  • PCW
  • PCW's Avatar
10 Oct 2025 20:41
NEW BUILD, need help with e-stop in tklinuxcnc
Category: Basic Configuration
Are you saying the GUI never launches?
  • andypugh
  • andypugh's Avatar
10 Oct 2025 20:38
Controlling spindle using python scripts and Modbus TCP
import linuxcnc and hal into the Python script, then create HAL pins to receive the spindle commands from HAL.
Load the Python script at load-time with a "loadusr" command in the HAL.
  • Dragan
  • Dragan
10 Oct 2025 20:37
c@raspberrypi:~/linuxcnc/configs/microcarve$ LINUXCNC - 2.9.6
Machine configuration directory is '/home/cnc/linuxcnc/configs/microcarve'
Machine configuration file is 'microcarve.ini'
Starting LinuxCNC...
Note: Using POSIX realtime
Found file(REL): ./microcarve.hal
task: main loop took 0.100768 seconds
task: main loop took 0.113741 seconds
task: main loop took 0.140260 seconds
this is what i get running it from commandline. task: main loop ........
  • andypugh
  • andypugh's Avatar
10 Oct 2025 20:34
Replied by andypugh on topic Axis configuration not fully working on 2.9.6
Category: AXIS
Can you report this problem on the issue tracker?
github.com/LinuxCNC/linuxcnc/issues
  • PCW
  • PCW's Avatar
10 Oct 2025 20:30 - 10 Oct 2025 20:32
if this:
net estop-loop =>iocontrol.0.user-enable-out
net estop-loop => iocontrol.0.emc-enable-in
does not work, it's most likely because you have
estop-loop connected to another pin in the hal file.
Starting LinuxCNC from the command line will show the actual error.
  • andypugh
  • andypugh's Avatar
10 Oct 2025 20:27
Replied by andypugh on topic XHC-WHB04B-04 Got it working
it's almost like multiprocess welders, unless you drop some serious money, you're compromising.
Off-topic but I am impressed with the multiprocess welder at my local Hackspace. It allows you to keep both MIG and TIG torches permanently connected and has separate gas input spigots for each process gas.
You are not wrong about the "serious money" part, though.
parweld.com/product/xtm211di/
(#notsponsored :-) )
  • Dragan
  • Dragan
10 Oct 2025 20:19
axis not working over vnc in my setup,
this is resulting in tklinuxcnc not starting, maybe its working with older software versions.
  • andypugh
  • andypugh's Avatar
10 Oct 2025 20:16
Replied by andypugh on topic NEW BUILD, need help with e-stop in tklinuxcnc
Oh, and why tklinuxcnc? There's nothing wrong with it, but it's rather outmoded and hasn't had a lot of developer attention for a while.
  • andypugh
  • andypugh's Avatar
10 Oct 2025 20:10
net estop-out =>iocontrol.0.user-enable-out
net estop-in => iocontrol.0.emc-enable-in
I think these need to be the same signal name to work as described. Try:
(note that the signal name is nothing special, there is no significance in changing it to loop, other than clarity. The important thing is that it should be the same name on both lines)
  • andypugh
  • andypugh's Avatar
10 Oct 2025 20:06
Replied by andypugh on topic Strugling with installation
Category: Installing LinuxCNC
Is this with the LinuxCNC install image?
  • andypugh
  • andypugh's Avatar
10 Oct 2025 20:03
Button on Linuxcnc interface that switches an output on Mesa 7i76e on and off
Category: GladeVCP
If your Glade UI element is of type "Hal button" then the HAL pin will be created automatically and no handler file is needed.
(This is stated with 93% confidence, I don't have easy access to a LinuxCNC machine at the moment to test this assertion)
  • Fastfred
  • Fastfred
10 Oct 2025 20:01
Replied by Fastfred on topic Gmoccapy tool setter install "errors"
Category: Gmoccapy
[Gmoccapy.GMOCCAPY.GETINIINFO][[33mWARNING[0m] No DEFAULT_SPINDLE_SPEED entry found in [DISPLAY] of INI file (getiniinfo.py:282)
[Gmoccapy][[33mWARNING[0m] No virtual keyboard installed, we checked for <onboard>. Try 'sudo apt-get install onboard'. (gmoccapy:2112)
gmoccapy_postgui.hal:24: Pin 'gmoccapy.toolchange-change' was already linked to signal 'tool-change-request'
10530
  • andypugh
  • andypugh's Avatar
10 Oct 2025 20:00
Replied by andypugh on topic Axis control via ModbusTCP
If you have proved that you can control the drive from Python then I would suggest carrying on with that.
You can "import linuxcnc" and "import hal" into your Python script then create HAL pins to recieve the position commands from HAL.
linuxcnc.org/docs/stable/html/config/python-interface.html
linuxcnc.org/docs/stable/html/config/python-hal-interface.html
  • nanowhat
  • nanowhat
10 Oct 2025 19:47
Ethercat drives not responding, mesa error finishing read
Category: EtherCAT
I can try it, but since ethercat at the command line (linuxcnc isn't even running) shows ~50% lost uploads, what's the point?
I don't think this is a linuxcnc problem, but rather some networking or drive problem.
  • andypugh
  • andypugh's Avatar
10 Oct 2025 19:40
Replied by andypugh on topic MPG pendant interface 7I96s
Category: HAL
I think that the problem is inconsistent HAL signal naming.
You have
net joint-select-a     <=  hm2_7i96s.0.inm.00.input-01
Then later in the file:
net axis-select-x  halui.axis.x.select
You need to connect the hm2_,,, pins to the halui.... (and motion....) pins.
Use the same signal name (the first term after "net") to link:
hm2_select pin / axis.L.jog-enable / joint.N.jog-enable
hm2_mpg_counts / axis.L.jog-counts / joint.N.jog-counts
You will also need to work out logic to set the scale:
(probably a mux block) axis.L.jog-scale joint.N.jog-scale
For initial testing, try:
net jog-scale => axis.X.jog-scale joint.0.jog-scale
net jog-scale => axis.Y.jog-scale joint.1.jog scale
net jog-scale => axis.Z.jog-scale joint.2.jog-scale
setp jog-scale 0.1
(change the setp to 0.01 if using inches)
If that works, then configure the jog scale (but to help with that we wiuld need to know whether the MPG binary-codes the speed selector or has a pin for each speed)
(This is using the pins from "motion" which are slightly preferable to the halui pins. However HALUI supports analog jog mode, so has its uses.)
linuxcnc.org/docs/stable/html/man/man9/motion.9.html
Displaying 8926 - 8940 out of 16970 results.
Time to create page: 0.571 seconds
