  • emcPT
  • emcPT's Avatar
07 Mar 2025 08:22
Finally 7i76EU! was created by emcPT
Finally 7i76EU!
Category: User Exchange
On transit to EuSurplus (limited quantities):
7i76EU
7i76U
7i84U
we now have a reasonable stock on most of the common boards.
  • UrKibin
  • UrKibin
07 Mar 2025 07:20
CINCINATTI MILACRON ARROW 500 (BDS4 + VFS5) WITH MESA 7i77 + 6i25 WITH LINUXCNC
Category: Milling Machines
Good day. Newbie here. Would just like to crowdsource and steer us to the right direction with regards to retrofitting a milacron arrow with BDS4 axis servo controllers and VFS5 spindle servo controllers.
Any inputs and directions will be greatly appreciated.
  • ErwinCNC
  • ErwinCNC
07 Mar 2025 06:58
Replied by ErwinCNC on topic 7i96s Watchdog Ethernet
Category: Deutsch
Guten Morgen Peter,
da hatte ich eine 0 vergessen.
Hier die Resultate für eine längere Zeit:
cnc@cnc:~$ sudo chrt 99 ping -i .001 -c 60000 -q 10.10.10.10
[sudo] Passwort für cnc:
PING 10.10.10.10 (10.10.10.10) 56(84) bytes of data
--- 10.10.10.10 ping statistics ---
60000 packets transmitted, 60000 received, 0% packet loss, time 60000ms
rtt min/avg/max/mdev = 0.065/0.078/0.178/0.007 ms
Mein PC hat folgende Netzwerkkarte:
cnc@cnc:~$ lspci | grep -i eth
00:19.0 Ethernet controller: Intel Corporation 82579LM Gigabit Network Connection (Lewisville) (rev 05)
Ich habe die Latenz mehrfach mit verschiedenen Grub Parametern gemessen. Hierfür habe ich folgendes Skript verwendet:
forum.linuxcnc.org/18-computer/39371-res...or-use-with-linuxcnc
Mit der aktuellen Konfiguration erhalte ich folgende Resultate:
Using default parameters:
Result: running as user: cnc,
runtime: 7200 seconds,
parameters: --nobase, ,
prefix for outfiles 1741329147
nglx: 5,
LinuxCNC pc tests, version 20200930, started 07.03.2025 07:32:29
Hardware info is logged here: 1741329147.hw.
Latency data is logged here: 1741329147.lat.
General info:
LENOVO,  7033W6G
Bios version 9HKT58AUS, dated 06/10/2014
Chipset: Intel Corporation 6 Series/C200 Series
Harddisk is non-rotational, ie. SSD
The amount of swap currently used is 0
CPU related data:
model name    : Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
cpu cores    : 4
stepping    : 7
cache size    : 6144 KB
RAM related data:
Maximum Capacity: 32 GB
Size: No Module Installed
GPU related data:
product: 2nd Generation Core Processor Family Integrated Graphics Controller
configuration: depth=32 driver=i915 latency=0 resolution=1920,1080
Parallel port related data:
number of parallel ports is 0
Os and desktop related data:
PRETTY_NAME="Debian GNU/Linux 12 (bookworm)"
Should the info below not match with your machine,
kindly post the output of pstree here, including a brief
desciption of your desktop environment, window manager and
display manager. Tia
forum.linuxcnc.org/18-computer/39370-scr...-of-computer-latency
Desktop environment : lightdm
Windowmanager       : Xfwm4
Displaymanager      : lightdm
Kernel related data:
Kernel 6.1.0-31-rt-amd64
GRUB_CMDLINE_LINUX_DEFAULT="quiet console=tty0 console=ttyS0,115200 skew_tick=1 rcu_nocb_poll rcu_nocbs=1-95 nohz=on nohz_full=1-95 kthread_cpus=0,1 irqaffinity=0,1 isolcpus=2,3 intel_pstate=disable nosoftlockup tsc=nowatchdog intel_idle.max_cstate=1 i915.enable_rc6=0"
Cpu idle driver: intel_idle
Kernel modules data:
Check if pcspkr is loaded: Yes, may cause bigger latency.
  can be eliminated using:
  sudo echo "install pcspkr /bin/true" >/etc/modprobe.d/pcspkr.conf
Check if snd modules are loaded: Yes, may cause bigger latency.
  can probably be disabled in bios, alternatively, you can run
   "./block-snd-modules"
   which has just now been created for your convenience.
Keyboard & Mouse related data:
Number of mice: 1
Mouse 0 : Logitech USB Optical Mouse
Mice  attached to USB:
Logitech, Inc. RX1000 Laser Mouse
Keyboards attached to USB:
IBM Corp. NetVista Full Width Keyboard
LinuxCNC related data:
LinuxCNC version is: 2.9.4
Preparing for latency test:
Started glxgears No. 1, 2, 3, 4, 5
 Remaining 0d 0h:0m:0s, press ^C to abort...
7200 s  servo min: -45.600 us max:  49.200 us sdev:   1.000 us
 7201 s  servo min: -45.600 us max:  49.200 us sdev:   1.000 us
 7202 s  servo min: -45.600 us max:  49.200 us sdev:   1.000 us
 7203 s  servo min: -45.600 us max:  49.200 us sdev:   1.000 us
 7204 s  servo min: -45.600 us max:  49.200 us sdev:   1.000 us
Core 0:        +60.0°C  (high = +80.0°C, crit = +99.0°C)
Core 1:        +58.0°C  (high = +80.0°C, crit = +99.0°C)
Core 2:        +63.0°C  (high = +80.0°C, crit = +99.0°C)
Core 3:        +59.0°C  (high = +80.0°C, crit = +99.0°C)
Cleaning up
terminated latency-test ...
Mit anderen Grub Parametern habe ich etwa 27 000us erhalten. Aktuell teste ich verschiedene Einstellungen und Parameter.
Im Beitrag zum Skript sind viele ähnliche Latenzwerte dokumentiert - so schlecht sollte die Maschine also nicht sein?
Muss ich irgendwo noch Werte eintragen? Testweise habe ich im pncconf am Anfang meine Werte + 30% eingetragen.
@tommylight schreibt dazu hier im Forum auf die Frage eines anderen Nutzers das muss nicht gemacht werden?
forum.linuxcnc.org/18-computer/39371-res...h-linuxcnc?start=230
seuchato wrote:
I'd set the value in LinuxCNC to 120 -130% of the obtained latency data ..
That is valid for base period when using parallel port. Mesa boards do not use base period at all, and the servo period should be left at default 1000000 ( 1 mill ).
Vielen Dank
Grüße Erwin
07 Mar 2025 04:45
Replied by tommylight on topic LinuxCNC coreXY homing question
Working config attached
  • ihavenofish
  • ihavenofish
07 Mar 2025 03:32
Replied by ihavenofish on topic New ethercat / probe basic control for minimonster
Category: CNC Machines
problem is i have no idea what i need haha.
i do have an xml for the drive but looking inside of it, i guess that's unrelated here.
I made a twincat project just to see, and the drives are telling me i have a data type length mismatch or something. So thats not helping me any haha.
sigh. were in the "i dont even know what questions to ask" part of the project.
  • snowgoer540
  • snowgoer540's Avatar
07 Mar 2025 03:26
Temporary materials was not loaded in a timely manner
Category: Plasmac
See if this helps
162.243.45.186/plasmac/36568-post-proces...mac?start=110#212283
Ok just checked and not much there, so
How are you loading the file and from what?
If from network or USB, try copying to HDD and load from there.
This link didn’t work earlier, this is why I remembered this.
Thanks Tommy.
  • snowgoer540
07 Mar 2025 03:18
Category: Plasmac
What is causing this error when I load my Gcode file.
I vaguely remember this, and I’m pretty sure we changed the behavior around this. I will double check tomorrow.
The other warning is because you have feed rates set by the material selection, as well as hard coded in the file.
I’m curious what version you’re actually running? It’s listed in the window title bar.
  • cmorley
  • cmorley
07 Mar 2025 03:02
Replied by cmorley on topic Qtvcp Development Discussions
Category: Qtvcp
Yes we are interested in potential screen alternatives. We don't you post some pics.
Master is fine for digging out the hidden bugs assuming the major functions work.
I have a 'best/preferred practice' page for GUIs I should add it to master.
How are you testing now? Are you installing the files in the config folder?
  • Nathan40
  • Nathan40
07 Mar 2025 02:57
Replied by Nathan40 on topic Ethernet Settings for Raspi4
Category: Installing LinuxCNC
Thanks PCW for your help! Cheers.
  • rodw
  • rodw's Avatar
07 Mar 2025 02:56
Awesome!
Start with the cia402 example and only add stuff from the manual you need
github.com/dbraun1981/hal-cia402
Should be easy,
  • Sziggy_NC
  • Sziggy_NC
07 Mar 2025 02:55
Replied by Sziggy_NC on topic Calling pockets with carousel
Category: Basic Configuration
That would explain my issue. I thought it was odd when I read the M-code explanation of M68. I was calling it without ever setting it...  I now see that section in the toolchangers for dummies video.
I will try "net car-pos-req motion.analog-out-00 => conv-float-s32.0.in"
And "net car-pos-s32 conv-float-s32.0.out => carousel.0.pocket-number"
Thank you for saving me Andy!
  • ihavenofish
  • ihavenofish
07 Mar 2025 02:47
Replied by ihavenofish on topic Problems with Lichuan Ethercat servo drive
Category: EtherCAT
I just tuned my omron ethercat servos. I fear manual tuning on these lichuans, haha. How are you doing it, just scoping it in twincat or linuxcnc? or do they have an app?
  • ihavenofish
  • ihavenofish
07 Mar 2025 02:43
Alright, I lied, I haven't given up yet :P
I went and tuned the X and Y. not perfect, but tracks within a couple microns and overshoots only 4-10 microns during 1G acceleration. Also only deviates 2-3 microns when I yank on the spindle with all my weight while moving.
If i can get the linuxcnc part going this thing is gonna rip :)
  • cmorley
  • cmorley
07 Mar 2025 02:38
Replied by cmorley on topic Custom Panel
Custom Panel
Category: AXIS
To use your modified version, put the .ui file in:
YOUR CONFIGURATION FOLDER/qtvcp/screens/qtaxis/
use the name qtaxis.ui
Qtvcp should load your modified .ui file.
  • Philip Lydin
  • Philip Lydin
07 Mar 2025 01:44
Custom mcodes was created by Philip Lydin
Custom mcodes
Category: O Codes (subroutines) and NGCGUI
Hello im currenttly working on a latthe rettrofit. The tailstock on the machine works by movving the z axis so it is aligned with the tailstock then a pin gets hydraullically pressed into the tailstock so when you now move the z axis it brings along the tailstock so you can move it to the desired position. Does anybody have a idea how i can make this. I tried to use a m100-199. But then i saw you canttt use subroutines. Otherwise ittt would be perfect since you can use its related parameters to set where you want to place the tailstock. Is it possible to use parameters with unallocatted mcode. So you could maybe do like a m20p200?
Displaying 18151 - 18165 out of 18523 results.
Time to create page: 1.262 seconds
