  • snowgoer540
  • snowgoer540's Avatar
27 Dec 2024 17:57
Replied by snowgoer540 on topic PathPilot V2 source code
Category: PathPilot
Snowgoeroe,
For my clarity.
You want pathpilot planner running in lcnc?
I think it might make the most sense to just port the >3 axis look ahead and blending over to the master LCNC branch.
I am not sure how their TP differs from ours otherwise, but I do know that theirs is pretty well tested and stable at this point.
  • Alarris
  • Alarris
27 Dec 2024 17:47
User removed? was created by Alarris
User removed?
Category: Forum Questions
Hello! I just re-signed up with the same email address and user name as previously. I was just wondering if users are removed periodically (I hadn't logged in for quite some time) or if there was some other reason my user was removed?
I just want to make sure I avoid whatever I did to make it happen so it doesn't happen again!
Thank you!
Evan
27 Dec 2024 17:30
Replied by Cant do this anymore bye all on topic Is the encoder feedback loop inside 7i92 (5ABOB_Enc)?
Category: Driver Boards
The Mesa hardware just doesn’t know about gcode. The computer interprets the gcode into step and direction timings and that is sent to the Mesa hardware. As for encoders, it does the counting and sends this information back to the computer. Any “closing of loops” is done by linuxcnc.
Whilst the Mesa hardware is quite complex (firmware wise) it requires a computer running Linuxcnc to instruct as to what to do.
  • tu_koper
  • tu_koper
27 Dec 2024 17:26
Scott, thank you very much for pointing me in the right direction. I made changes to the configuration file "ec500-rt1052-DMA.txt" (JSON) according to your guidelines. I modified the parameters: "Step Length": 10, "Step Space": 5, but for now, I’m applying it only to one axis, X - JOINT_0, for testing purposes. I’m glad you helped me. Of course, in the *.ini file, I adjusted the SCALE parameter to match the settings from the HBS86H (microsteps) and to ensure movements are adapted to the lead of the ball screw. For now, everything is set up on the floor at home. In the future, I plan to install the Remora system on my new CNC machine, which I’ve been building for a long time (mainly because it’s very heavy, as it’s supposed to be, and requires a lot of work). I want it to be faster in its movements than my current one, which operates on a parallel port. If I have any questions, I’ll definitely ask you or others on the forum. It’s great that you’re all here and creating such amazing things. Take care for now.   Christopher - tu_koper.
  • elovalvo
  • elovalvo
27 Dec 2024 17:18
Newbie looking for a hardware configuration based on Raspberry Pi
The professors who know me and I think deal with these issues are at DIMEG.
You can go to them saying I was the one who reported them and ask
infodimeg.unical.it/associate_professor/card/152
infodimeg.unical.it/associate_professor/card/148
  • MaHa
  • MaHa
27 Dec 2024 16:17 - 27 Dec 2024 17:22
Replied by MaHa on topic Tool setter setup
Tool setter setup
Category: Basic Configuration
Change position must be 0 or negative value
XYZ change positions are all in machinecordinates G53:
g53 g0 Z #<_ini[change_position]z>
  • Oops
  • Oops's Avatar
27 Dec 2024 15:51
Replied by Oops on topic Re:DIgitizing a part with no probe
Category: AXIS
I am looking to use Axis 2.5.4 to digitize a paper plot or 2D template on a small gantry router.
Is there a simple to implement (my programming skills are weak) solution for writing current machine XY or XYZ position to a file? I am imaging a small pointed probe, aligning it visually, and a keystroke or GUI button to log data.
Thanks!
  • PCW
  • PCW's Avatar
27 Dec 2024 15:34 - 27 Dec 2024 15:49
Replied by PCW on topic Threading Index Varies With Speed
The 100 RPM plot looks as expected, (It would probably be less jagged if the
interpolated encoder position was used) but the 200 RPM plot is definitely broken.
 I don't understand the slow exponential velocity rise. Plotting the commanded velocity
would discriminate between LinuxCNC motion issues and hardware side issues.
Also , plotting the spindle position might help the diagnosis.
I would try doubling the acceleration to see if that helps (Increasing the acceleration
may _require_ using interpolated spindle position as the large Z position staircase
from having only 10 counts/turn will be less filtered.)
  • CaspianCmonster
  • CaspianCmonster
27 Dec 2024 15:26
Replied by CaspianCmonster on topic Tool setter setup
Tool setter setup
Hi, I am making progress I think.
the error I have now is that when I try test a file with an M6 command it I get an error
"Program exceeds machine maximum on axis Z"
It doesn't matter what code I have in there or where the machine is zeroed
I have found how to sets the locations of the probe but can't find the source for the probing travels (I think the gcode has a reference to the INI but I don't see anything there)
perhaps this is an inch vs mm thing,again I think that is correct in the file but it is a bit confusing.
thank you
Luke
  • 10K
  • 10K's Avatar
27 Dec 2024 15:20
Replied by 10K on topic Threading Index Varies With Speed
Here are the requested outputs
100RPM
200RPM
  • zmrdko
  • zmrdko's Avatar
27 Dec 2024 15:02
Replied by zmrdko on topic LinuxCNC on Raspberry Pi 5
Category: Installing LinuxCNC
try
DISPLAY = qtvcp qtdragon
  • hans48
  • hans48
27 Dec 2024 14:52
Replied by hans48 on topic Ein Neuling sucht Hilfe
Category: Deutsch
Hallo
Habe das sofort geändert. Jetzt geht es. Danke Danke für die Hilfe.
Habe alles 50 mal überprüft aber den Fehler nicht gesehen.
Gruß Han und ein GUTES NEUES JAHR.
  • User_paulvdh_42
  • User_paulvdh_42
27 Dec 2024 14:49
Replied by User_paulvdh_42 on topic round holes not exactly round.
If one diagonal is too short, and the other too long, then it's likely the axis of your machine are not perpendicular to each other.
27 Dec 2024 14:32
Replied by tommylight on topic Boxford 260 CMC 1989 mod
Category: Milling Machines
There are a lot of GUI's included with LinuxCNC, you can find them by starting it from the main menu in the config picker, most are under SIM folder and all those run without any hardware so you can run and test them as much as you like.
27 Dec 2024 14:29
Replied by tommylight on topic Ein Neuling sucht Hilfe
Category: Deutsch
net estop-ext <= [HMOT](CARD0).inm.00.input-10
Da felt ein punkt zwischen die inm und 00 beim deinen hal file.
Displaying 21301 - 21315 out of 21693 results.
Time to create page: 0.464 seconds
