17 Oct 2024 14:11
Replied by tommylight on topic Fast Hole EDM from Hacked Parts
BAXEDM sells a very nice power supply, with all bells and whistles included for interfacing with LinuxCNC, as that is what he uses for his machines.
No idea about the price, but from what i have seen on youtube, he is very reasonable and supportive.
His channel has the same name on youtube.
  • Muecke
  • Muecke's Avatar
17 Oct 2024 14:11
Replied by Muecke on topic Welche Tasten haben die Achsen?
Category: Deutsch
Kann man die Tasten auch selbst belegen?
@ tommylight
Welche genau?
17 Oct 2024 14:07
Replied by tommylight on topic Welche Tasten haben die Achsen?
Category: Deutsch
Usually last two buttons before ENTER, upper row.
17 Oct 2024 14:00
Replied by tommylight on topic Linux is an RTOS NOW
Category: Installing LinuxCNC
6.11 shows SMP PREEMPT_DYNAMIC out of the box, did not test LinuxCNC yet.
  • Phorced
  • Phorced
17 Oct 2024 13:46
Replied by Phorced on topic Linuxcnc for CNC-STEP HIGH Z 400
I know that it is now over a year ago but i am currently setting up exactly the same machine and am not getting any movement just sounds like the steppers are being provided a locking current and that is it would you be willing to provide your configuration file that i can test on my side cause i have tried all the configuration changes mentioned in this forum with no resolve.
  • myankov
  • myankov
17 Oct 2024 13:46
RF 45 homing issue was created by myankov
RF 45 homing issue
Category: Basic Configuration
Hello
It is my first time converting a mill and I am having a problem with homing sequence. I short I can't make it work.
I read this linuxcnc.org/docs/html/config/ini-homing.html  and some similar  topics  here in the forum, and after all I am more confused :).
I use same input for home and limit switch  on all axes .
You see in the where are the switches:
What I want to do is when lets say homing Z - goes to the switch trips it, returns slowly trips it again and then moves 10mm down. Ini file is attached check it and tell me what I am doing wrong.
Thank you.
  • unromeo21
  • unromeo21
17 Oct 2024 13:36
LitexCNC: firmware and driver for 5A-75B and 5A-75E
Category: Driver Boards
Any updates on the new version with shit register support ? It was anounced for 1st of March.
  • timo
  • timo
17 Oct 2024 13:12 - 17 Oct 2024 13:13
Replied by timo on topic Fast Hole EDM from Hacked Parts
"I am in desperate need of drilling some very small (.5-.8mm) holes in inconel of high aspect ratio."
Sounds like an examination question to a "make or buy" decision.
holeflix or spotdrillfy?
  • sajurcaju
  • sajurcaju
17 Oct 2024 12:51
Replied by sajurcaju on topic Has Anyone used DeskProto
Category: CAD CAM
I've used DeskProto for about a year. It works great, though I haven't gotten to trying the 4th axis yet. You are correct, you buy the software in perpetuity, with optional major updates that you get at a discount.
Try it out--start with the free version. In the free version you can choose to run the full version but it carves a logo across your piece.
For hobby use (less than some $ per year sales), the full license is $250. Commercial use is higher, I think $1000.
  • Aciera
  • Aciera's Avatar
17 Oct 2024 12:44
Replied by Aciera on topic Welche Tasten haben die Achsen?
Category: Deutsch
Ja. haste Recht. Geht nicht.
  • JT
  • JT's Avatar
17 Oct 2024 12:44
Replied by JT on topic Read HAL pin in Python
Category: Other User Interfaces
Yup it works
JT
  • Aciera
  • Aciera's Avatar
17 Oct 2024 12:31
Unterstützung bei der Automatisierung einer Simulation
Category: Deutsch
Danke, das habe ich soweit eingearbeitet.
Eine Übersetzung würde momentan mein Zeitbudget für dieses Projekt überschreiten.
  • bkt
  • bkt's Avatar
17 Oct 2024 12:12 - 17 Oct 2024 12:14
Replied by bkt on topic c++ compiling error
c++ compiling error
/usr/lib/liblinuxcnc.a(iniaxis.o):function iniAxis(int, char const*):(.text+0x6b9): error: undefined reference to 'emcAxisSetLockingJoint(int, int)'
nm /usr/lib/liblinuxcnc.a | grep emcAxisSetLockingJoint U _Z22emcAxisSetLockingJointii
nm /usr/lib/liblinuxcnc.a | grep iniAxis 0000000000000160 T _Z7iniAxisiPKc 00000000000000c8 t _Z7iniAxisiPKc.cold
these means sometings go wrong during creation of .deb packages?? or c++14 not able to find .h necessary heather?
Because iniAxis is linking to liblinuxnc.a but emcAxis..... is used as c++ code (correctly) some trouble with mixing c and c++ code? .....
  • rodw
  • rodw's Avatar
17 Oct 2024 12:09
Replied by rodw on topic Hurricane Milton
Hurricane Milton
We are all happy you got through OK and your earlier fortifications saved the day.
Since the 1980s here the building code places additional requirements on construction in tropical areas that are subject to cyclones (our name for a hurricane) Your tie downs are part of the code, but they are probably theaded rods in the wall cavities that tie the roof to the concrete slab floor and foundations.
  • Muecke
  • Muecke's Avatar
17 Oct 2024 12:08
Category: Deutsch
Auf die Gefahr hin das ihr mich für ... haltet.
Doch welche Tasten sind denn bitte [ und ] bei mir bewegt sich da nichts :-(
in der Hilfe steht es jedoch auch so drin.
Displaying 19921 - 19935 out of 24212 results.
Time to create page: 0.539 seconds
