  • MarkoPolo
  • MarkoPolo
21 Jul 2024 12:23
Replied by MarkoPolo on topic Error in tool_offsetview.py
Category: Qtvcp
I tested on 2.9.3 and master, and the error comes from gcode_graphics.py or qt5_graphics.py
21 Jul 2024 12:19
Replied by tommylight on topic Bridgeport EZ Trak DX II Conversion to LCNC
Category: CNC Machines
Yes, the wiring diagram is for a lathe, but if the drives are the same, this is very usefull and saves a lot of time trying to figure out wiring.
21 Jul 2024 12:07
Replied by tommylight on topic Problems with building Linux CNC source
Try compiling without documentation.
  • sprintertrd
  • sprintertrd
21 Jul 2024 12:04
Replied by sprintertrd on topic Schmitt trigger
Schmitt trigger
Category: HAL
Hi Roland,
I was wondering if you have a copy of CSbrady's hyst component.
Unfortunately the link is no longer valid.
  • rodw
  • rodw's Avatar
21 Jul 2024 12:03 - 21 Jul 2024 12:04
2.9.3 ISO Issue was created by rodw
2.9.3 ISO Issue
Category: Installing LinuxCNC
I ran the 2.9.3 installer today and noticed it was installing an old version of linuxcnc.
I've sent a PR to the powers that be that should fix it but in the meantime if you are using 2.9.3 please enter these commands at install time
sudo apt update
sudo apt upgrade
This will upgrade to 2.9.3
  • WKS-3D
  • WKS-3D's Avatar
21 Jul 2024 11:46
Brauche bitte Hilfe bei der Steuerung des Werkzeugrevolvers
Category: Deutsch
So, der Lagesensor für den Revolver-Zylinder ist auch eingebunden und funktioniert einwandfrei.
Jetzt fehlt mir nur noch der passende Code um den Revolver zu lösen bevor der Home-Switch angefahren wird.
Hat dafür vielleicht jemand eine Lösung parat?
  • andypugh
  • andypugh's Avatar
21 Jul 2024 11:20
Lag in MPG response after updating from 2.7 to 2.9
Is this just velocity jogging ? (there is an option to stop the axis when the wheel stops, even if the axis is not in position yet. ) Though I don't think that has changed.
A lot related to the names of joint and axis pins changed between 2.7 and 2.9, possibly the conversion script missed something.
  • andypugh
  • andypugh's Avatar
21 Jul 2024 11:16
Integrating Joystick Control (Logitech Wireless Gmpd F710) with axis selection
You can link the jog-velocity from the joystick to every axis, and then just enable jogging on the one you want to jog.
Maybe you haven't found the axis pins in motion that also exist in addition to tha HALUI ones?
linuxcnc.org/docs/stable/html/man/man9/m...n.9.html#AXIS%20PINS
net jog-z-analog <= joyZ.out => halui.jog.2.analog
net jog-y-analog <= joyY.out => halui.jog.0.analog, halui.jog.1.analog. halui.jog.4.analog
net joyButtonX <= input.0.btn-x => axis.x.jog-enable joint.0.jog-enable
net joyButtonY <= input.0.btn-y => axis.y.jog-enable joint.1.jog-enable
net joyButtonA <= input.0.btn-a => axis.a.jog-enable joint.3.jog-enable
net joyButtonB <= input.0.btn-b => axis.b.jog-enable joint.4.jog-enable
This is untested, and intended as a pointer. Possibly you need to use axis.L.jog-velocity instead.
  • andypugh
  • andypugh's Avatar
21 Jul 2024 11:06
Replied by andypugh on topic Carousel Toolchanger
Lots of people have done this.
Take a look at the "carousel" HAL component as an alternative to using Classic Ladder.
(you can also use both, in combination, of you want to)
  • andypugh
  • andypugh's Avatar
21 Jul 2024 11:04
Replied by andypugh on topic LinuxCNC stalls on manual toolchange routine
Try adding some debugging lines to the tool change routine.
Things like
(DEBUG, Starting toolchange, 1800 = #1800)
Just to be sure that the toolchange routine is being called, and that what you see is not just a preprogrammed tool change position.
  • andypugh
  • andypugh's Avatar
21 Jul 2024 10:56
Replied by andypugh on topic RC Servo Test with 7i96s
Category: Basic Configuration
Since that example was written a dedicated RC servo PWM component has been added to the Mesa firmware. You could try seeing if there is a suitable firmware for your card.
(Though having had a look in the downloadable firmware, I haven't spotted one)
Making a normal pwmgen look like an RC pwmgen is just a case of setting the max duty cycle to be only 1ms in 20ms (IIRC) and with a minimum duty cycle too. This might take a bit of hand-fettling of the HAL files.
  • chris@cnc
  • chris@cnc
21 Jul 2024 10:49
Netzwerkauffälligkeiten auch bei neuer Installation
Category: Deutsch
Deinstallieren Sie nm-tray mit sudo apt-get remove nm-tray. Melden Sie sich ab/an und installieren Sie es erneut mit sudo apt-get install nm-tray.
Melden Sie sich ab und wieder an, und Sie sollten eins haben. Gehen Sie dann ins MENÜ: Einstellungen/Sitzung und Start, wählen Sie die Registerkarte „Anwendungs-Autostart“ und entfernen Sie das Kontrollkästchen nm-tray. Schließen Sie, melden Sie sich ab/an und es wird nicht weiter hinzugefügt.
  • ississ
  • ississ's Avatar
21 Jul 2024 10:49
Replied by ississ on topic Aktuelle hardware mit PCI
Category: Deutsch
Schauen Sie sich die Mesa-Karte an.
Es ist möglich, es falsch herum zu installieren.
  • andypugh
  • andypugh's Avatar
21 Jul 2024 10:35
Data transfer LinuxCNC to / from custom board - Solved
I knew there was another HAL component that might be relevant, I don't know how I missed it:
linuxcnc.org/docs/stable/html/man/man1/sendkeys.1.html
  • andypugh
  • andypugh's Avatar
21 Jul 2024 10:25
Replied by andypugh on topic linuxcnc 2.9.2/2.9.3 toolchanger problem
As far as I can see, the carousel component did not change between 2.9.1 and 2.9.3
github.com/LinuxCNC/linuxcnc/compare/v2.9.1...v2.9.3
(click on the files tab, then the blue "293 files changed" link for the list of changed files if the link above does not take you straight there)
Is it possible that you were previously using the 2.10 version of carousel, and that has been overwritten?
Can you attach the HAL files that contains the carousel connections?
How did you do the update to 2.9.3? Did you change any config files, or re-run any setup wizards?
Displaying 24391 - 24405 out of 25547 results.
Time to create page: 0.579 seconds
