  • rodw
  • rodw's Avatar
08 Nov 2025 06:36
Replied by rodw on topic USB activity causes network error
Category: Plasmac
Try this command and review results when complete
sudo chrt 99 ping -i .001 -c 600000 -q 10.10.10.10
The max reading is usually the first entry as it connects so look at average and standard deviation.
  • rodw
  • rodw's Avatar
08 Nov 2025 06:17
Help with Wireless Handwheel XHC-WHB04B-6 (wrong Product ID)
@Rod,
We can not edit your youtube videos on your youtube studio! :)
how is the html code for grin?
That's quite an old video now. There are more reasons  in 2.10  to grin :)
In  2.10 there is a change to how Deb files are built by doing it the Debian way which installs all the dependencies for you. It is described in the building linuxcnc docs for 2.10. I do remember testing it prerelease and it was sooo simple,,, except for building the docs.
  • hanz24
  • hanz24
08 Nov 2025 06:09
problem with homing was created by hanz24
problem with homing
Category: Basic Configuration
I have a problem with homing in the lcnc sim. First, i jog the axis xz and then try to home all axis, and it's works. But when i try to do that again, its only homing for the x axis, and z axis didn't go to the home coordinate. Already check the ini file and it's all same with x and z axis, what can i do to solve this.
And i also want to try to jog a-axis with external push button, is this hal configuration enough to do that
setp halui.axis.a.jog-speed 100
net jog-a-plus-raw debounce.0.0.in <= hm2_7i98.0.gpio.001.in_not
net jog-a-plus debounce.0.0.out => halui.axis.a.plus
net jog-a-minus-raw debounce.0.1.in <= hm2_7i98.0.gpio.005.in_not
net jog-a-minus debounce.0.1.out => halui.axis.a.minus
  • rodw
  • rodw's Avatar
08 Nov 2025 06:07
MonoKrom - QtPyVCP GUI for PlasmaC and Mill
Category: QtPyVCP
there should be a specific post processor for Plasmac shipped with Sheetcam (before QTplasmac) Try it and read the file as there are notes at the top.
@Tommy, line numbers in linuxcnc are optional and Sheetcam has settings to generate with and without.
  • rodw
  • rodw's Avatar
08 Nov 2025 06:02
Replied by rodw on topic New and Working RTAI debs for 2.9
Category: Installing LinuxCNC
If you use 2.10, there are some changes to make it easier by doing it the Debian way (to a Deb file). The Debian way installs all the required dependencies so check the 2.10 Docs. Otherwise there is a how to video on my MrRodW YouTube channel
  • frayja2002
  • frayja2002
08 Nov 2025 02:51
USB pendant stops working after using macros
Category: Qtvcp
Hi all
I have a dragon rise USB board (pendant) attached to one of my machines. When I first home the machine all of the buttons work as expected (IE I can jog the machine around)
After I press one of the macro buttons on the screen ( Switched Home or Work Zero) the USB pendant stops working.
I'm guessing that the macros are not exiting properly but I can find no errors.
I am running debian 3.10 with LinuxCNC 2.9.4
I'm hoping someone can give me some pointers on this.
Alex
08 Nov 2025 02:39
Replied by tommylight on topic Dual X Axis Control
Dual X Axis Control
1. see below
2. yes
3. yes
About 1, it would be much better to have some pictures to be able to answer exactly, but in general, LinuxCNC is very flexible and quite easy to make it do pretty much everything within reason.
I am sure Todd has a machine with 4 of Z axis, just not sure if independent, but again sure it should be possible.
If you wander a bit through the "show your stuff" section of the forum, pretty quickly you can find all types of machines controlled by it, personally i have from small "scratcher" machines for pictures on granite/stone/glass to huge industrial machines (plasma, mills, lathes) and some welding robots and small dental 4 axis clear aligner cutter.
Plenty of pictures and videos there.
  • COFHAL
  • COFHAL
08 Nov 2025 01:46
Replied by COFHAL on topic Rotary axis Display
Rotary axis Display
08 Nov 2025 00:44
Can I use these little 3d printer drivers with 7i96?
Category: Driver Boards
T470 with FHD 120Hz touchscreen
Y370 laptop/tablet/pen/FHD 120Hz touchscreen
X1 Yoga gen1 laptop/tablet/FHD 120Hz touchscreen
Plain ol X240 seems OK also, had 2, still have one in active use
Notice the touchscreen and VSync frequency, those are very important as they are top of that line, meaning other versions might or might not be good latency vise.
The link i posted above has all the info and videos of them in use plasma cutting, so no interference issues with touchscreen.
  • seuchato
  • seuchato
08 Nov 2025 00:30 - 08 Nov 2025 00:31
"old Lenovo laptops at 100-200 Euro a piece"
Tommy,
could you kindly name a few of them?
I could test a T440p, T460p for example.
Greez
chris
PS: these do NOT have touch screens, though
  • PCW
  • PCW's Avatar
07 Nov 2025 23:15
Replied by PCW on topic Bricked Mesa 7i92T
Bricked Mesa 7i92T
I don't think so, those appear to have analog sinusoidal outputs so
require an interpolator (that is, they are not standard quadrature encoders)
  • FPVUALAB
  • FPVUALAB
07 Nov 2025 22:38
Replied by FPVUALAB on topic Bricked Mesa 7i92T
Bricked Mesa 7i92T
Please tell me, can I use encoders from the Mitutoyo AT111-100F або AT111-200S series?
  • MarkoPolo
  • MarkoPolo
07 Nov 2025 21:56
Replied by MarkoPolo on topic Rotary axis Display
Rotary axis Display
Try it out.This should draw the tool, detect your machine's workspace, and correctly map the A-axis rotation.Copy the entire directory to "/usr/share/qtvcp/panels" and run "qtvcp machine-test"
  • kale hater
  • kale hater
07 Nov 2025 21:53 - 07 Nov 2025 22:25
Replied by kale hater on topic Plasma Tube Cutter with only 2-Axis on QTPlasmaC
Category: Show Your Stuff
DANNNNGGGGGGG. This is so impresive. The arc cuts are actually so clean. Wish I had something like this in my FSAE group.
  • Quail
  • Quail's Avatar
07 Nov 2025 21:41
Thanks for being a good sport haha.
Yeah we had to do some tricky stuff and use the m64 and m65 commands for torch on and off in the g-code. Also had to manually add in the pauses before and after cutting to ensure a good arc and full cut had been made.
There's some other odd stuff going on in the background too. The machine thinks the rotary axis is linear and 1 inch of travel is actually 1 rotation. We made a post processor for sheetcam that scales any unwrapped tube profile to be within 1inch as well to correspond to the 1 revolution needed. Lots of strange stuff happening lol.
Displaying 11326 - 11340 out of 12803 results.
Time to create page: 2.181 seconds
