  • tftmarco0
  • tftmarco0's Avatar
16 Feb 2025 10:37
Tried every net solution for days to install linuxcnc
Category: Installing LinuxCNC
Once the live versions were working, I did try a lot of sudo commands in the terminal. Some seemed to work, others said the file could not be found I believe. All things the OS is suppose to include and are required. After all the sudos the system still would not boot to the installed hard drive internal or external USB.
  • tftmarco0
16 Feb 2025 10:19
Great suggestions and thanks to all. I am feeling more hopeful already. Since a picture is worth a thousand words, I took some photos of my system, bios options, setting and what I get after a successful installation that can’t be found. I have dedicated this computer to just be a linuxcnc system, so the main hard drive and USB drive were reformatted with FAT before partitioning for a clean start. I used rufus-4.6_x86.exe to prepare a USB boot stick and USB drive with the respective ISOs that worked well for the live but not for installs.
My system.
My bios startup menu.
My UEFI boot options.
My bios boot order.
My bios secure boot configuration options.
And My device not found after a “successful” installation.
  • Hakan
  • Hakan
16 Feb 2025 10:16
THC with Beckhoff EL5101 and THCAD2 => encoder signal loss
Category: Plasmac
If the pulse length method works for you it is even better. 100 ns resolution between two rising edges gives 0.1 Hz resolution and seems to be updated every cycle.
  • Aciera
  • Aciera's Avatar
16 Feb 2025 10:12
Replied by Aciera on topic Mesa 7I76-5I25 control cards
Category: User Exchange
Might want to clarify the type of cards you are offering here.
  • Aciera
  • Aciera's Avatar
16 Feb 2025 10:09
Replied by Aciera on topic DynexHobby impulse 2 for sale
Giving this a bump so it does not show up in the 'No Replies' section.
  • Hakan
  • Hakan
16 Feb 2025 10:09 - 16 Feb 2025 10:10
Replied by Hakan on topic Fusion 360 post processor file for Plamac
Category: Plasmac
I have used the Fusion 360 QtPlasmaC postprocessor from here forum.linuxcnc.org/plasmac/38438-plasmac...ssors?start=0#162574 and overall it works good.
But for centerpunches (see the doc in the link) there is the error "M3 command before moves", which is that immediately before the M3 torch on line there are lines with only coordinates, they have to include also the G0 or G1 text. Fusion 360 normally takes them away as needed to save three bytes(?).
And the M3 command didn't switch on the torch but instead a marker device/laser cross.
Also a feed F99999 was commented out.
These are the changes needed from line 504 or so.
          var arcI = arcCenterX - circleData.center.x;
          var arcJ = arcCenterY - circleData.center.y;
          if (centerPunch) {
            writeBlock(String("G0 "), xOutput.format(circleData.center.x), yOutput.format(circleData.center.y)); //move to start of entry arc - center of the hole
          } else {
            writeBlock(gMotionModal.format(0), xOutput.format(circleData.center.x), yOutput.format(circleData.center.y)); //move to start of entry arc - center of the hole
          if (centerPunch) {
            writeComment("CENTER PUNCH THE HOLE ONLY");
            //writeBlock(feedOutput.format(99999));
            writeBlock(mFormat.format(3), $Format.format(0), sFormat.format(1)); //start the torch
            writeBlock(gFormat.format(91));
            writeBlock(gFormat.format(1), xOutput.format(0.00001));
            writeBlock(gFormat.format(90));
  • Aciera
  • Aciera's Avatar
16 Feb 2025 10:08 - 16 Feb 2025 10:08
Replied by Aciera on topic Kinematics for nutating table rotary
Category: Show Your Stuff
Just giving this a bump so it doesn't show up in the 'No Replies' section.
  • Aciera
  • Aciera's Avatar
16 Feb 2025 10:07
  • Aciera
  • Aciera's Avatar
16 Feb 2025 10:02
Replied by Aciera on topic help with guidance spindle
Translation
I set the orientation of the spindle with m19, it worked well, but I have a problem that as much as I put the same degree every time, it finds different positions of the spindle, for example I give m19r0 it finds a point and stops, but I do the same command again and it does not find the same point it goes to another point and stops, that is it keeps changing the degree 0 of place, sometimes it does it several times in the same place, out of nowhere it goes to another point and if I do it a few more times it stays there. At that point, out of the blue it changes the point again, can you help?
Translated with DeepL.com (free version)
[/code]
  • rodw
  • rodw's Avatar
16 Feb 2025 10:01
Replied by rodw on topic MESA 7i96S and Input config
Category: Basic Configuration
It does not really matter. Each pin has a matching pin ending in -not that is always the inverse of the main pin.
so you can choose which pin you use to set the default position to be on or off.
  • Aciera
  • Aciera's Avatar
16 Feb 2025 10:00
Using A axis as second spindle with stepper motor
There have been a few threads about switching a rotary axis to spindle mode and back. Currently there is no standard solution that fits all scenarios.
This might give you an entry point:
forum.linuxcnc.org/26-turning/55148-lath...g-and-milling#319940
  • Aciera
  • Aciera's Avatar
16 Feb 2025 09:55
Replied by Aciera on topic Multi use FPGA Project
Thanks for sharing.
  • Aciera
  • Aciera's Avatar
16 Feb 2025 09:53
Replied by Aciera on topic Probe Basic Lathe
Probe Basic Lathe
Category: QtPyVCP
please post your config folder (compress and attach)
Displaying 19006 - 19020 out of 19205 results.
Time to create page: 0.451 seconds
