  • rasmus
  • rasmus
25 Nov 2025 18:26 - 25 Nov 2025 20:41
Replied by rasmus on topic carousel.comp scale questions.
Sorry, I am using version 2.9.3.
and uname -srm:
Linux 6.1.0-30-rt-amd64 x86_64
  • meister
  • meister
25 Nov 2025 16:52
Replied by meister on topic SmartSerial on cheap ESP32-8ch-Relais Card
Category: Driver Boards
ok, works also on the 7c81 ports :)
  • PCW
  • PCW's Avatar
25 Nov 2025 16:14
Replied by PCW on topic Chinese Mesa 7I92 from aliexpress NEW
It may be that the Fujitsu Mini PC (like many laptops) has some
built-in power management that cannot be disabled.
  • Klak
  • Klak
25 Nov 2025 16:10 - 25 Nov 2025 18:07
Problems with Lichuan Ethercat servo drive
Category: EtherCAT
Hello,
@LCR
Did you manage to solve the problem of offset a different way than the integration loop ? I have the exact same problem, and I am stuck when using csp mode :(
I have everything working, some of it is AI coded, but I also made an installation guide on how I did it.
github.com/KlaKalma/Ma_CNC
Here is the repo, for those who want it.
This LC10E drive seems quite hard to use....
When I use CSV tho, it's working super well. I have a custom-made PID tuner, that automatically tunes the PID for the position. It's on the git. I have a few microns of error as well.
  • Sekai
  • Sekai
25 Nov 2025 15:20 - 25 Nov 2025 15:21
Replied by Sekai on topic Chinese Mesa 7I92 from aliexpress NEW
I did a
sudo ethtool --show-eee enp6s0
And it show that the eee is inactive.
but the value is still over 5ms.
  • snowgoer540
  • snowgoer540's Avatar
25 Nov 2025 12:30
Replied by snowgoer540 on topic Ohmic Probe + Material Height Feature Request
Category: Plasmac
In fairness, you did say "take your time" :-).  I honestly didn't realize it has been since April that we talked about this.
I have a ~75% diff created.  I will try to make time to see this to completion in the coming days.  I'll take a look at what you've provided and no doubt merge it with what I've got and it'll be a nice little collaboration.
Thank you for providing what you did, I will let you know when I've committed everything!
  • TripleM
  • TripleM
25 Nov 2025 11:41 - 25 Nov 2025 11:43
Replied by TripleM on topic Suche Fusion Postprozessor für Drehmaschine
Category: Deutsch
habe den aktuellen PP angepasst, und die Bohrzyklen G81, G83 hinzugefügt.
Bei mir funktioniert dieser sehr gut, bitte aber bei dir an der Maschine genau prüfen.
  • Todd Zuercher
  • Todd Zuercher's Avatar
25 Nov 2025 10:44
Replied by Todd Zuercher on topic adaptive feed enable disable and indication from halui
Could you could use some Halui MDI commands?
  • Aciera
  • Aciera's Avatar
25 Nov 2025 06:43
calling subroutine from G54, G55, G56, but it acts weird
Category: O Codes (subroutines) and NGCGUI
'P0' will set the currently active offsets, while 'P1','P2' ... will set the values of a particular offset system.
You could also stay in G54 and use different G52 offsets.
  • Ul
  • Ul
25 Nov 2025 06:30 - 25 Nov 2025 06:31
Tipps für aktuelle LinuxCNC Hardware gesucht
Category: Deutsch
Wenn es bereits läuft, ist es natürlich wurscht.
Ich suche eher was fürs Bedienpanel und die Aliexpresskarte schien mir brauchbar. Habe sogar ein PDF bekommen, wo was zur Einrichtung steht, aber nichts von einem Bitfile o.Ä.
Wenn den Chinesen keiner testen will, werde ich mir wohl eine 7i73 kaufen. Hab gerade eben herausgefunden, dass Portugal doch in der EU ist und deswegen kein Zoll zu zahlen ist.
  • rodw
  • rodw's Avatar
25 Nov 2025 06:23
Replied by rodw on topic LinuxCNC homing twice in Axis SImulation
Category: AXIS
I think what you experienced is expected behaviour. Once an axis is homed, it can't be homed again unless its unhomed. I did notice recently in a axis sim that the unhomed menu was not enabled...
  • meister
  • meister
25 Nov 2025 05:47 - 25 Nov 2025 05:57
i modified the  mesa-smartserial-device-template a little bit
and put it on a cheap ESP32 8ch-Relay board for extra Outputs.
i used platformio as buildsystem for easy use, i have also test the code on raspberry-pico,
github.com/multigcs/SmartSerial-ESP32RelayX8Board/tree/main
www.youtube.com/shorts/6ZKBH5xW8OQ
Relay-Board: www.amazon.de/dp/B0FNRH8QSN
Optional: www.amazon.de/TECNOIOT-Two-Way-Transfer-...tional/dp/B081J5R35N
Works fine with 7i92, but have still problems with 7c81 SmartSerial connector, not shure why,
maybe my pinout is wrong or problems with the TX_en stuff.
my Board with RS422 mod:
  • emresensoy
  • emresensoy
25 Nov 2025 02:59
Replied by emresensoy on topic LinuxCNC Hardware Survey
We have ESI files and many examples,
But, of course a driver is better than ever
  • EW_CNC
  • EW_CNC's Avatar
25 Nov 2025 02:46
Category: Plasmac
I have added the Material Thickness parameter option for Ohmic Probe with Material Height.
The updated files are in the attached qtvcp folder. It needs to be placed into your working machine config directory.
Also the attached custom_postgui.hal must also be in your machine config folder.
The qtplasmac-imperial_material.cfg file has the material thickness added, it has the settings for a Hypertherm Powermax 85.
Snowgoer, I'm not sure if the custom_postgui file is the proper place to do the hal pin linking. If you have time to review the changes and add it to the source code, I would appreciate it. Otherwise I can try to figure out git and do a pull request.
File Name: qtvcp.tar.gz
File Size:780 KB
File Name: custom_postgui.hal
File Size:0 KB
File Name: qtplasmac-...rial.txt
File Size:24 KB
  • Lcvette
  • Lcvette's Avatar
25 Nov 2025 02:31 - 25 Nov 2025 02:32
Replied by Lcvette on topic Rack ATC
Rack ATC
Category: QtPyVCP
For probe basic non of that is required, the existing rack atc is fully setup for configuring the atc in the gui once the correct ini settings and var file parameter numbers have been added. It uses random tool change and tracks pockets the same as random carousel. Looks for the first open pocket for storing the tool and finds the tool by its tool number and the parameter number its stored in. We made it super easy to setup with only a few user entries in the ui itself to determine where the rack is on the machine and the direction of ascending pocket order . Then the first pocket coordinate and the pocket spacing is entered and the drop off and pickup heights and clearance distance and its ready to rock and roll!
Displaying 6466 - 6480 out of 16729 results.
Time to create page: 0.338 seconds
