  • greg23_78
  • greg23_78
08 Jun 2024 11:50 - 08 Jun 2024 11:53
Mesa 7i97T IP network was created by greg23_78
Category: Driver Boards
I have a problem setting up my ip address to communicate with my 7i97T board.I followed the procedure in the link gnipsel.com/linuxcnc/debian-12-eth.html
I have the following problems
This browser does not support PDFs. Please download the PDF to view it: Download PDF
My board is setting to *SET FROM EEPPROM
  • JT
  • JT's Avatar
08 Jun 2024 10:50
Replied by JT on topic What does canon do?
What does canon do?
Category: Other User Interfaces
I worked for a while on QtPyVCP and the VTK plotter.
JT
  • Anton
  • Anton
08 Jun 2024 10:30 - 08 Jun 2024 11:43
Replied by Anton on topic error finishing read!
I have installed LinuxCNC on 3 computers so far.
1) Laptop i7: Very good latency times, very poor ping times - > unusable
2) Esprimo Q956 Mini PC with i5: poor latency, good ping - > unusable
3) DELL Optiplex 7010 Mini PC with Intel Celeron G2030 (by far the weakest processor): good latency, good ping (see appendix) -> usable
So the worst of the 3 processors is the best for real-time Linux in terms of latency and ping!!!???
So it must also be due to the mainboard, possibly the memory, ... !?
sunny greetings
  • andypugh
  • andypugh's Avatar
08 Jun 2024 09:39
Replied by andypugh on topic Gantry
Gantry
Indeed, the gantry.comp should not be used on new configurations, the correct behaviour is now built-in to LinuxCNC.
  • amanker
  • amanker
08 Jun 2024 08:48
Need help in choosing controller board from small honby cnc.
Are you still working on Remora_eth for v429? Did you looked at ld.script link I have posted?
  • Hossein74Majidi
  • Hossein74Majidi
08 Jun 2024 08:43
Replied by Hossein74Majidi on topic Can the OPI5 be Configured to Run LCNC?
Hi
I'm pretty new in this field and I'm trying hard to figure this out.
I have some challenges that I'm dealing with.
The first one, I couldn't use the GPIO driver which Guglielmi created. I'm getting some errors after configuring and writing the HAL code.
I installed the .deb package of linuxcnc and then installed the wiringop seperately.
Then as explained in following link, I cloned linuxcnc git and then copied and pasted the related files in the considered destination.
forum.linuxcnc.org/18-computer/48079-can...cnc?start=200#273554
I actually tried the halcmd loadrt hal_op5_io, but I got failed error and said it's not existed.
The second question is, is it necessary for OS to be real-time to execute this gpio driver?
and at last, can u please explain again that how should I make my Armbian, Debian bookworm to be real-time? I did the following link procedure as Royka said.
forum.linuxcnc.org/18-computer/48079-can...lcnc?start=80#269222
  • Aciera
  • Aciera's Avatar
08 Jun 2024 07:37
Replied by Aciera on topic kleine 5 Achsfräse
kleine 5 Achsfräse
Category: Deutsch
Es scheint, dass bei der sserial port Konfiguration etwas schief gegangen ist. Kannst du bitte mal die erstellte .hal Datei posten?
  • ms_5axis
  • ms_5axis
08 Jun 2024 07:22 - 08 Jun 2024 07:25
Replied by ms_5axis on topic kleine 5 Achsfräse
kleine 5 Achsfräse
Category: Deutsch
Guten Morgen,
die Steuerung ist auf dem Schreibtisch aufgebaut. PC, 7i96s + 5V Netzteil, JMC CLS auf StepGen1 + 24V Stromversorgung.
Wie vorgeschlagen habe ich mit pncconf eine Maschine konfiguriert.
Beim Start der Maschine erhalte ich eine Fehlermeldung
Die MESA Karte habe ich nach folgendem Video eingerichtet
Nur die IP habe ich auf Standard gelassen da der PC nicht im Netz hängt. Auf einem anderen PC hat die Konfiguration vor ein paar Wochen problemlos funktioniert.
Ping funktioniert
MesaFlash ebenfalls
Danach habe ich mit pncconf eine Maschine konfiguriert. Es ist nur ein Motor (Y-Achse auf Steckplatz 1 angeschlossen)
Hat jemand eine Idee wo der Fehler liegt?
Vielen Dank
Grüße und ein schönes Wochenende
Manuel
  • sven29ks
  • sven29ks
08 Jun 2024 06:40
Replied by sven29ks on topic Drehencoder Drehmaschine
Category: Deutsch
100 Impulse würden schon reichen?
Drehzahl der Spindel max 3000
08 Jun 2024 06:37
Replied by tommylight on topic Drehencoder Drehmaschine
Category: Deutsch
Mesa 7i76E ist die controller.
Umdrehzahl fur die spindel?
Normal ein 100-1000PPR encoder ist OK.
  • Aciera
  • Aciera's Avatar
08 Jun 2024 06:33
Replied by Aciera on topic Absolute homing
Absolute homing
Just checked and that is indeed how I got the pins created
  • sven29ks
  • sven29ks
08 Jun 2024 06:32
Category: Deutsch
Ich habe die Mesa 7i76e. Muß ich die Spindel denn referenzieren können (wegen Index)?
Was meinst du mit Controller?
Wieviel Impulse sollte der Drehgeber haben?
08 Jun 2024 05:51
Category: Deutsch
TTL incremental encoder mit A, B und Index oder Z, das soll ok sein.
Was fuhr ein controller?
Parallel port oder Mesa?
Welche Mesa?
08 Jun 2024 05:50
Replied by Cant do this anymore bye all on topic 2.9.2 LinuxCNC Dell XPS 15 loading ramdisk - out of memory
Category: Installing LinuxCNC
Debian should install on anything, I got Bookworm running on a circa 2006 Intel iMac desktop, as long as you give it the whole disk and don't intended to dual with MacOS it's pretty straight forward......oh needs nomodeset added to grub once installed .......but thats off topic.
08 Jun 2024 05:48
Replied by tommylight on topic What does canon do?
What does canon do?
I think Probe Basic uses VTK for preview, from reading here as it was mentioned in regards to RPI not having VTK support, and i recall something was done to make it work.
Me not helping ... :)
Displaying 25906 - 25920 out of 26048 results.
Time to create page: 1.315 seconds
