  • Aciera
  • Aciera's Avatar
05 Feb 2025 16:20
Replied by Aciera on topic lcec config exited without becoming ready
Category: EtherCAT
Change quotes around D3 (note the different appearance when you try to open the attached XML):
  • Aciera
  • Aciera's Avatar
05 Feb 2025 16:13
Replied by Aciera on topic G33.1 synchronized tapping problem
Could you post your hal files (IE the one that uses caxis.comp and the one with the orient.comp)?
  • Millimetergott
  • Millimetergott
05 Feb 2025 16:13
Replied by Millimetergott on topic lcec config exited without becoming ready
Category: EtherCAT
I made a new xml with only the beckhoff EK1100. Now i get a new error
  • PCW
  • PCW's Avatar
05 Feb 2025 16:07 - 05 Feb 2025 16:15
Stuck with spindle interface 7i76 card and weird BLDC driver
Another way to fix that is to chose the output polarity of the PWM
so its 0V at startup or watchdog bite (the STEP- pin) and then invert
the PWM in the hal file.
Its still a good idea to disable the spindle when LinuxCNC is not running
If the enable is an optocoupler input, a single resistor (R1)  will do
If its a 5V logic input, you need R2.
Safest would be to implement both (0 PWM at startup which is just a
wiring and hal change) and drive enable.
  • meister
  • meister
05 Feb 2025 15:53
i got my 32 relay card today and changed something in the setup, i will test everything again later.
you can now use func:6 and set the datatype (new option) to bool, as register the 112 (0x70) and Values = 16
            "config": {
                "relais": {
                    "address": 11,
                    "type": 6,
                    "register": 112,
                    "values": 16,
                    "datatype": "bool",
                    "scale": 1.0,
                    "unit": "",
                    "error_values": "",
                    "format": "",
                    "timeout": 100,
                    "delay": 60,
                    "direction": "output"
  • unknown
  • unknown
05 Feb 2025 15:33
Replied by unknown on topic is 40V enough for DM556?
Soldering Iron or Wood Burner temps will melt skin. Had a friend when I was 9 or 10 who picked up his mum's Wood Burner Iron. Old Greg was a built different to everyone else. Pretty sure when he was working on a trawler he just pulled the tuna in with his bare hands, bet he would of tried to bite the heads off a few as well.
  • unknown
  • unknown
05 Feb 2025 15:28
PNCConf, Mesa 7I96S: "You are using a simulated-realtime version of LinuxCNC..."
Category: PnCConf Wizard
Actually I've just had another thought, what version of RPi imager are you using and what particular OS ?
I'm not a windows user and some people have had issues with RPi imager ?
Do you uncompress the downloaded file or just point RPi imager to the compressed file ?
Cheers
Rob
  • unknown
  • unknown
05 Feb 2025 15:24
The images are not Raspbian based, so any pre imaging before writing to SD card will not work. This is mentioned in the sticky regarding the RPI images:
forum.linuxcnc.org/9-installing-linuxcnc...the-rpasberry-pi-4-5
Yeah I haven't really been happy with the way locales are setup. I would really like to come up with a solid solution and add that to the sticky mentioned above.
Regarding wireless:
wiki.debian.org/WiFi/HowToUse#Using_ifupdown_and_wireless-tools
I'm thinking network-manager and gnome network tools would make setting up networks somewhat easier.
  • Aciera
  • Aciera's Avatar
05 Feb 2025 15:24
Issue with Access - "pin is not writable" Error when using setp
Category: EtherCAT
You need to connect the relevant signals in your .hal file as in the example linked in the post above.
And where is the PLC of the machine written?
Not sure which PLC or which machine you are referring to.
  • Aciera
  • Aciera's Avatar
05 Feb 2025 15:13
Replied by Aciera on topic Semi-realtime hal component
Category: HAL
Are these positional updates coming in during execution of a gcode program or while an individual MDI command is being executed?
There has been a short discussion about a similar project recently:
forum.linuxcnc.org/38-general-linuxcnc-q...robot-control#319033
  • meister
  • meister
05 Feb 2025 15:05
Replied by meister on topic Semi-realtime hal component
Category: HAL
you can take a look at this (non-realtime) component,
there i use sliders in python(qt5) to move my robot-joints.
it can also change the target position while moving, like you need.
github.com/multigcs/riocore/blob/main/ri...s/robojog/robojog.py
the script is not big and you already have an insight or you can use it as a basis, throw out qt and simply replace the inputs with ZeroMQ
  • behai
  • behai
05 Feb 2025 14:59
I guess you didn't use the sysfs patch, this is required for Linuxcnc to recogonise that the environment is a real time one.
Easiest option will be to download the latest RPi4 image on the downloads page, has a 6.12.11 kernel (with the required sys_fs patch), Linuxcnc version 2.9.4. Might pay to backup your home directory.
As usual
user: cnc
pwd: cnc
linuxcnc.org/iso/rpi-4-debian-bookworm-6...25-01-27-0404.img.xz
linuxcnc.org/iso/rpi-4-debian-bookworm-6...7-0404.img.xz.sha256
Hi unknown,
Thank you for your suggestion. I have burnt that image, and I am able to ping my 7i96s on 10.10.10.10.
1. I am not able to go very far with PNCConf -- I have locale problem, using menu-config, I have set my default locale to en AU.UTF_8, still no go. There are existing posts on this problem, I will try it again.
2. This image does not come with WIFI preconfigured. I am using the Pi Imager to burnt it, and WIFI setting did not take effect.
Thank you and best regards,
....behai.
05 Feb 2025 14:48
Replied by tommylight on topic is 40V enough for DM556?
Should I connect one transformer lead to ground (the plug is 3-prong, the chassis is grounded steel)?
NO!
Connect ground only to box/chasis and to shielded cables.
Amps should be enough, move on.
Transformers can handle a lot of abuse, small overloads are no problem at all. After you power everything and have it running for 10-15 minutes, do check if it is heating from time to time, and even if it gets hot after and hour or two of work, as long as you can keep your palm on it, it is OK.
Human hand will have issues above 50 degree C, at 80 it burns like hell, and you will always know if the temp has gotten over 100 as your skin will remain attached to whatever you are touching, and fingers will turn shiny! :)
  • unknown
  • unknown
05 Feb 2025 14:34
Replied by unknown on topic LinuxCNC on Raspberry Pi 5
Category: Installing LinuxCNC
I'll have to leave this to Rod & others. It's not something I could really test other than the installation bit.
  • Martin.L
  • Martin.L
05 Feb 2025 14:07
Replied by Martin.L on topic Rack Tool Changer
Rack Tool Changer
Category: QtPyVCP
Nice! If you need someone to play with it I'm here
Displaying 19381 - 19395 out of 19546 results.
Time to create page: 0.375 seconds
