  • ANGELOS13
  • ANGELOS13
05 Jul 2025 02:51
Replied by ANGELOS13 on topic 7i92M very weird communication problem!!!
Category: Installing LinuxCNC
I reinstalled the ethernet drivers and got it down to 12ms so got it working for now, all tho at slow speeds. I order a faster mini computer so I hope that gets fixed, I installed a 7i76u daughter card, I flashed the bin file and nothing again the CR3 led is yellow and CR6 led is red. I installed the 7i92 with 7i76 bin file.
  • cakeslob
  • cakeslob
  • phino
  • phino
05 Jul 2025 01:20
Using Mesa 7i95T for laser + galvo (xy2-100) control
Category: Driver Boards
Thanks for the warning. What or where is the issue with raster galvo laser support? I'm still learning about linuxcnc and the mesa hardware and understanding how to implement the relevant capabilities.
This project involves only vector laser cutting or sweeping some areas with the galvos, not raster etching of images or text etc. In the future though of course it would be good to have both vector and raster capabilities.
  • suraj9735
  • suraj9735's Avatar
05 Jul 2025 01:01 - 05 Jul 2025 01:03
Adding external switch for emergency stop and feed override
Category: Basic Configuration
Dear LinuxCNC User,
I have bare minimum code of .ini and .hal file that perfectly working for single axis linear stage. Now, I want to add two switches one for emergency stop and another for feed override. I am planning to use pin 0 for emergency stop and pin 1 for feed override of Mesa 7i95 board.
Kindly provide the necessary pieces of code that need to be added in .hal and .ini file. explain the logic of the connection because I am not an expert of editing the .hal file.
The wiring I am planning for these switches are following..
either 0 or 5 volt to pin 1 using external DC power supply (I don't have switch currently but will buy it soon)
Continuous Analog voltage from 0-5 volt at pin 2 using another DC Power supply
GND, 0 volt at pin 3, because it is common ground for pin 0 and pin 1.
I am using linuxcnc 2.9.2
Thanks.
  • kworm
  • kworm
05 Jul 2025 00:34 - 05 Jul 2025 01:17
Replied by kworm on topic Servo Driver Plasma Retrofit
Category: Plasmac
Thanks Tommy. The attached files will support the 7i97t.  I created a config successfully but I don't have a card to test with so maybe the OP or someone can give it a try and let me know if it works.  I can send in a pull request if it's good.   This will only work with 2.10 master.
After updating to latest master just copy the attached private_data.py file to /usr/lib/python3/dist-packages/pncconf/ and the pncconf.py to /usr/bin/pncconf
I would suggest making a backup copies of the original files first just in case.
  • PCW
  • PCW's Avatar
04 Jul 2025 23:47
Replied by PCW on topic Mesa 7i96s / Network no longer working
Yes, Mesa can repair these cards
if they out of warranty, there is a nominal
change for chip replacement, usually $35.00
If these are not is the US, its probably cheaper
to repair locally due to shipping costs.
  • heffamonster
  • heffamonster
04 Jul 2025 23:37
Replied by heffamonster on topic Mesa 7i96s / Network no longer working
My bad. I had a brain fart. It is working in the dn, up position. I guess i lied, the thing that changed was the jumper postion. It slipped my mind i was messing with it. I guess thats what i get for messing with things late at night. I forgot i messed with it. This site is amazing. Most problems with these boards are user initiated. My question still stands; is it possible to get these boards service if something does go wrong with them? Not that i need it now but knowing the user (me) I am sure i will mess thing up at some point and need it serviced. I am just going to quit messing with things.
  • Hakan
  • Hakan
04 Jul 2025 23:37
Replied by Hakan on topic HY_VFD RS-485 HAL config
Maybe you can find something in this old thread www.forum.linuxcnc.org/24-hal-components...b485-to-huanyang-vfd
at least to make sure the communication works.
It was a long time ago this so I doubt I can answer any questions.
  • jmelson
  • jmelson
04 Jul 2025 23:27
looking for advice on retrofitting hydrolic mill
Are the axes moved by hydraulic motors or cylinders? Or, are there electric motors for the axes? Is it really an NC mill, or is that Ljumo just a digital readout?
Driving a machine with proportional hydraulic valves requires "dither" to be added to keep the valve freely floating.
  • Murphy
  • Murphy
04 Jul 2025 23:25
I'm not to sure what you mean by the cloud ? You have to change the address to 10.10.10.10. once changed, ping the address and see do you get a response (and how long it took).
  • PCW
  • PCW's Avatar
04 Jul 2025 22:56 - 04 Jul 2025 23:00
All the green led's light up
Are you saying the 4 green user LEDs all light when you start LinuxCNC?
That suggest communications are working
What does
ip a
report?
And what are the RJ45 LED states when the Ethernet is connected
and when not connected?
 The
red light just continues to blink with the jumper in the up, up position and none of the green leds
with light in the fallback mode. Ping is unreachable in up, dn and and in up, up.
Note that UP,UP is fallback at 192.168.1.121 and UP,DOWN is BootP
(DOWN,UP would normally be 10.10.10.10)
04 Jul 2025 22:51
Replied by tommylight on topic Servo Driver Plasma Retrofit
Category: Plasmac
No idea if this helps KWorm, but 7i97T (not aware of 7i97S) is the same functionally as 7i92 with 7i77, probably some IO pin names are different.
  • Sternfox
  • Sternfox
04 Jul 2025 22:49
Replied by Sternfox on topic poor surface quality
Hi tommy. They are ac servos all connected to the same 240v supply. Would the tuning be done via lunuxcnc or on the servo amp? They are step and direction drives. Thanks
04 Jul 2025 22:48
Replied by tommylight on topic Tool Change
Tool Change
Category: Configuration Tools
Have a look at carousel component included with LinuxCNC:
linuxcnc.org/docs/html/man/man9/carousel.9.html
And posts on this forum regarding it
www.google.com/search?q=carousel+site%3A...sclient=gws-wiz-serp
Also, there was similar functioning system on those small lathes, forgot their name, but there are plenty here...
  • Sternfox
  • Sternfox
04 Jul 2025 22:47
I will take the covers off and give this a try. Thanks man.
Displaying 406 - 420 out of 25375 results.
Time to create page: 0.205 seconds
