  • Waldemar
  • Waldemar's Avatar
09 Sep 2025 07:37
Replied by Waldemar on topic Simple/Manual Centre Finder
Category: AXIS
Cheers Andy,
I'll get hold of 2.9.5 and try it out on the sim!
  • 3Draf
  • 3Draf
09 Sep 2025 07:04
StepConf - tandem axe Y - comment configurer 2 moteurs synchrones
Category: Français
J'ai installé les interrupteurs de fin de course, un pour chaque moteur.
Je veux synchroniser les moteurs de manière logicielle pour qu'ils puissent se calibrer séparément et se déplacer de manière synchrone.
L'inversion des câbles est une bonne solution, mais cette machine appartient à mon employeur qui préfère ne pas toucher au matériel (et garder la compatibilité avec l'autre pc avec Mach3)
Dois-je modifier les fichiers .hal et .ini ou est-ce possible avec StepConf ?
I've installed limit switches, one for each motor.
I want to synchronize the motors in software so they can calibrate separately and move synchronously.
Reversing the cables is a good solution, but this machine belongs to my employer, who prefers not to touch the hardware (and maintain compatibility with the other PC with Mach3).
Do I need to modify the .hal and .ini files, or is this possible with StepConf?
  • jpg
  • jpg
09 Sep 2025 06:52
Replied by jpg on topic G33.1 synchronized tapping problem
Hello Aciera, regarding your “patch,” I would like to know if it is functional? Have you had any feedback? It is indeed a matter of correcting the defect concerning the tapping after the execution of the caxis component.
  • ziggi
  • ziggi's Avatar
09 Sep 2025 05:57 - 09 Sep 2025 07:34
Troubles to get started with SD240 Retrofit
Category: Turning
Ok- so the first thing you suggest to try would be single ended.  Is just setting the jumper DOWN really all I need to do in this case and the axis should (ideally) behave like before? Or will there be more to it?
Well, I will simply try to jumper it to TTL and see if I can run the axis single ended properly or not.
Years ago I remember such "differential converters" on Uhu´s (DC-drives) - these where small and pretty inexpensive parts. But I just knew them for converting A+B channels to A/A* and B/B* , did not need the index in this times....
If I could use such converters to get a differential Index signal out of a single one and so solve the issue I would be fine with it.
Unfortunately I can not simply exchange the encoders as these Fanuc encoders seem to be part of the servo motor and the rear end bearing of the motor.
So I will first try to run the axis with the 7i33 jumpered to TTL, see how it behaves with the single A/B signals and if I can use the index signal then.
Thank you
Sigi
  • cadcam
  • cadcam
09 Sep 2025 05:55 - 09 Sep 2025 08:29
Replied by cadcam on topic problems with Verser Probe Screen 2.9
Category: Basic Configuration
Maybe we can combine them?
  • mBender
  • mBender
09 Sep 2025 02:44
I need some help here again. I am having a weird issue with my machine. I first thought it has nothing to do with Riocore, but now I am not so sure anymore.
Posted here: forum.linuxcnc.org/12-milling/57122-mach...-programm-repeatable
Oliver or someone with experience, could you explain a bit more what the settings in the Stepper dialog under Step mean?
The Step signal for my machine is inverted. I tried to remove the inversion from the step signal, but than the Stepper don´t move at all. Does that make sense??
  • jschulze
  • jschulze
09 Sep 2025 02:17
Kinematic model for a 5axis mill with universal (nutating) head
Category: Show Your Stuff
Can you post your modified kinemaitics file and your ini file?
Here's all my files.  I've included .ini, .hal, and kinematics comp file.
  • scotth
  • scotth
09 Sep 2025 01:22
Replied by scotth on topic Axis_Comp having no effect[SOLVED]
I did most of my work on big iron. Watching what happens with an AC vent hitting the top of a machine with a laser will drive you crazy.
Good luck!
  • CNC4Life
  • CNC4Life
09 Sep 2025 00:45
Replied by CNC4Life on topic Axis_Comp having no effect[SOLVED]
Yes, it’s a rolled screw it has error from the manufacturing process. Thomson claims +\- 0.004 per ft / 300mm.
Though it could be mathed out in the SPU if I was using UCCNC or MASSO.
  • xunil
  • xunil
09 Sep 2025 00:19
Replied by xunil on topic halui.mdi-command-NN pins not showing up
Category: HAL
I'm happy to report that building the 2.9 branch (incorporating the merged PR mentioned above) from the LinuxCNC github solved the problem - the mdi-command-NN pins show up and function as expected.  Thanks for the fix!
-Rob
  • unknown
  • unknown
08 Sep 2025 23:13
Replied by unknown on topic Trixie libgpiod
Trixie libgpiod
Category: Installing LinuxCNC
Nevermind, I forgot how to correctly read and comprehend English.
  • PCW
  • PCW's Avatar
08 Sep 2025 22:52
Replied by PCW on topic Proximity sensor hardware debounce?
I would use an RC filter if in a high noise environment
Also not sure from your description,  whats 24V and whats 5V
no 24V signal should be anywhere near 7I92T I/O pins
  • PCW
  • PCW's Avatar
08 Sep 2025 22:46
Replied by PCW on topic Homing is not working
Category: HAL
Can you do a:
halcmd show all | grep home > beforehome.txt
With LinuxCNC launched and enabled but before being homed
and
halcmd show all | grep home > afterhome.txt
With LinuxCNC launched and enabled after being homed (well at least home button pressed)
and post both berforehome.txt and afterhome.txt here?
  • PCW
  • PCW's Avatar
08 Sep 2025 22:38
Category: Turning
Ahh, looks like the index is single ended, maybe that's the issue.
Unfortunately the 7I33, each encoder input is all differential or all single ended
So one thing to try would be to select single ended instead of differential
encoder mode one the 7I33. This is not ideal as it less resistant to noise
but may be OK.
If setting the 7I33 to single ended encode mode works, there is also
the possibility of using custom firmware that puts all the index inputs
on one 7I33 encoder connector  so you could have differential for A,B
but TTL mode for the Index signals.
Another possibility is to add a TTL to differential converter for the index signals
Mesa has such a thing, but its really just 1 chip on a board
(26ls31 or one of the many equivalents)
Displaying 10126 - 10140 out of 17035 results.
Time to create page: 0.398 seconds
