  • PCW
  • PCW's Avatar
13 Jun 2024 18:06
Replied by PCW on topic Mesa 7i95T PID tuning for velocity mode
If the drive has a step/dir position mode, that is what you use
(you don't need a velocity mode even for a spindle)
  • greg23_78
  • greg23_78
13 Jun 2024 16:59
Binary encoder - Sauter SK-501 turret - Strobe diagram of functions
after reading the hal file, i have a few questions.
why use a gray encoder when your code table encoder is binary?
you activate the solenoid when the selected tool is in activate position whereas the schematics show that the solenoid activates at the last falling edge before the selected tool. is it too complicated to program this? or is your solution sufficient?
you only have one direction of rotation, is it too complicated to use mux to manage reverse directions of rotation to block the turret?
  • greg23_78
  • greg23_78
13 Jun 2024 16:24
Replied by greg23_78 on topic Installing Mesa CT
Installing Mesa CT
Category: Driver Boards
i reinstall linuxcnc with a fresh file and all is good now, thx you
  • denhen89
  • denhen89's Avatar
13 Jun 2024 16:23 - 13 Jun 2024 16:27
New day, new problem - Home switch Z axis gets ignored?
Its working like that, not sure why its setup that way, but its working perfectly. (edit: i believe its because its a NO switch?)
I also have found the fault - broken wires (sensor was okay). Fixed it now and its working again.
  • RMJ fabrication
  • RMJ fabrication
13 Jun 2024 16:18 - 13 Jun 2024 16:44
Replied by RMJ fabrication on topic Fusion 360 post processor file for Plamac
Category: Plasmac
I installed the fusion360 post processor from here forum.linuxcnc.org/plasmac/38438-plasmac-post-processors#159042 and I am unable to get it to produce valid gcode successfully. I am trying to cut out a simple 10" sign and this is the error message I get every time I try to load the gcode into qtplasmac. I also cannot see the part on the screen. Attached is my post process window, can someone please guide me on how to proceed correctly making gcode files with fusion360 thanks!
  • tjtr33
  • tjtr33's Avatar
13 Jun 2024 15:23
Renora - SPI was created by tjtr33
Renora - SPI
hello, I do not see SPI in the existing Remora - Ethernet topic , so I start thgis one.
I have a Mks-Sbase V1.3 and ask where does the wire labeled 'px.x' go?
(refer to remora-docs.readthedocs.io/en/latest/har...e/SPI/Mks-Sbase.html  figure 1 )
It comes from rpi gpio 25
thx  tjtr33
  • vibram
  • vibram
13 Jun 2024 15:19
7i73 seems to be correctly installed but not working
Sorry for late reply. I gave the information on discord but not here.
Was all my fault since the beginning ;(
I will try to explain in English but it's not my native language.
I did not correctly understood the pin number allocation. So I assume the first row was 1 to 20 and the second one 21 to 40.
Hence all my tests were wrong and I'm very lucky to not damaged the board.
I read the documentation several times and with a printscreen from another forum member whom is helping me a lot, I understood one row was for odd and one row was for even numbers.
Rookie mistake and waste of time for several users. Sorry for that.
Now everything is working
Thank you
13 Jun 2024 15:07
Replied by tommylight on topic Help me setting up My LinuxCNC
Category: Basic Configuration
CD4017 CMOS IC ? :)
Scaling should work, and see if there is a shift register component as that might also work, but scaling should be much easier.
  • cakeslob
  • cakeslob
13 Jun 2024 14:54
Replied by cakeslob on topic Help me setting up My LinuxCNC
its fine, but the following error is me, but lets ask these guys if they know how we can do this.
we have a float output from a remora quadratic counting encoder module, and we want to use it for an MPG. we have converted the float to s32, but the encoder is counting quadratic
What hal logic components can we use to make the count.....not quadratic? so it counts 4 pulses for every one click of the MPG and we want 1 click, how can we use hal to make it work?
  • PCW
  • PCW's Avatar
13 Jun 2024 14:41
I checked in HALmeter and it shows that the switch is FALSE when active (same as the X and Y aixs) and TRUE when NOT-Active.
That seems wrong, The home switch should be active (yellow in halshow)  when activated.
Sounds like you need to invert the inputs
  • denhen89
  • denhen89's Avatar
13 Jun 2024 14:39
EDIT;
I was wrong, the proximity switch seems to be broken.
I will install a new switch and then it should work.
  • denhen89
  • denhen89's Avatar
13 Jun 2024 14:30
Hello guys,
another day on my CNC router starts with a problem, coming out of nowhere, but this time i will try to make it as short as possible, but after 4 hours of trying to fix it, i am already a bit confused.
So, my cnc router has this home sequence:
1. Z Axis
2. X and Y-tandem together
Usually, when my Z axis was at the uppest position, the proximity switch was already active so the Z axis was waiting until the other axis has been homed, but now when the Z axis is already in the HOME-Position, it drives into the other direction (into the table) trying to find the switch, but why? It was already on the Home switch.
When the Z axis is not in the Home position and the proximity switch is not active, it drives up and the switch gets ignored and drives into the physical end of the axis. I checked in HALmeter and it shows that the switch is FALSE when active (same as the X and Y aixs) and TRUE when NOT-Active.
I tested it with a new Proximity switch, even if HALmeter showed that the original one is working, but same behaviour.
I have tried a couple of things like changing the direction, even i thought this makes no sense because the homing sequnce was always working since the beginning and i compared the INI with one from 5 years ago and everything is same.
I just dont get it.
The last changes i did was when trying to set up the A axis, but i have a seperate settings-folder. (i tried to run that config, but the homing problem is same)
I have attached my INI and my HAL.
Hope you can help me out again.
  • Masiwood123
  • Masiwood123's Avatar
13 Jun 2024 14:23
Replied by Masiwood123 on topic 7i96s +7i83 trough 7i44 is it possible?
thanks, then I will buy a 7i77 and I solved the problem with cards:)
  • Masiwood123
13 Jun 2024 14:20
thank you, I made a mistake, I have 7i74 instead of what I wrote 7i44
  • Anton
  • Anton
13 Jun 2024 14:18 - 17 Jun 2024 05:59
Replied by Anton on topic error finishing read!
Thank you for your efforts and the quick reply.
I will test it tomorrow.
I have also just ordered a network card:
Intel Gigabit CT Desktop Adapter 893647 Network Card EXPI9301CT
Perhaps this will work better than the onboard network card.
VG Anton
Displaying 25666 - 25680 out of 26040 results.
Time to create page: 0.610 seconds
