better choice).
@jtrantow - how's your project going? I'm interested, and maybe I can help you out?
08 Jun 2025 14:46
ESP32/S2/S3 LinuxCNC Controller (6 axis hardware step gen), USB plug-and-play
This is with 10.10.10.10 IP address.
You have to compile the component again.
  • Lcvette
  • Lcvette's Avatar
08 Jun 2025 14:18
Replied by Lcvette on topic Cant del Offset table and save
Category: QtPyVCP
is your machine 5 axis using xyzac?
  • poesel
  • poesel
08 Jun 2025 14:11
Replied by poesel on topic connecting to laser TTL
Category: Plasma & Laser
Yes, this is correct, well done!
This what I added to my .hal:
# invert pwm output
setp hm2_7i96s.0.pwmgen.01.out0.invert_output true
# set output type to PWM
setp hm2_7i96s.0.pwmgen.01.output-type 1 # pwm
# set scale
setp hm2_7i96s.0.pwmgen.01.scale 100 # 100%
# test - this will enable the output and should give about 1,25V
# setp hm2_7i96s.0.pwmgen.01.value 25 # pwm
setp hm2_7i96s.0.pwmgen.01.enable true
# Link PWM output to analog-out 0
net laser-power motion.analog-out-00 => hm2_7i96s.0.pwmgen.01.value
If you comment in the pwm line (and comment out 'net laser...' you permanently get 1,25V on the output.
You can also leave it as is, run lcnc and run 'M68 E0 Q25' for the same effect. 'M68 E0 Q0' to turn it off again.
Where I'm not so sure is that the output is permanently enabled and only controlled by M67/M68. I'm going to use Lightburn which uses these M-commands instead of the spindle control. Is that ok?
  • jhandel
  • jhandel
08 Jun 2025 13:58
IO Questions around mixing IO between Ethercat and Pi 5?
Category: EtherCAT
that EasyCAT is an interesting bit of kit...
  • Grotius
  • Grotius's Avatar
08 Jun 2025 13:52
HAL CiA402 Drive Interface for Can Bus,Ethercat etc...
Category: HAL
Others may bring it in the main stream.
I am against one off the github policys.
Therefore i stay at Codeberg wich dont use the policy i hate.
  • Kittifix
  • Kittifix
08 Jun 2025 13:32 - 08 Jun 2025 22:15
Cant del Offset table and save was created by Kittifix
Category: QtPyVCP
after probing Edge Angle the R is set and now i want  remove for a new Operation
in the Tab Offsets i can clear all or clear selected or one - save and i get this Errors
File Name: Offset_tab...rror.txt
File Size:3 KB
  • bassti
  • bassti
08 Jun 2025 12:50
Replied by bassti on topic reference during rotorhoming
Yes, I know how to set the homing order, the question is whether I can stop during the homing sequence, i.e. after z has been homed and then the rotorhoming of the b axis can be fixed and then the remaining axes can be referenced
  • Edi_48
  • Edi_48
08 Jun 2025 12:39
24 Volt Ausgänge? was created by Edi_48
24 Volt Ausgänge?
Category: Deutsch
Hallo ich habe eine Neue Mesa 7i96s und habe Probleme mit meine 24 VoltRelay und Schaltkontakten Spindel PneumatikFrage wie kann ich die an 7i96s Anschließen ?
mfg
Hilton
  • Hakan
  • Hakan
08 Jun 2025 12:12
Category: HAL
Sounds great!
What are your plans with this?
Keep it separate in your code or bring it into mainstream linuxcnc code?
  • SwitchWitch
  • SwitchWitch
08 Jun 2025 11:58 - 08 Jun 2025 11:59
Replied by SwitchWitch on topic xml and hal - I am lost
Category: EtherCAT
As promised - here is a little update.
Now evrything is running or better starting. The Beckhoff modules do what they should do, 2 oft the servos can be jogged but 1 servo is not able to be jogged and when trying to an amplifier error ist displayed in a pop up display. The motors are not yet tuned as they are no yet mounted to the machine.
I can`t really understand the difference of behaviour as all of the 3 servos are out of the box without any change to the values.
The only thing inside lcnc wich is possibly related to it is the ferror value - nothing else.
What could be a good starting point to figure out what goes wrong?
- If helpful for anybody I could post my setup files
  • partec
  • partec
08 Jun 2025 11:42
Replied by partec on topic cam_align
cam_align
Category: Qtvcp
Please excuse me, I didn't think about that at all, of course I'm happy to do it that way and thank you very much always
  • TheTinkeringMechanic1
08 Jun 2025 11:39
Replied by TheTinkeringMechanic1 on topic CNC lathe to grinder.
Category: Basic Configuration
I knew it had to be something simple I was overlooking. I'll give this a try. Thanks for the explanation.
Displaying 15286 - 15300 out of 15472 results.
Time to create page: 1.654 seconds
