  • Moutomation
  • Moutomation
28 Aug 2024 05:03 - 28 Aug 2024 05:04
Replied by Moutomation on topic İnstall glade
İnstall glade
Category: Gmoccapy
  • Moutomation
  • Moutomation
28 Aug 2024 04:51 - 28 Aug 2024 04:55
İnstall glade
Category: Gmoccapy
Since I deleted the configuration I do not use, it cannot find that configuration. How can I run the configuration I actually use with linuxcnc -l?
It's looking for sim.gmoccapy, my configuration name is bluecad
  • Moutomation
  • Moutomation
28 Aug 2024 04:48
İnstall glade
Category: Gmoccapy
I created the above configuration just to see the embedded pages, but now I have deleted it and when I run the linuxcnc -l command, it says that it cannot find my actual configuration.
  • Moutomation
  • Moutomation
28 Aug 2024 04:40 - 28 Aug 2024 04:43
İnstall glade
Category: Gmoccapy
Hello,
sorry this is not this there are 2 configurations
  • panming
  • panming
28 Aug 2024 03:24
How to compile the RT kernel of a ARM board?
I tried apt install, but nothing changed after the reboot , the kernel is still the same.
And the compiled kernel can't be turned on after being flashed in via a USB cable.
I've returned the board. ARM is an architecture that makes me sad.
  • Desertboy
  • Desertboy
28 Aug 2024 03:11 - 31 Aug 2024 10:29
Looking for a Linuxcnc guru to help install/upgrade machine paid
Category: User Exchange
Hi
Could you drop me an email please
Edit: email removed to protect user
I'm not about 50 miles I think I come past Cambridge to get to Stanstead
  • rickjmain
  • rickjmain
28 Aug 2024 02:57
Replied by rickjmain on topic Duplicate settings in Pref File
Category: Gmoccapy
I'm having the same problem as well. The system _name values get entered twice. The file change happens on exit, if I've edited my offests or done a tool change.
Using gmoccapy, dark theme. I have a glade vcp panel that handles air/mist/dust collection
  • PCW
  • PCW's Avatar
28 Aug 2024 00:57
newbie issues with mesa 5i20 and 7i36 daughtercard.
Category: Driver Boards
5I20 configuration for 1 7I36 on P4
File Name: 5i20_7i36x1d.zip
File Size:132 KB
Sorry it took so long, needed to update the older 5I20 source
to support the new inmux module
  • snowgoer540
  • snowgoer540's Avatar
27 Aug 2024 23:46
Replied by snowgoer540 on topic #<holes> = 3 - Unexpected behaviour
Category: Plasmac
I should caveat that the buildbot has been down, I think this change was built before it broke. But I’m sure this is the issue nonetheless.
  • acondit
  • acondit
27 Aug 2024 23:38 - 28 Aug 2024 00:53
Replied by acondit on topic Converting a 7i76e config to 7c81/7i76 pair
I updated my amd64 from linuxcnc 2.9.0pre to 2.9.2. (same thing I’m running on my rpi4). Then I ran pncconf on the 5i25 config. Interestingly linuxcnc would not run until I commented out the first few “[HMOT](Card0).7i76…” lines.
I’ll try editing the config again with pncconf to be sure it is not just some dumb mistake on my part.
Try turning on the cnc power dummy!!!
  • Evgeny
  • Evgeny
27 Aug 2024 21:56
Replied by Evgeny on topic Marco Reps video on youtube about EtherCAT
Category: EtherCAT
From your pictures of the drives I would also recommend you go and look at the correct installation/wiring recommendations in the manual before you damage one of the drives. (Space around the drive, and not daisy chaining the wiring like you have). I get it is a test setup... so might be changed in the future.
Oh my friend, I know how to install servo amplifiers, this is just a test configuration that lies on the bed. Then I will assemble everything as it should be according to all the rules.
It appears you have issues with the lcec_conf module?
I changed the ethercat-conf.xml file, it didn't work
I don't understand why after turning on my servo amplifiers they have a different indication than Marco Reps
Indication of my amplifiers
they are all determined
Here are the configuration files that are there now
File Name: linuxcnc_l...27-3.zip
File Size:25 KB
www.leadshine.com/upfiles/downloads/80d2...d8_1687682456724.pdf
  • cmorley
  • cmorley
27 Aug 2024 21:27
Replied by cmorley on topic QTDragon spindle raise issues
Category: Qtvcp
So from memory I made that pause_pin.py modification because qtdragon_hd had no external way to pause the program.
In master at least there now is an external pin for pausing, so you might not need that part.
I see you have a bit for running a oword sub on abort - you'll still need that.
So please confirm you are using current master.
If so you will probably see two external pins qtdragon.external-pause and qtdragon.external-pause-2 is that true?
if so you should not need line 46.
finally you could try commenting out the halui pause/resume lines temparaily.
  • rodw
  • rodw's Avatar
27 Aug 2024 21:22
Replied by rodw on topic problem with running ethercat
Category: EtherCAT
Seems like you are running a python virtual environment. Not sure that is an issue, but Try after exiting it.
  • rodw
  • rodw's Avatar
27 Aug 2024 21:15
Replied by rodw on topic Inssues Arc Start
Inssues Arc Start
Category: Plasmac
What plasma cutter?
How are you getting an ArcOK signal? From the plasma cutter?
It could be oxidisation of the relay contacts.
  • jmelson
  • jmelson
27 Aug 2024 21:13
Replied by jmelson on topic MCG Server Controller for 4th axis
The Leadshine DCS810 is a brush-motor servo drive, essentially similar to the MCG servo amp you already have. It ALSO needs a controller, which it is NOT.
What I THINK you are trying to do is create a standalone positioning control for the rotary table. Is that right? Or, do you want to integrate the rotary table into some other CNC system?
If you have some system that produces step/direction pulses, then you need a step to servo drive. Assuming the motor is indeed a brush motor, then the Gecko 320X is likely the best way to go.
Jon
Displaying 22321 - 22335 out of 24898 results.
Time to create page: 0.730 seconds
