  • Becksvill
  • Becksvill
16 Aug 2026 02:58
Replied by Becksvill on topic Conversational CAD CAM
Category: O Codes (subroutines) and NGCGUI
yep no stress. hopefully as time goes on people will test this and use it. just would be a waste if it never got used. But i have 7 cnc machines myself that are getting the conversational stuff and a general upgrade of linuxcnc. and it's worth the time just for me so not too fussed if no one else uses this. machines are getting pretty cool now. with all the auto tool measure stuff it all makes a massive difference how fast jobs get done. and auto tool measuring means that i don't get the chance to make mistakes with tool offsets and they always stay loaded so i don't do any hacks. cause the fastest option is clicking measure and walking away to carry on programming on cam
cheers
  • Becksvill
  • Becksvill
16 Aug 2026 02:54
Planning to Retrofit a Mazak Integrex200Y Mill-Turn Machine
man this looks just like my place in NZ you get the machine bug and it bites hard aye lol. and then its more and more machines until its hard to stop
  • emresensoy
  • emresensoy
16 Aug 2026 02:48
Replied by emresensoy on topic DIY Robot Kinematic parameters,
First of all, thank you very much for your interest and support. The diagram you sent already formed my starting point. However, since there is a 90-degree difference between the slider joint and the next joint, I wanted to redo the calculations.
Also, since Genserkins only supports rotary axes, I will not be using it. I will recreate the kinematics according to my system.
  • Aciera
  • Aciera's Avatar
16 Aug 2026 02:35
Replied by Aciera on topic DIY Robot Kinematic parameters,
Is the DH parameters below right?
Those won't work. First indication is the simple fact that you are mixing distances and angles. Also note that genserkins uses 'modified DH' parameters not the standard 'DH' parameters.
I already posted the parameters for your robot that should work for your robot, why don't you start by trying those?
  • karlhe
  • karlhe
16 Aug 2026 00:24 - 16 Aug 2026 03:24
Replied by karlhe on topic radiusendpunkt nicht gefunden
Moin,
ich bin der Meinung, dass es nichts mit linuxcnc zu tun hat, sondern mit
fusion 360..?
Karlhe
Ich habe das Programm in fusion 360 mit dem Prozessor von estlcam rechnen lassen. der fährt die kontur ohne radius, dass hat
funktioniert. Der Postprozesseor von linuxcnc sollte beim abfahren von Konturen vielleicht doch noch überarbeitet werden.
  • viewsat
  • viewsat
15 Aug 2026 20:25 - 16 Aug 2026 07:20
The Linux CNC FPGA control board I bought connects to the motor driver, and it works perfectly with the 74HC245.
There is no problem connecting the DM542 using the 74HC245.
The FPGA (3.3V) is directly connected to the 74HC245 (5V).
  • dm17ry
  • dm17ry's Avatar
15 Aug 2026 16:00
Replied by dm17ry on topic Okuma encoders and drives
it's the data received by the controller from drives
  • emresensoy
  • emresensoy
15 Aug 2026 14:33
  • stefan63
  • stefan63's Avatar
15 Aug 2026 13:14
PureCutCNC was created by stefan63
PureCutCNC
Category: CAD CAM
Any LinuxCNC users that have an opinion of PureCutCNC?
I'm not involved but it look kind if nice.
purecutcnc.github.io/
15 Aug 2026 13:12
Replied by tommylight on topic can't issue MDI command when not homed
Press the "home all" button, then issue MDI.
  • mediocre_chloride
  • mediocre_chloride's Avatar
15 Aug 2026 13:01
Replied by mediocre_chloride on topic radiusendpunkt nicht gefunden
Tut mir Leid für die Falsche Fährte.
Ich habe das Problem nicht reproduzieren können in meinen Testconfigs. dürfte ich deine INI sehen um die zu vergleichen?
mfg
  • GFC
  • GFC
15 Aug 2026 11:33
Integrating ethercat with QTplasmaC and Beckhoff modules
Category: Plasmac
managed to fix this by completely rebuilding the config, no idea what was causing it
  • karlhe
  • karlhe
15 Aug 2026 11:00 - 15 Aug 2026 11:17
File Name: zinken-kuze-seite.ngc
File Size:5 KB
File Size:5 KB
Danke, ich füge das nc programm hinzu.
ich habe das programm mit nc viewer laufen lassen, keine Fehler
Karlhe
  • PCW
  • PCW's Avatar
15 Aug 2026 10:17
If this is a drive level issue, note that a 26C31 does not swing to 5V
and its output level is about 2 diode drops below 5V (3.6V) with a 5 mA load.
I connected the motor driver using +5V and A-.
Yes, connected that way you would get close to 5V drive.
The issue with the 26C31 is that the high level drive does not swing to 5V
but the low level drive does swing close to 0V.
  • MaHa
  • MaHa
15 Aug 2026 10:01
Replied by MaHa on topic radiusendpunkt nicht gefunden
G91.1 ist eigentlich standard für I,J,k , ausgehend vom Kreismittelpunkt. Diese parameter werden ässerst selten als absolutwert angewendet.
Das Problem mit Fusion360 und Kreisendpunktfehler taucht seit langer Zeit immer wieder auf. Vielleicht ist da was mit Nachkommastellen, 3 für metrisch und sonst 4
Einige Ideen bringt auch die websuche:
fusion360 linuxcnc end of arc differ
Displaying 1816 - 1830 out of 11355 results.
Time to create page: 0.349 seconds
