  • RLA
  • RLA
14 Oct 2024 16:51
Replied by RLA on topic Make arc in W axis
Make arc in W axis
Hi...so one more question...I was thinking to drive 2 tools off same axis from computer...the only thing is that they have different scales..meaning one is screw...other is gear....almost 10 to 1 difference...I was thinking of using 2 different drivers with different microstepping...does not seem to work...any other workarounds?
Thanks,
Rick
  • dreBird
  • dreBird
14 Oct 2024 16:38 - 14 Oct 2024 16:39
Joint homing offset and following error - HELP
So I tried a few things but it seems the burnout is holding back progress. The burnout is when the table rapidly accelerates without command. It always burnout in the same direction regardless of table movement direction, in the X axis case its in the negative direction. When P=100, the x-offset from home is 2 thou. P=200, x-offset from home is 1 thou. P=300 burnout. So I can't get to P values that allow the machine to home to 0,0,0.
I caught a burnout on the Halscope doing a G01 F50 X1 move and you can see the following error oscillates then shoots vertically to 1 (P=300). This is where the burnout starts, and you can see the velocity command drops to 0 when the following error cuts power. Even though power is cut, the table has enough initial acceleration to move almost 2 inches. I put a Halscope of P=100 for reference (there is still a bit of oscillation, not sure if that's normal). See attached.
This browser does not support PDFs. Please download the PDF to view it: Download PDF
Any idea on what could be causing these runaway oscillations?
  • Muecke
  • Muecke's Avatar
14 Oct 2024 16:10
Age of the website and forum was created by Muecke
Category: Forum Questions
-- EN
Hello everyone,
I am aware that this is not a pleasant topic and that some things do not always work as they should. Above all, there is a lot of work behind it, and for that I would like to thank everyone who actively supports here.
However, I have noticed that a Joomla version 3.10.xx is still being used for which there is no longer any support or security updates. If I see it correctly, the forum (Kunena) is not up to date either.
Yes, moving to a new Kunena forum is tricky to almost impossible, and even upgrading Joomla to the current version 5 doesn't seem feasible without moving the forum.
Nevertheless, I wanted to address this topic without anyone feeling offended - quite the opposite. I just want to encourage a conversation about it.
I would be interested to know whether an upgrade is being considered or what the plans are for the forum in general. Because there will probably not be much support from Joomla or Kunena.
Greetings Mücke
Translated with DeepL.com (free version)
-- DE
Hallo zusammen,
ich bin mir bewusst, dass dies kein angenehmes Thema ist und dass manche Dinge nicht immer so funktionieren, wie sie sollten. Vor allem steckt viel Arbeit dahinter, und dafür möchte ich mich ausdrücklich bei allen bedanken, die hier tatkräftig unterstützen.
Allerdings ist mir aufgefallen, dass immer noch eine Joomla-Version 3.10.xx verwendet wird, für die es keinen Support und auch keine Sicherheitsupdates mehr gibt. Wenn ich es richtig sehe, ist auch das Forum (Kunena) nicht auf dem neuesten Stand.
Ja, ein Umzug auf ein neues Kunena-Forum ist heikel bis fast unmöglich, und auch ein Upgrade von Joomla auf die aktuelle Version 5 scheint ohne einen Umzug des Forums nicht realisierbar.
Trotzdem wollte ich dieses Thema ansprechen, ohne dass sich jemand angegriffen fühlen soll – ganz im Gegenteil. Ich möchte lediglich ein Gespräch darüber anregen.
Mich würde interessieren, ob ein Upgrade angedacht ist oder wie die Pläne für das Forum generell aussehen. Denn von Seiten Joomla oder Kunena wird es wohl keine große Unterstützung mehr geben.
 Gruß Mücke
  • 3dtech_ks
  • 3dtech_ks
14 Oct 2024 15:48 - 14 Oct 2024 15:48
Replied by 3dtech_ks on topic Using skr 1.4 turbo with w5500 for Linuxcnc
Im not sure yet, i know skr 1.4 uses LPC1768 , SKR 1.4 TURBO uses LPC1769 , but can i use the same config.txt for both ?
  • Todd Zuercher
  • Todd Zuercher's Avatar
14 Oct 2024 15:03
Replied by Todd Zuercher on topic New update on STMBL
New update on STMBL
Category: Driver Boards
Looks nice!
  • Muecke
  • Muecke's Avatar
14 Oct 2024 14:55
Replied by Muecke on topic Email Notification?
Email Notification?
I use G-Mail.
There is nothing from LinuxCNC in my SPAM folder :-(
I don't get notified about any of my topics, I always have to check manually.
14 Oct 2024 14:51
Replied by tommylight on topic IRQ Affinity setup
IRQ Affinity setup
rc.local would work, but not sure it is usable still on Debian, i know Mint stopped using it a while back, but it can still be made to work with a bit of fiddling.
14 Oct 2024 14:49
Replied by tommylight on topic Mesa 7i96s --USB error finishing read
Not sure if it will help much, but only connect your motor cable shield at the drive end. instead of both ends.
Sometimes it does help, a lot, although only once in my experience, the rest (probably over 10) both sides worked better.
All VFD's i have used have separate ground pins for mains and for motor, probably have some LC filter inside but i never checked, waiting for one of those to die so i can open it. :)
Another thing i noticed with a cheap 2.2KW HY-whatever VFD was that grounding the motor wires on both sides would make it possible to use it without mains grounding at all, hence the above assumption on LC filtering.
  • royka
  • royka
14 Oct 2024 14:46
Replied by royka on topic IRQ Affinity setup
IRQ Affinity setup
Otherwise in /etc/rc.local above "exit 0": sleep 10 && echo .....
Or "sudo crontab -e": @reboot sleep 10 && echo ......
The sleep is necessary with the orange pi at least.
  • Todd Zuercher
14 Oct 2024 14:39
Replied by Todd Zuercher on topic Mesa 7i96s --USB error finishing read
  • Freak
  • Freak
14 Oct 2024 14:19
Replied by Freak on topic New update on STMBL
New update on STMBL
Here some pic assembled with the case.
Much more space in the cabinet now
  • stonebite
  • stonebite
14 Oct 2024 14:18
Replied by stonebite on topic Einbindung externer Komponenten in der HAL Datei
Category: Deutsch
ok, probieren wir aus
besten Dank, herzliche Grüsse
Claude
  • PCW
  • PCW's Avatar
14 Oct 2024 13:43
Category: Deutsch
 Um einen NPN-Sensor mit einem 7I76-Eingang zu verwenden,
ist ein Pullup-Widerstand erforderlich
(schlagen Sie 1K 1W von +24V zum Sensorausgang vor)
Displaying 20101 - 20115 out of 24270 results.
Time to create page: 0.560 seconds
