  • andypugh
  • andypugh's Avatar
24 Sep 2025 11:52
Replied by andypugh on topic MPG whb04b-6 starts by default in MPG Mode
Category: HAL
Are you using the "-f" flag when loading the component?
That seems to have that effect. (But it might also be the default behaviour)
  • alangibson
  • alangibson
24 Sep 2025 11:44
Replied by alangibson on topic No underspeed with temporary material
Category: Plasmac
I've just put up a YouTube video with a quick demo:
  • andypugh
  • andypugh's Avatar
24 Sep 2025 11:41
Replied by andypugh on topic Touch off, OK button greyed out
Category: AXIS
Uninstall 2.9.5
Manually download the 2.9.4 deb files using gdebi.
Or 2.9.6 which has been created to fix this specific issue, but hasn't been moved onto the repository yet (I haven't been at home long enough to do it since the debs got built).
buildbot2.highlab.com/release/debian/dists/
  • rasuran
  • rasuran
24 Sep 2025 09:54
newbie issues with mesa 5i20 and 7i36 daughtercard.
Category: Driver Boards
"Dear friend,
I am working on retrofitting a grinding machine and I have prepared the following hardware for it: Mesa 5i22-1.5 + 2x 7i36 + 7i44 + 7i70 + 7i72 + 7i73. I would kindly like to ask if it would be possible to create firmware for this combination.
Thank you very much in advance."
  • Hakan
  • Hakan
24 Sep 2025 08:49
Replied by Hakan on topic Trouble with Cia402 drive configuration
Category: EtherCAT
It's not obvious what's wrong. Forget the 0x20xx SDOs, you are not using them, they are not mentioned in ethercat-conf.xml.
Let's look at the error message in syslog
[  331.671725] EtherCAT WARNING 0-3: SDO information error response while fetching SDO entry 0x1C32:07!
[  331.671732] EtherCAT ERROR 0-3: SDO abort message 0x06090011: "Subindex does not exist".
If you look at the subindices that are listed, they agree with the documentation
(From teknic.com/files/downloads/ClearPath-EC_Software_Reference.pdf)
Some subindices ARE missing and I don't know why the EtherCAT master makes a big deal of that. If it needs that info or what?
I think the Invalid input configuration is a consequence of those errors but could be something else also.
Almost out of ideas, but there are two things you can try. Set configPDOS="false" or remove the option altogether.
If that doesn't help, increase debug level on the ethercat master to hopefully get some ideas on what's going wrong.
ethercat debug 1
for example, try to start linuxcnc and list the messages in syslog again.
Can you also show the content of sdo 0x60c2:1 and 0x60c2:2 (interpolation time) Use command
ethercat upload 0x60c2 1
Compare with table in manual.
  • Zipdodar
  • Zipdodar
24 Sep 2025 08:26
Replied by Zipdodar on topic Datron M9 to LCNC Conversion
Category: CNC Machines
Hi  thankyou for your post.  Do you have any videos of it in action?
  • rodw
  • rodw's Avatar
24 Sep 2025 07:54
Replied by rodw on topic Trouble with Cia402 drive configuration
Category: EtherCAT
Clearpath should have good docs. Typically the CIA402 registers are > 6000.
Its not a one size fits all.
  • rodw
  • rodw's Avatar
24 Sep 2025 07:50
Going from Devian 10 to 12 has created problems
There are quite a lot of optimisations required with the later kernels (Debian 12-13). I have documented them in a PDF file available here
erpx.au/shop/trixie-linuxcnc-debian-trix...tion-pdf-download-48
There is a nominal AUD $2.00 fee for this info... Sorry but it was the only way I had to store a file.
While it refers to Debian 13 Trixie, it also is applicable to Debian 12 Bookworm.
I will say that feedback from users I've received says 2 core PCs are marginal for Debian 12-13 but some have got them working with the optimisations I describe. I have never used < 4 core PC's
  • unknown
  • unknown
24 Sep 2025 05:54
Replied by unknown on topic 8i20 power supply variation.
Hahaha I look stupid, I thought "our solar system" you meant the solar system, some kind of weird google translation. Not a solar inverter as mentioned later.
You have my permission to make as much fun at my expense as you feel necessary. I honestly feel I deserve it.
Sorry if you thought I was making fun of you. Please accept my apologies.
  • M4MazakUser
  • M4MazakUser
24 Sep 2025 04:06
Replied by M4MazakUser on topic 8i20 power supply variation.
I'm thinking more it's a bad filter cap and a rough infeed from the 3phase fronius solar inverter. It does bump the voltage up.
  • unknown
  • unknown
24 Sep 2025 03:09
I'd look at a component heating issue first. Maybe just below "bad things" when it's not sunny outside, and pushed over the edge when it's sunny outside.
TBH honest the sun is huge, like really huge current thinking has it at 99.8% of the TOTAL mass of the solar system, all the planets and sundry matter make up 0.2% of the solar system (and our sun isn't all that big). And whether it's sunny or not outside it's still fusing ~600 million tonnes of Hydrogen per second into ~596 million tonnes of helium, thus fusing continues (element by element) until all that is left is iron, then we die, and being twisted by magnetic fields and the rest. So basically it's always on, doing what the sun does best fussing atoms into other atoms, generating heat and all manner of electromagnetic radiation.
I'm pretty sure if the ripple was being caused by the solar system you'd be noticing many many more items playing up.
But if you really want to check on the cosmic microwave background grab an old CRT tv, turn it on and turn to a channel that has no terrestrial signal, it'll give a reasonable idea of the radiation around. That's what a small part of the static is.
  • PCW
  • PCW's Avatar
24 Sep 2025 03:05
Replied by PCW on topic 8i20 power supply variation.
Ripple should not make too much difference, you might plot the bus voltage in halscope
to see if there's anything suspicious.
  • snowgoer540
  • snowgoer540's Avatar
24 Sep 2025 01:43
Replied by snowgoer540 on topic No underspeed with temporary material
Category: Plasmac
It should be fixed in that version:
forum.linuxcnc.org/plasmac/53657-holes-3...iour?start=20#308841
But probably you should try updating.
I will try to make some time to have a play with your CAM code.
  • M4MazakUser
  • M4MazakUser
24 Sep 2025 01:06
8i20 power supply variation. was created by M4MazakUser
After many -many many hours of having problems with random following errors in finally have found something that links.
so, when it's not sunny outside the voltage i read on the 8i20 card is 315v dc. When the sun is in full swing it reads 325v dc. This doesn't seem to relate to anything I know, but I have no errors when the sun isn't doing much,  and  plenty when it is, I'm thinking that there is probably some induced ripple from our solar system,  and the dodgy fanuc power supply im using probably has a bad cap. Any ideas ???
Displaying 9616 - 9630 out of 17018 results.
Time to create page: 0.346 seconds
