  • kb58
  • kb58
27 Sep 2025 16:48 - 27 Sep 2025 16:49
(Solved) Initialization code for a rintelligent ECT60 fails when run on an ECR60
Category: Driver Boards
I will try that, yes. What is meant by "nets and stuff?"
I will also try the factory reset but am unsure how well that will work. What I mean is, let's say that I issue the factory reset command upon entry to the code. Then, the following code will immediately configure the driver into a "not factory reset" condition. Is the thinking that something was changed that has not been corrected and that a factory reset is the only way to fix it?
  • Hakan
  • Hakan
27 Sep 2025 16:48 - 27 Sep 2025 16:52
Replied by Hakan on topic Trouble with Cia402 drive configuration
Category: EtherCAT
I meant "lcec_configgen".
I don't think there is a guide for TwinCAT here, have not seen one.
Maybe my old stumbling tries with Twincat still works.
Youtube video Twincat start
Download TwinCAT XAE shell from beckhoff (free).
It might need other downloads as well, but once installed it seems to work.
So I think we have tried everything now.
TwinCAT should be supported by the manufacturer, so you should be able to ask the manufacturer how to get it running.
Once you have got was is needed to get the drive from PreOP+E it should be possible to replicate in lcec.
  • Hakan
  • Hakan
27 Sep 2025 16:37
Can you comment out nets and things in the hal file to also remove the digital in and out?
rodw also mentioned doing a factory reset of the drive by writing to a sdo. Can you do that too?
  • Ul
  • Ul
27 Sep 2025 15:55
  • ulda
  • ulda
27 Sep 2025 14:53 - 27 Sep 2025 14:56
proudly presenting a Maho MH700 retrofit ..
Category: CNC Machines
Hi
The machine is sold, but I have the config data.you can download it to the attachment.
/ulda
  • Aciera
  • Aciera's Avatar
27 Sep 2025 14:31
Replied by Aciera on topic Spindle speed settings
Category: Gmoccapy
I think you might have to look at the [SPINDLE_0] section in the ini.
  • kworm
  • kworm
27 Sep 2025 14:17
Replied by kworm on topic Beckhoff AX5YZZ internal probing
Category: EtherCAT
If you already have it working in TC3 then my stuff won't help.  I don't know if you are using Beckhoff drives but here is some documentation that might help.  I think you will have to parametize everything and then enable with something like S-0-0405 before initiating with the control word.
Pages 104-105:
download.beckhoff.com/download/Document/...scription_hw2_en.pdf
Many IDNs dealing with probing...just search for "prob":
download.beckhoff.com/download/Document/...N_Description_en.pdf
Hope this helps.
  • GDTH
  • GDTH's Avatar
27 Sep 2025 13:52
Carousel with counts move x amount of pockets
okay, i will sure to be using in that in the end. however when i am using M120 or just put the pocket number manualy it just gets stuck in state 8 where it is waiting for align_pin to be something else then 0. As nothing moves , this will never happen. also i constantly getting the error "the toolchanger has hailed its alignment check". I have used the carousel comp many times. howeve this is the first time with only a stepgen. with that in mind and that i barely find anyone use it the same i am question if this actualy works with stepgen (Counts).
  • jcbryant
  • jcbryant
27 Sep 2025 13:40
Going from Devian 10 to 12 has created problems
Thank you very much for explaining this. I do hate not understanding things. And I now understand how it can be that simply writing to a file effect irq's, and why changes made don't persist after a reboot (something else that was troubling me). Clearly this is an instance of a pseudo file system (something I'd never heard of until this morning).
This whole experience has extended my limited knowledge of Linux. And, incredibly enough, I now seem to have a functioning system. The diagnostic tests look good and, although I've hardly stressed it very much, Linux CNC appears to be perfectly functional save for the fact that the Axis window won't maximize. I'll start a separate thread on this as it's a pretty specific issue. Hopefully a solution will turn up, and f none does I've also found some workarounds.
Many thanks to both of you for responding. Were it not for you two I would never have got things working.
  • phew
  • phew
27 Sep 2025 13:26
LCNC 2.9.5 - How to jog with a wireless xbox bt controller
Category: Basic Configuration
Yeah, finding things on the forum is currently a bit tedeous for me. At least from Central Europe it sometimes takes like 15-20 seconds to load a single thread. Since my last visit this seems to have improved a lot (today it's actually quite fast), maybe it was just a temporary routing issue. The wiki loads way faster though, probably due to its pages being static.
Yeah I completly understand, I mean jogging with the controller is more of a nice-to-have than a must-have.
github.com/LinuxCNC/linuxcnc/issues/3573
  • anli
  • anli's Avatar
27 Sep 2025 11:34 - 27 Sep 2025 11:38
Spindle speed settings was created by anli
Category: Gmoccapy
I try to setup my spindle in gmoccapy. The spindle uses wj200_vfd, I can start it and run it via gmoccapy, however I don't manage to set up the correct parameters for the speed selection. The spindle has min speed 0 and max speed 24000 rpm. This is my setup:
In machine.hal:
[DISPLAY]
DISPLAY = gmoccapy
CYCLE_TIME = 150
DEFAULT_SPINDLE_SPEED = 2000
MIN_SPINDLE_OVERRIDE = 0
MAX_SPINDLE_OVERRIDE = 2.4
DEFAULT_SPINDLE_0_SPEED = 2000
MIN_SPINDLE_0_SPEED = 0
MAX_SPINDLE_0_SPEED = 24000
MIN_SPINDLE_0_OVERRIDE = 0
MAX_SPINDLE_0_OVERRIDE = 2.4
and in machine.pref:
scale_spindle_override = 2.4
spindle_bar_min = 0.0
spindle_bar_max = 24000.0
spindle_start_rpm = 10000.0​​​​​​​
but I can't manage to get it up to 24000rpm. What am I doing wrong here?
  • nikopoli@live.it
  • nikopoli@live.it
27 Sep 2025 11:21
Replied by nikopoli@live.it on topic Repair servodrive yaskawa CACR
  Yes of course This Is the okay board
  • anli
  • anli's Avatar
27 Sep 2025 09:51
Replied by anli on topic Update LinuxCNC 2.9.5 on debian 13
Category: Installing LinuxCNC
Thank you, I managed to get the machine up and running now.
I fixed the errors in the ini and the glade file (wrong labels).
However, if I try to update to LinuxCNC via
apt update
, I receive the following error:
root@linuxcnc:/etc/apt/sources.list.d# apt update
OK:1 http://security.debian.org/debian-security trixie-security InRelease
OK:2 http://deb.debian.org/debian trixie InRelease
OK:3 http://download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ InRelease
OK:4 http://deb.debian.org/debian trixie-updates InRelease
OK:5 https://tvd-packages.tradingview.com/ubuntu/stable jammy InRelease
OK:6 https://repository.qtpyvcp.com/apt develop InRelease
OK:7 https://dl.google.com/linux/chrome/deb stable InRelease
OK:8 https://packages.microsoft.com/repos/code stable InRelease
Holen:9 https://www.linuxcnc.org trixie InRelease [31,1 kB]
Fehl:9 https://www.linuxcnc.org trixie InRelease
  Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on EEDD0D29F81DCAA0D258661F3CB9FD148F374FEF is not bound:            Policy rejected asymmetric algorithm   because: DSA1024 is not considered secure since 2014-02-01T00:00:00Z
Warnung: http://download.opensuse.org/repositories/science:/EtherLab/Debian_12/./InRelease: Policy will reject signature within a year, see --audit for details
Warnung: OpenPGP-Signaturüberprüfung fehlgeschlagen: https://www.linuxcnc.org trixie InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on EEDD0D29F81DCAA0D258661F3CB9FD148F374FEF is not bound:            Policy rejected asymmetric algorithm   because: DSA1024 is not considered secure since 2014-02-01T00:00:00Z
Fehler: Das Depot »https://www.linuxcnc.org trixie InRelease« ist nicht signiert.
Hinweis: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
Hinweis: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
Stating that the repo is not signed.
This is my linuxcnc.list:
deb [arch=amd64,arm64 signed-by=/usr/share/keyrings/linuxcnc.gpg] https://www.linuxcnc.org/ trixie base 2.9-uspace 2.9-rt
deb-src [arch=amd64,arm64 signed-by=/usr/share/keyrings/linuxcnc.gpg] https://www.linuxcnc.org/ trixie base 2.9-uspace 2.9-rt
The key lives in /usr/share/keyrings/linuxcnc.gpg
  • endian
  • endian's Avatar
27 Sep 2025 08:53
Replied by endian on topic Beckhoff AX5YZZ internal probing
Category: EtherCAT
Thanks.... I have working configs for TC3 and it works well but if I mirror them to lcec ... probing not working at all ... I did custom component to use the internal probing but I can not use them because of I do not know ...
I have contacted all members which are more suitable to do explain me whats going on from this forum but no answers from anybody at all ...
maybe during the winter there will be more itteractions between us
  • M4MazakUser
  • M4MazakUser
27 Sep 2025 08:49 - 27 Sep 2025 08:51
Replied by M4MazakUser on topic 8i20 power supply variation.
I'm waiting for some parts to turn up, going to build a power supply- three phase rectifier and 4 large caps, the fanuc one I've been using is basically a bridge rectifier I'm not sure how good the caps are,  if I power it up it displays a fault code. It has been 2metres under floodwater (two washing machines in 'merican speak). So i don't really trust it. The issues I have are during hard acceleration from stopped, or high speed travel(rapid moves). Say I'm moving an axis 8in - 200mm, it will throw an error at around the 7in mark, this i can fix if I lower the travel speed a bit. I never lose encoder position but I geuss the mesa cards have that under control.  I would have preferred an Ethernet style card, but not much was available during covid etc. I don't believe the computer is the issue from tests I've done and the bios settings in place etc. It never shows any errors about realtime etc.
Displaying 9496 - 9510 out of 17020 results.
Time to create page: 0.558 seconds
