  • jblanscett
  • jblanscett
05 Mar 2026 16:32
Replied by jblanscett on topic Trying to set up position control mode
Category: HAL
Okay I changed it and there was no improvement.
  • HM
  • HM
05 Mar 2026 16:17
Replied by HM on topic RPI5_7i80HDT_7i52s+7i49+7i44+BISS
Category: Driver Boards
Thank you in advance =)
File Name: PIN_Moore_...3-05.zip
File Size:3 KB
  • mrgksworld
  • mrgksworld
05 Mar 2026 15:48
Replied by mrgksworld on topic Ethercat HAL driver
Ethercat HAL driver
Category: EtherCAT
Hello,
I try to integrate the security plc from Sick Flexi Soft via ethercat but I get the message that bitLen only allows 32 bits.
Are the restrictions limited to Linuxcnc-ethercat or do they also apply to the IGH ethercat-master.
Did you manage to integrate Sick Flexi Soft Safety controller with IgH Ethercat?
I can set the Sick safety controller in operational mode but can not able to get the data exchange correctly. Probably configuring the pdo incorrectly.
  • PCW
  • PCW's Avatar
05 Mar 2026 15:48 - 05 Mar 2026 15:48
Replied by PCW on topic Trying to set up position control mode
Category: HAL
Looking more carefully at your hal file:
setp joint.0.jog-vel-mode 1
Means that the jog will continue as long as jog count <> 0
(this is normally intended for input devices like joysticks that return to 0 when not pressed)
for position mode jogging with a MPG, you should have:
setp joint.0.jog-vel-mode 0
  • Hakan
  • Hakan
05 Mar 2026 14:01
Replied by Hakan on topic XHC WHB04B development?
I found it.
Ok, I didn't find the reason but I found a way around it.
It always crashed for me with "libusb: debug [libusb_unref_device] destroy device 3.109"
I ran it in the debugger and saw it stopped with a SIGSEGV.
After spending too much time figuring out how to turn on core dumps, I got a core dump.
Here is the stop point.
The one wonders what ctx_log_handler is
(gdb) p ctx->log_handler
$2 = (libusb_log_cb) 0xbb343c565cbddc86
I commented out this line in libusb_unref_device()
and then the xhc actually restarted.
Here is the log of that.
hal   failed to wait for requested mode. waited 500ms
pndnt wheel total counts {counts=-353 activeCounter=2 isLeadActive=0}
inTransfer = 0x558412062e00 deviceHandle = 0x558412066360
libusb_fill ..
.. done
Failed in setupAsyncTransfer -4
transmission failed, try to reconnect ...
connection lost, cleaning up
init  pausing 10s, waiting for device to be gone .............. done
init  usb context ... ok
init  not waiting for device XHC-WHB04B-6 vendorId=0x10ce productId=0xeb93, will continue in 0s ...1 ok
init  XHC-WHB04B-6 device found
init  detaching active kernel driver ... ok
init  claiming interface ... ok
init  enabling reception ...In enableReceiveAsyncTransfer
inTransfer = 0x558412062e00 deviceHandle = 0x558412075a50
libusb_fill ..
.. done
 ok
in    0x04 10 00 00 0f 13 00 10 delta 15 => | 04 | 10 |                 |                 |   0.1( 10%) |     Z(    ) |  \
 0 | 10
pndnt wheel  event -353
  • Lcvette
  • Lcvette's Avatar
05 Mar 2026 13:39
Replied by Lcvette on topic Add Buttons in Probe Basic
Category: QtPyVCP
were you able to get it set up and working? :side:
  • T_D
  • T_D
05 Mar 2026 13:36
Replied by T_D on topic Probleme mit NativeCam
Category: NativeCAM
how do i change the pref_edit.py from this one out of the forum with mine becaus when i am just copy paste than occurs an error . regards tom
The links : NativeCAM-Python3-Debian-12-Installationguide2026-02-20.pdf
: forum.linuxcnc.org/media/kunena/attachments/40714/pref_edit.py
  • RotarySMP
  • RotarySMP's Avatar
05 Mar 2026 13:00
Replied by RotarySMP on topic chineese mesa 7i92 custom bit file
Amazing support Peter, but I really don't understand the expectation of the original post.
Your Mesa cards are very resonably priced. You have obviously put years of work into designing and updating these cards, and provide outstanding support to us here in the forum.
Someone reverse engineers your work, floods the market with knock-offs, undercuts your livelyhood, and then expects support?
You are a better person than me Peter. In your place, I would be tweaking Mesaflash to brick any knock off which gets connected to it :)
Cheers,
Mark
  • meister
  • meister
05 Mar 2026 12:27 - 05 Mar 2026 12:29
something like this:
and it will generate the code for all FPGA's and MCU's
the interlinks are RS422 over RJ45 cables (like smart-serial)
  • ClarkSavage
  • ClarkSavage
05 Mar 2026 12:17
Replied by ClarkSavage on topic 7i92T and mx3660 request for help
Category: PnCConf Wizard
Ok, got it, good to know - and I do not know that much about Linuxcnc and lastly, Pnnconf / MESA stuff. All new.
But, all limits working now. I just need to check the probe setup - think that I can do after the limit switch and HalShow stuff initiation.
But, my ESTOP is still beyond me. Saw threads where JT and I believe a few others talked about inserting lines that linked the ESTOP pin to other pins or feedback - tries several but beyond me once again.
ESTOP - loaded all pins and all ESTOP, Abort, Charge pump references into HalShow, enabled [it's a NC switch] my external ESTOP button and nothing in Halshow changed color. Yes, my external button is wired into the mx3660, and yes it shuts down the motors on push.
I tried to move the ESTOP to different pins that were open and then Halshow - no change. The probe pins work in Halshow so I know that is at least on the right pin and gives feedback - I can figure that out.
So any suggestions on ESTOP? Else I will live with it the way it is. Still have a lot of changes to do with travel and positioning in the ini for axes but that's easy stuff, just takes me a little longer one step at a time.
  • meister
  • meister
05 Mar 2026 12:09
Thanks.
at the moment, i rewrite the riosub stuff in the dev branch and the riosub plugin will be removed in the next release.
it will be replaced by uartsub+uart/satmcu (i need other names for that plugins, something with 'satellite').
The reason is that you can then edit everything in one configuration and thus always have the overall picture in front of you.
Then you can also use microcontrollers as satellite-board and configure them in the Flow GUI.
  • epineh
  • epineh
05 Mar 2026 11:49
You are doing awesome things, I plan to start testing Riosub in the near future, hopefully I can contribute something useful !
  • jblanscett
  • jblanscett
05 Mar 2026 11:12
Category: HAL
I don’t have anything in those files. I’m very new to Linuxcnc so maybe I missed a step somewhere to set those files up?
  • DerKlotz
  • DerKlotz
05 Mar 2026 09:52 - 05 Mar 2026 09:58
Verdrahtung Leadshine DM856 Ena+ und - bei Mesa 7i76e
Category: Deutsch
Moin,
ich würde gerne die ena+ und ena- Eingänge meiner Leadshine DM856 bei einer Mesa 7i76e beschalten. Wenn ihr euch die Anhänge anseht... nach welcher Schaltung muss das geschehen? Spontan würde ich nach PNP sagen... nur ist das richtig?
  • DerKlotz
  • DerKlotz
05 Mar 2026 09:13
Replied by DerKlotz on topic Add Buttons in Probe Basic
Category: QtPyVCP
Wow, wow and wow! Great job. Thank you so much
Displaying 6136 - 6150 out of 12553 results.
Time to create page: 0.943 seconds
