  • Hakan
  • Hakan
27 Mar 2026 08:15
Review Request for Arc Volt Sensor Schematic
Category: Plasma & Laser
I also wonder about the 2 50k resistors.
Good find on the regulated TMR-0511.
I looked at the output of the isolated power supply I use. I wasn't terrible, almost ok but not totally stable.
Why the filter step? HF?
  • Hakan
  • Hakan
27 Mar 2026 07:28
Replied by Hakan on topic Ethercat Setup help needed for beginner
Category: EtherCAT
Basically what you do is replace the motion part of the sim config with the ethercat motion.
Here is an example I often refer to. You do need the cia402 component as well.
github.com/dbraun1981/hal-cia402/tree/main/example
  • Yannis
  • Yannis
27 Mar 2026 07:07
Replied by Yannis on topic W axis machine config
The signals looks ok
Also on the WATCH tablet the virtual led for e-stop and machine enable are working fine
  • MiMaMoadlo
  • MiMaMoadlo
27 Mar 2026 06:58
Stepperonline A6 400W Servo RS485 Step/Dir (ohne EtherCAT)
Category: Deutsch
ja, der the stepperonline support hat mich noch auf diesen Artikel hingewiesen:
Why Does the Motor Not Rotate After I Connect My Pulse Controller to the A6 Driver? | Help Center
Mein Fehler war, dass ich den S-On Pin mit GND und nicht mit COM- beim Testen verbunden hatte, jetzt funktioniert es!
  • ts
  • ts
27 Mar 2026 06:38
Replied by ts on topic Flex GUI Keyboard Jogging
Category: Flex GUI
This is works cool
And is there option for toggle between continues and limited (0.01 0.1 1) movements? I mean for example if keyboard jog is active, and i push 1 on keyboard, jog speed switch to 0.01, if i push 2 on the keyboard, then jog speed switch to 0.1 etc
  • ts
  • ts
27 Mar 2026 06:17
Ext hard buttons duplicate Power_PB and Reset
Category: Flex GUI
Additional :
I tryed to add halui to have functionality of power on button and reset with external hard button, but somewhy there is an errors duing start of halui. May be flexgui didnt let halui to start?
  • AntonioT
  • AntonioT
27 Mar 2026 06:12
THC not getting active even when "all seemingly needed" requirements are met
Category: Plasmac
ok, found this to try those 2 seconds maybe:
Two methods of THC activation are available and are selected with the Auto Activation check-button. Both methods begin their calculations when the current velocity of the torch matches the cut feed rate specified for the selected material:
Delay Activation (the default) is selected when Auto Activation is unchecked. This method uses a time delay set with the Delay parameter.
Auto Activation is selected when Auto Activation is checked. This method determines that the arc voltage is stable by using the Sample Counts and Sample Threshold parameters.
  • Nathan40
  • Nathan40
27 Mar 2026 03:10
Replied by Nathan40 on topic Qtplasmac- adding .py files as user buttons
I am trying to generate a pop up window telling if the nozzle needs change depending on the distance traveled.
26 Mar 2026 23:47
Replied by tommylight on topic FreeCAD 1.0 Who's using it?
Category: CAD CAM
  • jschulze
  • jschulze
26 Mar 2026 23:13 - 27 Mar 2026 03:37
Pico Systems Servo Controller was created by jschulze
Category: User Exchange
Had these sitting around and figured someone might be able to put them to use.  Pico Systems servo controller with 2 servo amps and braking resistor modules.  Also includes a spindle dac.  Had this running a 2 axis lathe that I ended up having to scrap.  $150 shipped in the US.
  • my1987toyota
  • my1987toyota's Avatar
26 Mar 2026 21:54
Replied by my1987toyota on topic FreeCAD 1.0 Who's using it?
Category: CAD CAM
  • mooser
  • mooser
26 Mar 2026 21:32
Leave enabled pin active when leaving linuxcnc
Category: Basic Configuration
And that's why it keeps turning off the 220v going to the vfd when I close linuxcnc to pickup the new settings I'm working on in the HAL and ini. For me it's a lot of brute-force and ignorance working in there sometimes and trial & error to get things working. (And a whole lot of help from you guys, thank goodness)
I'll hot-wire the SSR to keep the vfd from having to reboot every few minutes until I get this somewhat sorted out. I think I've at least figured out what's causing my gear function, that'll be the next series of questions lol
Thanks again
M
  • Robert312
  • Robert312
26 Mar 2026 21:09 - 26 Mar 2026 21:10
Servo tuning was created by Robert312
Servo tuning
Servo Tuning advice needed!
Attached are the oscilloscope reading from our 4 axis mill, we are using mesaboards to retrofit a bostomatic machine. Any tips on tuning the servo parameters would be great.  The readings are all from the X axis we had it doing 2 inch movements at the same velocity. If anyone has pointers on PID values based on the readings that would be so helpful.  Also all the other values are 0 unless otherwise written in the slide.
  • susan-parker
  • susan-parker
26 Mar 2026 20:58
30 Second timeout before opening and E-Stop button not clicking...
Category: QtPyVCP
Probe in Sim works okay... now comparing the various files.
Thanks for the suggestion.
Displaying 3691 - 3705 out of 14010 results.
Time to create page: 0.302 seconds
