  • andypugh
  • andypugh's Avatar
15 Apr 2025 12:37
Replied by andypugh on topic ChatGPT LinuxCNC Assistent
Category: Configuration Tools
The URL posted to the mailing list was
chat.openai.com/g/g-vfeQnX43z-linuxcnc-assistant
but I can't check that from work as they are worried I will ask questions that leak data.
  • mariusl
  • mariusl's Avatar
15 Apr 2025 12:35
Replied by mariusl on topic Problem with THC
Problem with THC
Category: Plasmac
Thanks Rod, I found it there eventually.
  • andypugh
  • andypugh's Avatar
15 Apr 2025 12:30
Replied by andypugh on topic Linux conversion for MDX540???
Have you seen the previous threads on converting this machine?
forum.linuxcnc.org/38-general-linuxcnc-q...dx540-rebuild#253265
  • andypugh
  • andypugh's Avatar
15 Apr 2025 12:23
Replied by andypugh on topic Retrofitting my Fadal VMC15 to LinuxCNC w/MESA
Category: Milling Machines
If your drives use resolvers than your Mesa card choice is pretty simple, it has to be the 7i49 .
That card needs a 50-pin header FPGA card. I would suggest the 6i24 if your PC has PCIe. The 6i24 can be mounted at the end of a PCIe extension cable if that makes things easier (my own mill does this)
Or, if you prefer an Ethernet connected FPGA card, then perhaps the 7i93 would work (but check with Mesa)
  • andypugh
  • andypugh's Avatar
15 Apr 2025 12:05
Replied by andypugh on topic Remap M6 in python
Remap M6 in python
It looks like your remap "magic" in in the "remap_m6.py" file.
Can you attach that too?
  • Grotius
  • Grotius's Avatar
15 Apr 2025 12:04
Replied by Grotius on topic LinuxCNC S-Curve Accelerations
the latency debian 13 is very bad.
We have to come up with an idea to
solve this.
  • andypugh
  • andypugh's Avatar
15 Apr 2025 11:58
Replied by andypugh on topic ENCODER_RATIO function implementation.
Yes, mainly the UI does the gear size / depth calculations and gives you a span measurement to run a quick test that the tooth depth is correct.
It could be more aesthetic:
  • andypugh
  • andypugh's Avatar
15 Apr 2025 11:53
Replied by andypugh on topic Engraving Fonts
Engraving Fonts
Where did you find engraver-1.py ? It doesn't seem to appear in this thread....
  • andypugh
  • andypugh's Avatar
15 Apr 2025 11:48
External comp driver for custom hostmot2 module
Category: HAL
I think that using HAL to read the multiplexed inputs is likely to be the easier solution.
But, yes, you probably _could_ create a custom component that uses the hotmot2 raw interface to read register values directly and interpret those into HAL pins.
linuxcnc.org/docs/stable/html/man/man9/h...t2.9.html#Raw%20Mode
In fact, if it is a single address that needs to be read, it might be possible to do it all in HAL, by "setp" the register address to read from, and using "bitwise" on the read data to toggle individual HAL pins.
  • spumco
  • spumco
15 Apr 2025 11:42
Need help making rotary axis behave like second spindle
Not sure 'cutting edge' is the right term, but I understand if you're not interested in something slightly experimental.  You can always have a go at caxis.comp later.
As far as creating a second configuration goes, there are (at least) a couple ways.
First, you can simply make a copy of your current config and then hand-edit the INI and HAL files.  But you mentioned that HAL isn't clicking for you, so that may be a bit of a stretch.
Second method would be to use Mesact to create a new configuration from scratch, but this time you tell Mesact that your spindle is a step & direction type.  I think you've got the 4th axis connected to stepgen.04 and are using a 6:1 belt ratio, yes?  Include those values in the new config via Mesact, along with an appropriate max speed and estimated max accel for the 4th axis.
Leave out the 'real' spindle settings, and put everything else (axes & IO) the same as your existing config and then see what Mesact comes up with.
That should give you new INI and HAL files which you can use to create a merged/blended configuration that has both spindles and no 4th axis.
I find that using VSCode makes things easy to read/edit (there's a LCNC/HAL file plugin).  I'd set up all three HAL files across two monitors and look at the differences.  Things to look out for:
  • Dont forget to comment out or delete the A-axis/joint 3 section
  • The new spindle needs all pins to be named 'spindle.1.nnn', and the signal names need to be 'spindle1-vel-cmd-nnn' (or similar).
INI file must be edited, too, especially these:
[DISPLAY]
GEOMETRY = xyz
[KINS]
KINEMATICS = trivkins coordinates=XYZ
JOINTS = 3
[TRAJ]
COORDINATES = XYZ
SPINDLES=2
[AXIS_A] - remove this entire section
[JOINT_3] - remove this entire section
[SPINDLE_1]
(put the 4th axis spindle stuff here)
Have a go and see what you come up with.  Assuming it doesn't work - these things are rarely perfect the first time - and you get an error trying to start LCNC, make sure to screen capture the error and report back here.
  • Miller Turner
  • Miller Turner
15 Apr 2025 11:35 - 15 Apr 2025 12:06
Replied by Miller Turner on topic Retrofitting my Fadal VMC15 to LinuxCNC w/MESA
Thanks for your reply.
The XYZ servo drives seem to use +/- 10V analog signal to control the DC motors.
The resolvers are the default Fadal resolvers.
For the VFD I don't know as I'm looking for a new VFD to replace the current Baldor VFD. I did see people succesfully replacing the Baldor either by Yaskawa GA500, Yaskawa V1000 or Hitachi WJ200 VFD.
Can the 7i97T output +/-10V signals and take the input of the resolvers?
Oh and a generic question: can someone share the Fadal Model 914 / VMC15 (1994) wiring diagrams / electrical schemetics?
  • jochen91
  • jochen91
15 Apr 2025 11:14
Planning to Retrofit a Mazak Integrex200Y Mill-Turn Machine
I think you identified to problem :) By trade I'm a power electronics engineer... so my programming skills are... well they can only be improved :)
  • Aciera
  • Aciera's Avatar
15 Apr 2025 07:39
There isn't really a 'dev-team'. The vismach feature was added years ago by interested users. The documentation was written up some years later by somebody else who was not involved in creating the feature.
If you have the knowledge to prepare a pull request for what you have in mind then I'm sure there would be a fair bit of interest but if you hope for somebody else to do the programming then the chances are fairly slim.
  • jochen91
  • jochen91
15 Apr 2025 07:16 - 15 Apr 2025 07:36
Hello Aciera,
yeah that was basically the problem. I could figure it out with your suggestion with the frequent halcompile way, but this was the culprit. Now it works and i started working on vismach.
I figured out how vismach works and started to modify an existing configuration. But in general its a bit of a pain.
I wonder if its possible to give feedback to the dev-Team in terms of new ideas?
I think it could be done easier, more comfortable and more accurate if it would be possible to export the already animated and set up machine out of Freecad and then just implement it into LCNC. Which would result in a proper machine simulation just as the big boys do it (siemens/fanuc etc.)
It is nice to import .obj and .stl but fitting them together is somehow a bit painful.
Even the documentation has a nice little note:
part = Capture() I have no idea what this does ! But it seems to be important for tool tip visualization…
But anyway, thank you so far for the great support!
  • Soccer Kid
  • Soccer Kid's Avatar
15 Apr 2025 06:30
Displaying 16621 - 16635 out of 17624 results.
Time to create page: 0.673 seconds
