  • rodw
  • rodw's Avatar
28 Jul 2024 18:31
Replied by rodw on topic big 5axis mazak horizontal cnc mill
Category: Show Your Stuff
I might go to pci mesa though 5i25T as that way I can keep the Ethernet for internet
Grabbing another network card locally might be easier
  • rodw
  • rodw's Avatar
28 Jul 2024 18:29
How to make Linuxcnc open with the feed and override 0?
Note to self: Never mention that my own machines are still running 2.8.0~pre
Noted
  • rodw
  • rodw's Avatar
28 Jul 2024 18:27
Replied by rodw on topic Latency Test OK, dennoch Fehlermeldung
Category: Deutsch
The RTL8111 is guaranteed to cause latency issues.
Please follow my guide (Sorry written in English)
docs.google.com/document/d/1jeV_4VKzVmOI...diY/edit?usp=sharing
  • rodw
  • rodw's Avatar
28 Jul 2024 18:14
Ethercat installation from repositories - how to step by step
Category: EtherCAT
There appears to be something broken at ethercat themselves.
I have raised an issue with them
gitlab.com/etherlab.org/ethercat/-/issues/131
  • andypugh
  • andypugh's Avatar
28 Jul 2024 18:07
Replied by andypugh on topic Error in tool_offsetview.py
Category: Qtvcp
Do you have a remap that uses M70?
  • andypugh
  • andypugh's Avatar
28 Jul 2024 18:06
Something strange in the config on my lathe (I think it's an old driver for one of the boards that counts MPG pulses) does this to me sometimes. I don't like it.
Maybe I should use your idea to set them to 100% instead,
  • andypugh
  • andypugh's Avatar
28 Jul 2024 18:02
  • andypugh
  • andypugh's Avatar
28 Jul 2024 18:01
Replied by andypugh on topic big 5axis mazak horizontal cnc mill
I think that tilted workplanes are, at best, a workaround for not being able to define arcs in arbitrary space.
My preferred solution is to allow arcs in arbitrary space, but as far as I know nobody is working on this at the moment.
There was some work done a long time ago, but it has been abandoned (and I didn't like the approach taken anyway)
I drawback with both approaches is that most CAM systems simply don't use them. They jist make little straigh-line moves.
  • chernogorsky
  • chernogorsky
28 Jul 2024 17:54
Replied by chernogorsky on topic Work with probe
Work with probe
Category: Basic Configuration
Ok, it have some Z issue
so the flow is
1. do probe_tool_with_toolsetter
1.1 touch TS
1.2 go back Z_CLEARANCE (Z = *0 + Z_CLEARANCE)
2. perform XMinus
2.1 Go to X+ # move X - edge_length- xy_clearance
2.2 Go down with z_clearance_down (Z = Z - Z_CLEARANCE == *0)
2.3 Perform probe('xplus')
on 2.3 I have an issue, since its try to locate the edge of the TS with Z = top_of_TS == *0
  • cakeslob
  • cakeslob
  • rodw
  • rodw's Avatar
28 Jul 2024 17:18
Category: EtherCAT
  • rdtsc
  • rdtsc's Avatar
28 Jul 2024 17:06
Replied by rdtsc on topic I can no longer access a Linuxcnc page
Category: LinuxCNC Documents
Wasn't there some recent issue with the docs build system and the French language specifically?  Perhaps the two issues are related.
  • kmeld
  • kmeld
28 Jul 2024 16:56
Replied by kmeld on topic Subrouting Path - no effect
Category: AXIS
Ok, I do not know what exactly solved the problem but I have it working now.
I have changes SUB path not to be sub-directory of main program folder
I have set up SUB path in DISPLAY and in RS274NGC sections of INI file.
Now subroutines are properly read from intended directory.
Cris
  • AndriySM
  • AndriySM
28 Jul 2024 16:20
Category: EtherCAT
Yes, the PC has an internet connection, running the sudo apt update command, which I did before, gives me this error
Displaying 24406 - 24420 out of 25070 results.
Time to create page: 0.421 seconds
