  • unknown
  • unknown
05 Mar 2025 14:21
Replied by unknown on topic Ethernet Settings for Raspi4
Category: Installing LinuxCNC
The issue is that interface is setup for both dhcp and a static address.
I'd do a write up about how to setup an interface but for 2 reasons, it would get lost and ignored, and this kind of thing has been discussed far too many times to recall.
I think people have lost the art of being able to search.
  • Sternfox
  • Sternfox
05 Mar 2025 14:07 - 07 Mar 2025 20:03
Advanced Lube pump timing and memory for oil mist spindles
Hi Guys,
I have written a script for all of you that use oil mist spindles.
This py script will time the on and off usage of your spindle and activate the lube pump for a specific amount of time. Then when you close down linuxcnc, a JSON file will be updated with the exact time that has elapsed. making sure you do not over lube your spindle. It will remember how long you last ran your spindle and only start the pump once the allotted lube cycle time has elapsed.
This has been developed for use with a HAAS mill using the Bijur Lubrication system.
I hope it helps someone.
File Name: lube.py
File Size:3 KB
Hal components needed
loadrt oneshot count=1
#central lubrication
loadusr -W /home/cnc/linuxcnc/configs/haas_probebasic/lube.py
net lube-run lube.run => hm2_7i95.0.ssr.00.out-02 # your output for the lube pump
net spindle-cw   lube.spindle_status <=
.PY is attached but i will paste it here with some explanations
#!/usr/bin/env python3
import linuxcnc, hal, time, os, json
# File to store cycle state
STATE_FILE = "/home/cnc/linuxcnc/configs/haas_probebasic/lube_pump_state.json"  #location of the json file that will automatically be generated
# Initialize HAL component
lube = hal.component("lube")
lube.newpin("run", hal.HAL_BIT, hal.HAL_OUT)
lube.newpin("delay", hal.HAL_BIT, hal.HAL_OUT)
lube.newpin("spindle_status", hal.HAL_BIT, hal.HAL_IN)
lube.newpin("reset", hal.HAL_BIT, hal.HAL_IN)
lube.ready()
# Pump timing settings
PUMP_RUN_DURATION = 10  # Seconds HOW LONG THE PUMP WILL RUN
REST_DURATION = 1800  # 30 minutes (in seconds) HOW LONG THE PUMP CYCLE TIME
# Initialize variables
pump_running = False
resting = False
elapsed_rest_time = 0
remaining_rest_time = REST_DURATION
start_time = None
# Load previous state if exists
if os.path.exists(STATE_FILE):
    try:
        with open(STATE_FILE, "r") as f:
            state = json.load(f)
            elapsed_rest_time = state.get("elapsed_rest_time", 0)
            resting = state.get("resting", False)
            # Ensure remaining rest time continues exactly where it left off
            remaining_rest_time = max(0, REST_DURATION - elapsed_rest_time)
            if resting:
                print(f"Machine restarted. Pump remains in rest mode for {remaining_rest_time:.2f} seconds.")
            else:
                remaining_rest_time = REST_DURATION  # Reset if not previously resting
    except Exception as e:
        print(f"Error loading state: {e}")
print("Lube system initialized.")
try:
    while True:
        time.sleep(0.1)  # Reduce CPU usage
        # Check spindle status
        if lube["spindle_status"]:
            if not pump_running and not resting:
                pump_running = True
                lube["run"] = 1
                start_time = time.time()
                print("Pump running.")
            # Stop pump after run duration
            if pump_running and (time.time() - start_time >= PUMP_RUN_DURATION):
                resting = True
                lube["run"] = 0
                lube["delay"] = 1  # Indicate pump resting
                print("Pump resting.")
        # Handle rest period
        if resting:
                elapsed_rest_time += time.time() - start_time
                if elapsed_rest_time >= REST_DURATION:
                    resting = False
                    lube["delay"] = 0  # Rest complete
                    print("Rest complete. Pump ready to run again.")
            else:
                start_time = time.time()  # Pause timer if spindle stops
        # Save state periodically
        with open(STATE_FILE, "w") as f:
            json.dump(
                    "elapsed_rest_time": elapsed_rest_time,
                    "resting": resting,
                f,
        # Handle reset signal
        if lube["reset"]:
            print("Reset signal received.")
            resting = False
            lube["reset"] = 0  # Reset the reset signal
except KeyboardInterrupt:
    print("Shutting down lube system.")
    lube["run"] = 0
    raise SystemExit
  • Sternfox
  • Sternfox
05 Mar 2025 13:52
Replied by Sternfox on topic Spindle orientation
Spindle orientation
Thanks for the reply, I managed to get it to work with just two hal commands, my spindle and driver have inputs and outputs for doing this without using the encoder through linuxcnc.
  • Beovoxo
  • Beovoxo
05 Mar 2025 13:28
2 Encoders per axis ? was created by Beovoxo
Category: EtherCAT
Hi all, I have some questions and would like to hear your opinion on retrofit. The retrofit is  on a older Deckel FP4A “another thread”.
Glass scale encoder vs just motor encoder??.
Is it ok to just have the motor encoder for a system regarding backlash in the system ? ??
Leadshine EL8 or Delta drives with 2 encoder inputs ??Any out there running 2 encoders pr axis ? via EtherCat ?Have a nice day all.
  • COFHAL
  • COFHAL
05 Mar 2025 13:26
  • andypugh
  • andypugh's Avatar
05 Mar 2025 13:10
Replied by andypugh on topic TAMAGAWA encoders model TS5661N132
Maybe you could send one to Mesa for testing?
05 Mar 2025 13:10
Replied by tommylight on topic Ethernet Settings for Raspi4
What does
ip a
in a terminal return?
  • Hakan
  • Hakan
05 Mar 2025 13:06 - 05 Mar 2025 13:32
Replied by Hakan on topic Fusion 360 post processor file for Plamac
Category: Plasmac
Could be something with the smoothing tolerance even if it is tighter than the overall tolerance.
I use MergeCircles ON so it may not be so important.
05 Mar 2025 13:03
Replied by tommylight on topic Hurricane Milton
Hurricane Milton
Keep us updated, if possible, and take care.
  • meister
  • meister
05 Mar 2025 12:56
  • Nathan40
  • Nathan40
05 Mar 2025 12:42
Ethernet Settings for Raspi4 was created by Nathan40
Hi All,
I am unable to connect 7i95t on raspi4 with the below settings. Ping is not sending any data. Please suggest as what I am doing wrong!
# Ethernet
allow-hotplug eth0
iface eth0 inet dhcp
        address 10.10.10.1
        netmask 255.0.0.0
        gateway 10.10.10.1
        dns-nameservers 8.8.8.8 8.8.4.4
  • gwond
  • gwond
05 Mar 2025 12:40
Replied by gwond on topic Fusion 360 post processor file for Plamac
Category: Plasmac
I just ran it with smoothing off and it processed the hole as a centerpunch. So it seems smoothing should be OFF and MergeCircles also OFF. Would still be curious as to where the tolerance values should be set. Thanks for the help!
  • Pipik
  • Pipik
05 Mar 2025 12:37
Replied by Pipik on topic Mesa 7i96 mixed voltage field input wiring
Category: Driver Boards
PCW, how do you solved that inputs can source and sink (depends on one comm pin voltage/ground) and also can source/sink 5-36V range? I am definitely not master electronic engineer like you, but need to solve a simmilar issue. Some schematic?
Thank you.
  • gwond
  • gwond
05 Mar 2025 12:33
Category: Plasmac
That's quite interesting, but also odd. I have the tolerance set to 0.0004 in, which may have just been the default.  If I raise this above 0.021 should it join the circle?  I also have smoothing checked, which may be another thing to try removing.
  • rodw
  • rodw's Avatar
05 Mar 2025 12:21
New ethercat / probe basic control for minimonster
Category: CNC Machines
git clone puts the folder with the same name as the repository in the folder you run the command in. have a look in the file explorer
I tend to create a new folder ~/devel and put all my cloned repos in it. I used to use ~/dev under my home folder but it is easy to get mixed up with the system folder as you found out
Displaying 18196 - 18210 out of 18601 results.
Time to create page: 0.397 seconds
