19 Apr 2025 21:28
Replied by tommylight on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
If the power supply can do over 2A of current, yes you can use the same supply.
And no, that 2A is not related at all to the 2A written on the drive.
  • notJamesLee
  • notJamesLee
19 Apr 2025 21:12
Replied by notJamesLee on topic Determining Angular Scale - Help w/ Microsteps
Category: Configuration Tools
Hi Friends,
catching up on replies now, i was out traveling for work the last few days. Here are the links to the motor and driver i am using.
Motor
Driver
Ill try to reply to everyone in this one reply to avoid any confusion, and ill to to work backwards as much as possible.
@Langdons
 - Does speed make a difference?
No it doesn't seem like it. The Arduino code i am running does  a slow loop and a fast loop changing the delay int between steps and its been consistent every time. Although i haven't cranked the speed up and don't plan on it.
@andypugh
- you are correct, i am trying to understand the most optimal way to get this into Lcnc and based on previous posts I can maybe modify the drivers software to make that a whole number. Still investigating this though.
@timo
- I have and it works as expected and repeatably. The issues comes up when i put it into the pulley system, with the reduction i can't hone in a precise step/rev, from which i can derive the steps/deg for a rotary axis in LCNC.
- in regard to the pulleys, I am certain the motor pulley isn't (the ole sharpie method) the idler doesn't count, and no am im not 100% certain that the drive shaft is fixed in place, however with everything powered down i can turn the drive shaft and it turns the motor pulley. that on top of the low speeds and it being uploaded gives me a decent amount of confidence in my answer.
- I also haven't even begun to tackle any of the encoder/ pid error stuff because when i tried initially i discovered this the issue we're dealing with now, that comes next once i have this setup pretty good.
@spumco
- This is my plan. I have the cable and am able to get it to talk to my PC, the issue is once i get it its all french to me. How would i verify the 4:1 encoder resolution? Should the drive be connected to the motor when i do this? I am going to spend the next few hours messing with it on the software side and ill report back what i learn or how i mess up.
Thank you all again,
  • DarkPhoinix
  • DarkPhoinix
19 Apr 2025 21:09
Replied by DarkPhoinix on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Driver:TB6560 JP-1635A
Steper:  57hdd0401
In your opinion is it safe to connect this driver and stepper?
Can I use the same 24V power supply that I use to power NVEM or is it better to use a separate one?
I only need it to test the jjdege conf (if I'm not mistaken it's the same conf as mine then it will tell me nvem-rt1052.txt)
to check the outputs.
I will never use this driver-stepper as a final solution.
  • meister
  • meister
19 Apr 2025 21:03
rio can now can :)
odrive(modded) via can-bus in an icebreaker board with rio:
  • rodw
  • rodw's Avatar
19 Apr 2025 20:38
Replied by rodw on topic Custom interface board questions
You won't need to develop a driver, you just need to write an xml file.
the wiring is substantially reduced using Ethercat drives over mesa.
Do you really need an encoder? The only purpose I can see is rigid tapping but thread milling is more efficient and it does not require it.
Everything about Ethercat is more expensive but it is the emerging standard. It does add a bit of complexity to the config. The bit that is not really worked out is the internal drive homing but using Linuxcnc homing is just as simple as mesa. I've had good luck finding reasonably priced Beckhof modules on ebay (including encoders) but some are outrageously priced, more expensive than new modules.
Ethercat with rs485 controlled VFD is the simplest way to run your spindle but there is now a linuxcnc driver for Omron mx2 VFD's .
  • RobotMatic
  • RobotMatic's Avatar
19 Apr 2025 20:30
Replied by RobotMatic on topic MPG " la conexion mas simple !! "
Category: Español
File Name: jog_ui_29.hal
File Size:2 KB
Para la version actual de linuxcnc2.9x ,el archivo  jog_ui.hal que mensiono en el inicio de este hilo necesita una actualizacion.
Adjunto aqui arriba el archivo jog_ui_29.hal donde esta implementado el mismo funcionamiento con axisui.
  • rodw
  • rodw's Avatar
19 Apr 2025 20:07
Replied by rodw on topic Should I switch from AXIS to QtDragon?
Category: Qtvcp
its just all round better if you have a 1080p rouch screen, plus it adds probing and too handling if you have repeatable tooling.
it is very well documented
  • Cynas
  • Cynas
19 Apr 2025 18:25
Replied by Cynas on topic NativeCam on LinuxCNC 2.9.3
Category: NativeCAM
Thank you all for your time for NativeCam,
Does the configuration for the lathe work?
Milling machine and plasma work without any problems, unfortunately configuration but lathe does not start
Thank you for your help
  • pgf
  • pgf
19 Apr 2025 18:14
Replied by pgf on topic Rotating the g54 coordinate system.
Sorry -- I missed this reply earlier. No, nothing specific. But the machine (and the axis preview) seem to do the right thing.
  • PCW
  • PCW's Avatar
19 Apr 2025 17:56
After homing X and Y, can I auto move to a non 0,0 location?
Also make sure you read this entire document:
linuxcnc.org/docs/html/config/ini-homing.html#_home
It seems like HOME is the INI variable you need to change.
19 Apr 2025 17:49
That drive and board require Quadrature outputs, LinuxCNC can do that easily, but i have no idea if Remora can do that.
There are 9 or 10 stepgen types that LinuxCNC can do, and probably 3 of those should work.
And just to be clear that "drive" is not a drive, it is an array of Darlington transistors that can handle 500mAh, if i recall correctly.
Apparently there are 15 types now, just checked so i need to update myself from 2008! :)
linuxcnc.org/docs/html/man/man9/stepgen.9.html
  • DarkPhoinix
  • DarkPhoinix
19 Apr 2025 17:37 - 19 Apr 2025 17:41
"Thread": "Base",
"Type": "Stepgen",
"Comment": "Z - Joint 2 step generator",
"Joint Number": 2,
"Step Pin": "P1_18",
"Direction Pin": "P1_25"
"Thread": "Base",
"Type": "Stepgen",
"Comment": "A - Joint 3 step generator",
"Joint Number": 3,
"Step Pin": "P1_27",
"Direction Pin": "P1_21"
I have the same configuration loaded for my Z and A they are different
  • spumco
  • spumco
19 Apr 2025 17:26
Post your INI file please and we'll see what needs editing.
And yes, homing is a never-ending struggle for LCNC users - both new and old-but-rusty.
  • Millimetergott
  • Millimetergott
19 Apr 2025 17:17
Replied by Millimetergott on topic Marco Reps video on youtube about EtherCAT
Category: EtherCAT
Hello, I managed to install the homecomp independently, and Linux CNC also started. The servos are also enabled according to Linux CNC, but they don't go into op mode, only preop mode. When I try to jog manually, a lag error immediately occurs. What's wrong? I'm using Stepperonline A6 motors, but they're the same as the EL8, just with a different name.
  • Hakan
  • Hakan
19 Apr 2025 17:16
First time to try build my xml for not listed ethercat in-out component
Category: EtherCAT
Run the "lcec_configgen" command and put the output in a file.
It will have all the pdos, but you can just delete all except the ones you need. So you need to figure out which PDOs you need to use.
It will also have all the numbers etc in the right places, so if you are lucky it can work.
At least use it as starting point.
Displaying 16291 - 16305 out of 17615 results.
Time to create page: 0.545 seconds
