  • Thllll
  • Thllll
31 Dec 2025 19:31
How to setup a tool sensor was created by Thllll
Category: Gmoccapy
How do you setup a tool sensor exactly? I cant seem get it right after a week of trial and error of setups, parameters changes. This is not a wiring issue or a debounce issue but a setup issue.
Current Setup:
LinuxCNC 2.9.4
2" tool sensor on the bed
Attached is my setup files
From this document  linuxcnc.org/docs/stable/html/gui/gmocca...uto-tool-measurement  I cant tell if I am doing something wrong or where the discrepancy is.
[TOOLSENSOR]
X = 10
Y = 10
Z = -20
MAXPROBE = -20
This example setup would cause the Z axis to come down to get to the -20 setpoint. This results in a crash into the probe and a "Probe tripped during a non-probe move" would appear. The solution to this was to set the Z to 0 so the probing search would start immediately
For this next issue is touch off x and y (not z because the document says to press "Block Height") I immediatly get a error when pressing x or y touch off.
"G-code error in change.ngc near line 76, file ended with no percent sign(5) or program end (m2)"
Now if I just ignore these errors I get the same error when doing a tool change after it probes it.
  • RoKoTer
  • RoKoTer's Avatar
31 Dec 2025 19:23
Ethercat installation from repositories - how to step by step
Category: EtherCAT
@rodw Thanks for the guide, it really helped me! And some Claude assistance ;-)
  • RoKoTer
  • RoKoTer's Avatar
31 Dec 2025 19:14
Replied by RoKoTer on topic JMC Servo in PP mode
Category: EtherCAT
joshualee777,
Not sure if my Quick Reply was successful, so sorry for the duplicate post.
Hi! I've just successfully completed my initial test setup with a single JMC IHSV57. See github.com/rokoter/LinuxCNC/tree/main/ethercat/ihsv-homing. Hope it helps!
Launch LinuxCNC with cia402-ihsv-home-variant.ini
The Z startup error can safely be ignored :-)
  • Robin123
  • Robin123
31 Dec 2025 19:13
Replied by Robin123 on topic 7i97t Mesaflash Problem
Yes, the value comes from the PID. My power amplifier is a -10/+10V. Is the value a voltage value? If the value is, for example, 17, I measure at the Mesa only 0.35V.
  • RoKoTer
  • RoKoTer's Avatar
31 Dec 2025 19:08
Category: EtherCAT
  • PCW
  • PCW's Avatar
31 Dec 2025 19:06
Replied by PCW on topic 7i97t Mesaflash Problem
Yes, in the hal file, the analog outputs are all controlled by PWM values.
The actual PWM value shoudl be set by the output of a PID component that
in turn reacts to the difference in the encoder position to LinuxCNCs
commanded position.
  • Thllll
  • Thllll
31 Dec 2025 18:55
Replied by Thllll on topic Probe Error causes Jog lockout
Category: QtPyVCP
It wont let you change the mode, its gets locked out. I gave up on getting probe basic to work
  • Robin123
  • Robin123
31 Dec 2025 18:50
I've now loaded the standard 7i97t ini and hal files, and after a few minor adjustments, LinuxCNC is working (name, IP). In the hal file, I've only commented out the encoders and end positions for now, as they aren't connected yet. Is it even correct that the analog outputs are displayed as PWM? The only difference is that the value is set to higher values ​​(e.g., 17) when using the LinuxCNC interface.
  • workshop54
  • workshop54
31 Dec 2025 18:45 - 31 Dec 2025 18:48
Escalation of a Maho MH400E Retrofit (LinuxCNC + EtherCAT)
Category: Milling Machines
@suremetall Yeah, that's what my thoughts are exactly. I could keep messing around with the original hardware, waiting for one thing after another to fail, but once this retrofit is done I should be able to run it for years to come.
The biggest challenge for me at this moment is the motor adapter for the z-axis (ram), which doesn't have a lot of space.
I already created a design, but I'm having some issues with the tolerances and manufacturability I can't really get my head around.
  • endian
  • endian's Avatar
31 Dec 2025 17:21 - 31 Dec 2025 17:27
Replied by endian on topic Ethercat random jitter fix
Category: EtherCAT
I have been using negative ref cycles setup ... everything works well, but I have been using native drivers with custom configuration ... latency is very low in my case
it is here ? github.com/grandixximo/linuxcnc-ethercat
  • Lcvette
  • Lcvette's Avatar
31 Dec 2025 16:41
Replied by Lcvette on topic Axis deflecting while jogging in G54
Category: QtPyVCP
does your offset table show the offset for rotation column? if not you can set it to do so in the ini file by specifying the column axis as shown below:
  • Lcvette
  • Lcvette's Avatar
31 Dec 2025 16:33
Replied by Lcvette on topic USER section in Probe Basic
Category: QtPyVCP
check the qtpyvcp tutorials for buttons, the same method is correct for setting up user buttons in the user button ui
www.qtpyvcp.com/widgets/buttons/index.html
  • Lcvette
  • Lcvette's Avatar
31 Dec 2025 16:31
Multiple Probes: Touch-off Probe and Edge probe
Category: QtPyVCP
did you also add the addf and loadrt lines?
  • Lcvette
  • Lcvette's Avatar
31 Dec 2025 16:27
Replied by Lcvette on topic Surfacemap Z compensation with Probe Basic
Category: QtPyVCP
I am working on a new var widget that writes the var value to the widget at startup and monitors and updates the var for any changes without the need for running a subroutine. still in testing and will be released in the next major update hopefully!
  • grandixximo
  • grandixximo's Avatar
31 Dec 2025 16:26
Replied by grandixximo on topic Ethercat random jitter fix
Category: EtherCAT
I use Intel I225 with ec_igc driver, but I also tested generic and seems ok, I plan to do more extensive testing on something worse, just to see how bad I can go before I hit any issue, to have an idea on how cheap a system I can make lol.
The newest PR has not been merged yet at this time, you can get the code from my repo, or wait a few weeks for Scott, he mentioned he was going out of town.
I really think now the code respects the ethercat standard as closely as possible, it might just be a matter of exposing some phasing paramets for picky applications, but visualiziotion with halscope and sync0shift gets you all the way there too, and you have two options to choose from syncToRefClock true or false, if your latency is decent I advise to keep it false, with a refClockSyncCycles of 2, or 10 if you can wait a bit before start moving.
Displaying 8386 - 8400 out of 13508 results.
Time to create page: 0.419 seconds
