  • ok
  • ok
05 Feb 2025 17:44
Mesa 7C80, RPi4, 20cm ribbon cable and SPI speeds
Category: Driver Boards
using the prepared OS image "rpi-4-debian-bookworm-6.12.11-arm64-ext4-2025-01-27-0404.img.xz" from linuxcnc.org on a Pi4/4GB, I have no luck talking to my 7c80 board, which is connected with a 20cm ribbon cable to my RPi:
$ mesaflash --spi --device 7c80 --addr /dev/spidev0.0 --readhmid
Unexpected cookie at 0100..0110:
00000000 00000000 00000000
No 7C80 board found
This is both for the system-wide installed mesaflash as well as a separate build straight from github sources as of today.
I am (now) aware that cable length might be an issue here as SPI runs at a swift 20 MHz.
If possible (as replacing the cable with a much shorter one would involve quite a bit of mechanical disassembly and rework of my controller box) I would like to try the SPI connection first at slower speeds.
Is it possible to test (maybe bitbang even?) the SPI connection to the 7C80 FPGA to test whether the whole setup is working in principle? If so, are there any major problems expected then running everything with a reduced data rate (I am only planning to drive two steppers with this setup, so hopefully not a lot of bandwidth is needed)?
Can the FPGA be accessed slowly or are there timeouts preventing this?
I brazenly tried to reduce the SPI speed in spi_boards.c down to various rates, down to 100kHz, but that didn't help.
  • beauxnez
  • beauxnez
05 Feb 2025 17:31 - 05 Feb 2025 17:34
1. Convert an ST-Link to a CMSIS-DAP probe by using a a second ST-Link and the ST-Link utility to flash the CMSIS-DAP firmware.
mvdlande.wordpress.com/2015/10/05/cmsis-...ink-v2-mini-adapter/
2. Use pyOCD with the newly flashed CMSIS-DAP probe to flash the firmware to the controller board
python -m pip install -U pyocd
pyocd flash .\remora-rt1052-3.1.3.bin --target mimxrt1050_quadspi
github.com/scottalford75/Remora-RT1052-c...ora-rt1052-3.1.3.bin
Hello, I'm coming back to the charge on my RT 1052 card, I'm trying to flash with the CMSIS-DAP firmware but I have an error message the card is not detected?
  • Tobi_tree
  • Tobi_tree's Avatar
05 Feb 2025 17:01
Replied by Tobi_tree on topic Newbe trying to run 7i92TM
Category: PnCConf Wizard
Today i reran the PnCConf and the Startup Error didn't show.
But the WLAN Problem still persists.
  • Tobi_tree
05 Feb 2025 16:58
I am running Debian on my Thinkpad T420
The mesa is connected to the Ethernet port and when I connect to WLAN the connection to the MESA Card fails, it happens both with 10.10.10.10 and with 192.168.1.121.
Network:
IP 192.169.1.10 Mask: 255.0.0.0 Gate: 0.0.0.0
IP 10.10.10.11 Mask: 255.0.0.0 Gate: 0.0.0.0
  • PCW
  • PCW's Avatar
05 Feb 2025 16:35
Homemade CNC Plasma - hypertherm, Mesa, gear drives, nema 34.
Category: Show Your Stuff
Yes, I had the Ohmic sensing into the B encoder input on TB2.
That's OK with 7i96dpl.bit firmware (that has three separate encoder 'A' pins)
  • Aciera
  • Aciera's Avatar
05 Feb 2025 16:20
Replied by Aciera on topic lcec config exited without becoming ready
Category: EtherCAT
Change quotes around D3 (note the different appearance when you try to open the attached XML):
  • Aciera
  • Aciera's Avatar
05 Feb 2025 16:13
Replied by Aciera on topic G33.1 synchronized tapping problem
Could you post your hal files (IE the one that uses caxis.comp and the one with the orient.comp)?
  • Millimetergott
  • Millimetergott
05 Feb 2025 16:13
Replied by Millimetergott on topic lcec config exited without becoming ready
Category: EtherCAT
I made a new xml with only the beckhoff EK1100. Now i get a new error
  • PCW
  • PCW's Avatar
05 Feb 2025 16:07 - 05 Feb 2025 16:15
Stuck with spindle interface 7i76 card and weird BLDC driver
Another way to fix that is to chose the output polarity of the PWM
so its 0V at startup or watchdog bite (the STEP- pin) and then invert
the PWM in the hal file.
Its still a good idea to disable the spindle when LinuxCNC is not running
If the enable is an optocoupler input, a single resistor (R1)  will do
If its a 5V logic input, you need R2.
Safest would be to implement both (0 PWM at startup which is just a
wiring and hal change) and drive enable.
  • meister
  • meister
05 Feb 2025 15:53
i got my 32 relay card today and changed something in the setup, i will test everything again later.
you can now use func:6 and set the datatype (new option) to bool, as register the 112 (0x70) and Values = 16
            "config": {
                "relais": {
                    "address": 11,
                    "type": 6,
                    "register": 112,
                    "values": 16,
                    "datatype": "bool",
                    "scale": 1.0,
                    "unit": "",
                    "error_values": "",
                    "format": "",
                    "timeout": 100,
                    "delay": 60,
                    "direction": "output"
  • unknown
  • unknown
05 Feb 2025 15:33
Replied by unknown on topic is 40V enough for DM556?
Soldering Iron or Wood Burner temps will melt skin. Had a friend when I was 9 or 10 who picked up his mum's Wood Burner Iron. Old Greg was a built different to everyone else. Pretty sure when he was working on a trawler he just pulled the tuna in with his bare hands, bet he would of tried to bite the heads off a few as well.
  • unknown
  • unknown
05 Feb 2025 15:28
PNCConf, Mesa 7I96S: "You are using a simulated-realtime version of LinuxCNC..."
Actually I've just had another thought, what version of RPi imager are you using and what particular OS ?
I'm not a windows user and some people have had issues with RPi imager ?
Do you uncompress the downloaded file or just point RPi imager to the compressed file ?
Cheers
Rob
  • unknown
  • unknown
05 Feb 2025 15:24
The images are not Raspbian based, so any pre imaging before writing to SD card will not work. This is mentioned in the sticky regarding the RPI images:
forum.linuxcnc.org/9-installing-linuxcnc...the-rpasberry-pi-4-5
Yeah I haven't really been happy with the way locales are setup. I would really like to come up with a solid solution and add that to the sticky mentioned above.
Regarding wireless:
wiki.debian.org/WiFi/HowToUse#Using_ifupdown_and_wireless-tools
I'm thinking network-manager and gnome network tools would make setting up networks somewhat easier.
  • Aciera
  • Aciera's Avatar
05 Feb 2025 15:24
Issue with Access - "pin is not writable" Error when using setp
Category: EtherCAT
You need to connect the relevant signals in your .hal file as in the example linked in the post above.
And where is the PLC of the machine written?
Not sure which PLC or which machine you are referring to.
  • Aciera
  • Aciera's Avatar
05 Feb 2025 15:13
Replied by Aciera on topic Semi-realtime hal component
Category: HAL
Are these positional updates coming in during execution of a gcode program or while an individual MDI command is being executed?
There has been a short discussion about a similar project recently:
forum.linuxcnc.org/38-general-linuxcnc-q...robot-control#319033
Displaying 19381 - 19395 out of 19542 results.
Time to create page: 1.052 seconds
