  • Murphy
  • Murphy
22 Oct 2024 19:03 - 22 Oct 2024 19:04
Will this encoder code for A and index Z be added to an update in the future?
  • Aciera
  • Aciera's Avatar
22 Oct 2024 18:37
  • Aciera
  • Aciera's Avatar
22 Oct 2024 18:15
Machine moves when you stop program in the middle
ON_ABORT_COMMAND = O <on_abort> call
could you share 'on_abort.ngc'?
  • programador
  • programador's Avatar
22 Oct 2024 18:02
How to put the 7i77 encoder in mode 1? was created by programador
Category: HAL Examples
Hello everyone, I'm already on the client's machine, I'm trying to apply part of what worked in the lab test with 7i96s and
I'm trying to do the same client configuration on the 7i77 that was done in the lab on the 7i96s. But on the 7i96s I have to put:
setp hm2_7i96s.0.encoder.00.counter-mode 1
setp hm2_7i96s.0.encoder.00.filter 0
setp hm2_7i96s.0.encoder.00.scale -1
and will read the frequency applied to ENCA+ and ENCA- of THCAD2.
However, the 7i77 does not accept this configuration. What is the procedure to make the 7i77 change the encoder to mode 1?
Does not show hm2_7i96s.0.encoder.00.velocity
How to configure the 7i77 encoder to accept frequency?
File Name: 7i96s7i84d.hal
File Size:23 KB
  • btvpimill
  • btvpimill
22 Oct 2024 17:58
I think this is all there should be. Maybe more than needed. I will try and get a movie but no promises there.
  • Grotius
  • Grotius's Avatar
22 Oct 2024 17:54
Replied by Grotius on topic c++ compiling error
c++ compiling error
Hi Bkt,
You keep on dumping the core.
Nice you have a link to your project page.
What thing should i test for you? Please one thing at a time.
  • Giovanni
  • Giovanni
22 Oct 2024 17:19
Replied by Giovanni on topic NativeCam on LinuxCNC 2.9.3
Category: NativeCAM
I think that messages here would be fine.
Regards
Giovanni
  • pagan_dan
  • pagan_dan
22 Oct 2024 17:18
Replied by pagan_dan on topic Linuxcnc for CNC-STEP HIGH Z 400
Sure, it might take a day or two though as that machine is in bits at the moment and I'm busy at the moment. I haven't used this machine much, IIRC I still had a scaling config issue, but it was otherwise working, and I did a couple of test mills.
  • Aciera
  • Aciera's Avatar
22 Oct 2024 16:52
Replied by Aciera on topic Gmoccapy - spindle restarts at program stop
Category: Gmoccapy
Does this happen in QtDragon for you as well?
22 Oct 2024 16:49
Replied by tommylight on topic Mesa 7i96s torch on/off connection
Category: Driver Boards
They are the same, look the same, the only thing missing is the "pilot" terminal in lower front.
Also, chinese specifications do not help, they are a total mess usually.
  • PCW
  • PCW's Avatar
22 Oct 2024 16:44
Replied by PCW on topic Mesa 7i96s torch on/off connection
Looks like HF start so can start in air, but brings a horror show of EMI issues.
  • freemoore
  • freemoore
22 Oct 2024 16:36
Replied by freemoore on topic NativeCam on LinuxCNC 2.9.3
Category: NativeCAM
I'd be up for trying that; I've been down another rabbit-hole for the last few days and only just saw your message. What sort of medium suits you - via messages here, or e.g. whatsapp, what suits you and when?
  • Jensner
  • Jensner
22 Oct 2024 16:33
Unexpected realtime delay on task 0 with period 1000000
Category: QtPyVCP
OK, thanks a lot.
Will try it and replay.
I'm really looking forward to the results.
The networkcable between PC and the MESA Card is about 50cm long and directly connected.
Thank you for the exact command line, that would have been the next problem again
22 Oct 2024 16:31
It is an Everlast Supercut 50 (w/o a pilot arc)
Plasma source without pilot start can not be used for cnc cutting, it can not start an arc in mid air, it has to be touched to the material to start cutting.
Does your plasma make flames in mid air without touching material when you press the trigger?
  • Plasmanfm
  • Plasmanfm
22 Oct 2024 16:27
G-Code Verarbeitung: Kurze Pausen zwischen Bewegungen - Wie beschleunigen?
Category: Deutsch
Mit einer DFX Zeichnung können die meisten Cam-Programe dieses in G-Code umsetzen wichtig ist das das Cam-Program den
Postprocesor Linucnc hat PlasmaC usw da ich mit PlasmaC arbeite
hat Sheetcam diesen Postprocesor ein bichen feintuning und es wird der G-Code wird erstellt.
Gruß
Juergen
Displaying 19516 - 19530 out of 24147 results.
Time to create page: 0.744 seconds
