  • PCW
  • PCW's Avatar
04 Feb 2025 21:58
Replied by PCW on topic How to use Rcservos as axis motor.
Category: Basic Configuration
The motion should follow the PWM value and that should follow the absolute position.
if homing is disabled, I would expect the starting position (and therefore PWM value)
to always be the same.
Not sure of the resolution of the Remora PWMgen, it's tough to do PC servo PWM
in software because the entire range of motion is controlled  by a 1 ms PWM width change
(so say a 50 KHz base thread would result in only 50 discrete positions)
  • PCW
  • PCW's Avatar
04 Feb 2025 21:46
Replied by PCW on topic systematic drift on arcs
One guess is noise/crosstalk on the step/dir interface, especially if
the drives have a input capable of accepting high speed step signals.
  • Yaroslav
  • Yaroslav
04 Feb 2025 21:34
Replied by Yaroslav on topic Macros. File not open
Category: Gmoccapy
I tried both options. Version 2.9.4 is out. I'll try it and see if anything has changed.
  • bellda101
  • bellda101
04 Feb 2025 21:29
Replied by bellda101 on topic MecSoft Post processors.
Category: MecSoft
I have RhinoCam do you know a post processer that will work with Linux CNC machines. I have A PrintNC 3 axis router. I have been using the Practical CNC post processor I have to add S0 M5 M30 at the end of the code to get it to work but it doesn't work all the time. When it doesn't work, I have to close Linux CNC and restart it then it will work. I don't understand why it dose that.
DB
  • my1987toyota
  • my1987toyota's Avatar
04 Feb 2025 21:24
Replied by my1987toyota on topic Voron Life , for anyone going into 3D printing !
Category: Additive Manufacturing
I think I will put a pin in that route for a "try later" when the machine is dialed in and running properly.
I have seen some of the influencers comment on it, as a not for the novice crowd. It's a shame MESA
doesn't make a 3D printer controller board. But I guess that would also mandate a major add-on to
LinuxCNC. Oh well hope springs eternal.
  • royka
  • royka
04 Feb 2025 21:21 - 04 Feb 2025 23:39
Replied by royka on topic LinuxCNC on Raspberry Pi 5
Category: Installing LinuxCNC
@unknown Nope until now it's only at the master branch, when I see time I'll do a pull request for the 2.9 branch. You could possibly build from the 2.9 branch and apply the following patch with: git apply ../linuxcnc-rt-detect-6.12.patch
forum.linuxcnc.org/media/kunena/attachme...rt-detect-6.12.patch
Or just put "LINUXCNC_FORCE_REALTIME=1" in front of the LinuxCNC command of set it as a permanent environment setting
  • ihavenofish
  • ihavenofish
04 Feb 2025 21:11
Replied by ihavenofish on topic New ethercat / probe basic control for minimonster
Category: CNC Machines
Homing I am just gonna do the normal switch plus index for now. So 3 inputs out of my 24.
Other inputs I need are:
- Probe
- Laser tool setter
- Spindle clamp sensor
- Hard limits are either 3 or 6 switches but I will leave those off for now.
Not sure how you handle an MPG with this.
For outputs I have:
- solenoid for tool release
- solenoid for M7 mql
I will be using probe basic I think for this, i will need to figure out the rs485 for the spindle. It looks like I can read back the torque, and alarms, which is nice. My biggest issue on the old setup is the control is blind to errors and when the spindle or an axis stalls it just keeps on keeping on. Gotta get that all tied up.
  • jjdege
  • jjdege's Avatar
04 Feb 2025 21:01
Replied by jjdege on topic Rack Tool Changer
Rack Tool Changer
Category: QtPyVCP
Hi, sorry, do you mean something like this ?
  • COFHAL
  • COFHAL
04 Feb 2025 20:34
Replied by COFHAL on topic TURRET TOE100
TURRET TOE100
Category: Turning
This browser does not support PDFs. Please download the PDF to view it: Download PDF
  • Meichinger
  • Meichinger
04 Feb 2025 20:23
systematic drift on arcs was created by Meichinger
Hi Linux CNC forum,
I'm building on a small CNC for over two years now. Unfortunately, I've been running in some issues while milling circular pockets.
machine specs:
Traj XYZA
y-axis 1190 mm max travel, 20 mm ballscrew with 10 mm pitch, two 750W AC servo (HLTNC)
x-axis 900 mm max travel, 20 mm ballscrew with 10 mm pitch, one 750W AC servo (HLTNC)
z-axis 185 mm max travel, 16 mm ballscrew with 5 mm pitch, high torque nema 34 stepper
spindle - 2,2 kw rattmotor air cooled
Brain of the operation: raspberry pi 4b+ using a parallel port hat and a 5 axis breakout board
I'm running the premanufactured PI4 optimized Debian Bookworm image.
Y-axis settings as follows:
max_velocity = 5000 mm/min
max_acc  = 20000 mm/min2
min limit = 0 mm
max limit = 1190 mm
stepgen_maxaccel = 40000
scale = 10 steps/mm -> (not sure why i set this to 10 -> 200 steps/rev and 10 mm pitch shall result in 20 steps/mm)
FERROR = 1
Min_Ferror = 0.25
The issue:
See attachment for further details
arcs/circular shapes are for any reason shifted in XY - direction, the error occurs above 250 mm/min and is almost unchanged between 1000-5000 mm/min.
What did i test up to now:
  1. Change base_period up and down -> the servos are set to 200 "steps"/rev, 10 mm pitch -> thus 20 steps/mm resulting in below 2000 pulses per second on one axis. Base_period is set to 100k, shall be fine? Changing the base_period to 40k didn't change anything as well as increasing the base period to 150k.
  2. Change max_acc to 4x max_velocity and stepgen to 2x max_acc -> didn't change anything
  3. check mechanical stiffness and backlash -> everything feels tight and rock solid, the linear guide rails are 20x30mm using very massiv long carriers.
  4. kill all unnecessary PIDs on the debain system in order to reduce latency -> didn't change anything
added the .hal and .ini file as attachments.
Any hint or recommendation on how to improve this would be appreciated!
Thank you!
Michael
  • COFHAL
  • COFHAL
04 Feb 2025 20:22
Replied by COFHAL on topic AX58100
AX58100
Category: EtherCAT
I haven't had time to use halscope, I'll look at your recommendation for modifying the firmware.
  • TangentAudio
  • TangentAudio
04 Feb 2025 20:22 - 04 Feb 2025 20:22
Configure a non-motorized axis with a linear scale (DRO mode) - Solved
I made a surgical modification to the AXIS GUI to optionally modify the behavior of an axis to use the ACTUAL_POSITION value as part of the offset value sent to the G10 L20 command during a workpiece touch-off.  This is only done if TOUCHOFF_ACTUAL = TRUE is set in the appropriate [AXIS_x] section in your .INI file.
This may not be the most general approach and may yet prove to have some bugs (e.g. i have not tested metric mode yet), but it works for my situation right now anyway.
I'm not sure if this is worthy of creating a PR to include in LinuxCNC, but for anyone who might want to see the change you can view the diff here:
github.com/tangentaudio/linuxcnc/compare...025%7D?diff=split&w=
cheers,
Steve
  • rodw
  • rodw's Avatar
04 Feb 2025 20:20
Issue with Access - "pin is not writable" Error when using setp
Category: EtherCAT
You need to share more about what you want to achieve. Sounds like you are going about things the wrong way...
cia402.comp is an interface between Linuxcnc joints and the ethercat cia402 servo drive.
  • COFHAL
  • COFHAL
04 Feb 2025 20:15
TURRET TOE100
Category: Turning
I attach the configuration files to handle the turret. The only difference with yours is that the one I have did not have the encoder and I had to design one, but without the use of parity pins, you can add it by modifying the turret.hal file. My turret only has a 6-position tool changer while yours has 12, that's not a problem, what I did was design my encoder to only detect 6 positions and only use 3 sense pins to get a maximum of 8 combinations, with your encoder you can do all 12, adding another sense pin to the turret.hal file. As I explained in this thread, the turret originally works bidirectionally, but I could not get it to work that way because the carrousel component does not allow it. In this thread they also discuss this type of turret forum.linuxcnc.org/10-advanced-configura...ute-encoder?start=30. I have to search my notes because I found in another thread someone who designed a component for a turret that works the same as the one we have, but is manufactured by another company. This component does allow the turret to work in a bidirectional manner.
File Name: Lathemate.hal
File Size:8 KB
File Name: Lathemate.ini
File Size:3 KB
File Name: Torreta_20...2-04.hal
File Size:3 KB
  • rodw
  • rodw's Avatar
04 Feb 2025 20:05
Program exceeds machine maximum X and Y Axis
CandCNC ?
I was to polite to say anything but a lot of users have bought a THCAD and converted to QTplasmac.
Displaying 19471 - 19485 out of 19548 results.
Time to create page: 0.360 seconds
