  • grossm5000
  • grossm5000
28 Mar 2026 15:23
Replied by grossm5000 on topic Differential encoder hard crashes the PC MESA7i77
Category: Driver Boards
To be clear, i am not hard crashing anymore after installing a new 6i25 that i got last week. I am not sure what firmware is on either board.
I could try another motherboard...just a ton of work. what does the w3 jumper do on the 6i25?
i may try going back to breakout power enabled on the 6i25. It didnt like the differential encoders when I did that, but at least i was getting things through the 7i77.
  • PCW
  • PCW's Avatar
28 Mar 2026 15:13
I wonder if somehow the motherboard was damaged in some way at the first fault.
Because this is quite odd behaviour.
I wonder if you would get the same hard crash fault if the new 6I25 had the correct firmware?
  • grossm5000
  • grossm5000
28 Mar 2026 14:47
ok, I used the setpci command, seems to have worked, I no longer get a disabled on the lspci command:
however, the very next thing I do is try to run mesaflash, and again it cannot find the card:
I have adjusted all the PCI setting I could find in BIOS, no luck there either. The motherboard does not have PCIe jumpers, checked that as well. Everything was set to GEN1 just the same
  • endian
  • endian's Avatar
28 Mar 2026 13:03
Replied by endian on topic LinuxCNC S-Curve Accelerations
Hello,
I am sorry my bad ...I am too much focusing in something and then I failing in others ...
I have tested some toolpaths till now ... Infinite spikes are gone at tp 1 and 2 at paths where it defenetely were in the past ... I noticed that TP1 during its startup with testing code 1_1001.ngc spiking much with servo time (if we take 250us as our goal - for 1ms it is fine) ..
Default TP0 and TP2 do not this behaviour ...
dark blue from scope pictures in the attachments then TP1 is spiking at each segment change over 200us during cloud of points its repeating spiking too..
I notice that switching between TP1 and 2 is not possible sometimes it creates error and switch me back to TP2 from TP1
thank you E.
  • slowpoke
  • slowpoke
28 Mar 2026 12:51 - 28 Mar 2026 12:54
Keyboard key to activate a Mesa output was created by slowpoke
I'm near complete converting another manual lathe (Standard Modern this time) to LinuxCNC.
These programmable keypads are convenient for commonly used key entries to Axis/MDI. From LinuxCNCs perspective they are just another keyboard.
I have a few spare keys and I would like to use one to activate a Mesa output. I can program the key to any key or even key sequence.
Is there a way to make this happen in HAL?
IIRC there is a file somewhere that either defines or lets you redefine key codes, I'm not sure if that will come into play? I suppose choosing an oddball key for this might be advantageous, so a typing a key on the regular keyboard does not inadvertently activate the Mesa output.
  • JT
  • JT's Avatar
28 Mar 2026 12:02
Ext hard buttons duplicate Power_PB and Reset
Category: Flex GUI
Connect your external power button to halui.machine.on, note the estop must be released before pressing the power button.
JT
  • ihavenofish
  • ihavenofish
28 Mar 2026 11:51
Replied by ihavenofish on topic Ethercat Setup help needed for beginner
Category: EtherCAT
Er, no. It’s not that simple; LinuxCNC isn’t plug-and-play. If you don’t have any prior knowledge, you should put the A6 aside for now and start with simple stepper motors. You’ll first need to learn how the system works and what each component does. With EtherCAT, you’re moving beyond the hobbyist level, and even professionals sometimes find it frustrating.
I only broke 4 mice from throwing them in anger... its fiiiinnnee.
In seriousness though, I find its less about beginner vs expert in CNC stuff, and more about if you are well versed in linux usage. Most of my troubles setting up were because the instructions just assume you know everything about linux already and leave a lot of critical details out. I am working with one of my customers to trying an make a true step by step guide.
If you do know "nothing", step and direction with a mesa card is generally pretty safe cause its mostly done by a wizard. You aren't mucking in the terminal or doing much editing in HAL.
(also important to note ethercat in linuxcnc has some quirks too, its not quite "final" in my opinion)
  • JT
  • JT's Avatar
28 Mar 2026 10:57
Replied by JT on topic Jog troubles
Jog troubles
Category: Flex GUI
The following is the Python interface so it forces you to use joint number before homing then use index of axis after homing.
    joint_num_or_axis_index
        For joint jog (jjogmode=1)
            joint_number
        For axis Cartesian coordinate jog (jjogmode=0)
            zero-based index of the axis coordinate with respect to the known coordinate letters XYZABCUVW (x=>0,y=>1,z=>2,a=>3,b=>4,c=>5,u=>6,v=>7,w=>8)
JT
  • Hakan
  • Hakan
28 Mar 2026 09:39
Replied by Hakan on topic Ethercat Setup help needed for beginner
Category: EtherCAT
It's easier to start with a Mesa card for sure.
You have the pncconf utility that will give you a working configuration.
Once you have the Mesa config working, it's not that hard to
replace the motion part with EtherCAT. Cut and paste, though.
  • Spezidrohne
  • Spezidrohne
28 Mar 2026 09:31
Replied by Spezidrohne on topic Ethercat Setup help needed for beginner
Category: EtherCAT
I should add that i have done simmilar things, and have a good bit of knwoledge near, not specifically with the ethercat stuff, but with Profinet, Profibus, industrual automation, PLCs etc.
  • Spezidrohne
  • Spezidrohne
28 Mar 2026 09:28
Category: EtherCAT
Thanks. I will try to adopt them. As far as i have seen, the example file is for 3drives, and i right now only have one. The pid and vid i will also have to fill out.
Starting this project, I knew there will be a pretty steep learning curve. But i like challenges. I also have a Mesa Card on its way. Would that be easier to start with?
  • Hakan
  • Hakan
28 Mar 2026 08:09
Category: EtherCAT
It's easy when you know it.
The problem is to come to know enough.
Anyway, it's not that hard and there is virtually no difference between
setting up stepper drives or servo drives with EtherCAT.
The cia402 layer makes them look the same.
The example I gave is a starting point.
You can copy the files to your installation, change the HALFILE=cia402.hal in the ini file
and give it a try.
But you are going to need to adopt and edit the files to your specific setup.
Number of drives, what number/name they have. And you need to add other
functions like spindle. That's in the sim file. So you need to mix them together
and take the motion part from cia402.hal and the other functions spindle, limits etc
from the sim config.
  • Hakan
  • Hakan
28 Mar 2026 08:02
Replied by Hakan on topic Ethercat boards and hardware
Don't use EtherCAT if you want to use a step/dir driver.
There are advantages to skip the intermediate step with
step/dir for steppers and analog +-10V for servos.
The right way is to have a EtherCAT drive that controls the
motor directly, skipping that middle step.
I have built an EtherCAT board that gives step/dir signals.
But it's not the right way to go.
  • ts
  • ts
28 Mar 2026 03:14
Replied by ts on topic Jog troubles
Jog troubles
Category: Flex GUI
Hi, Rodw! Glad to see you in this topic)
Jog before homing.. hmmm.. for example, edm machine , some emergency, estop pressed or power loss.. and mechanical of the machine stucked. I have to move before homing, because homing may broke everything on the work table
  • ts
  • ts
28 Mar 2026 03:10
Jog troubles
Category: Flex GUI
Yes, it will work. But only after homing.
Before homing its work as 3rd number (all axus numbers are 0-1-2-3 )
Displaying 241 - 255 out of 17469 results.
Time to create page: 1.778 seconds
