  • FPVUALAB
  • FPVUALAB
29 Dec 2025 00:58
Replied by FPVUALAB on topic Safely Flash a Mesa Board
Category: Driver Boards
Hello. I have a Mesa7i92TH and I need a pinout for a Chinese board (mach3 interface board) 5Axis Breakout Board. 4 encoders and four axes. Why is there no 7i92t_5abob_encd.bin firmware in Mesa Configuration Tool II (I installed it via the terminal)? Maybe I need different firmware? 7i92t_7i85sx2d.bin, but it's not there either)))
Thank you very much for your help.
  • cmorley
  • cmorley
29 Dec 2025 00:52
Replied by cmorley on topic QT Dragon Unable to Set Tool Height
Category: Qtvcp
Can you post your ini file and preference file if possible?
  • FPVUALAB
  • FPVUALAB
29 Dec 2025 00:48
Replied by FPVUALAB on topic Bricked Mesa 7i92T
Bricked Mesa 7i92T
Hello. I need a breakout board for a Chinese circuit board (Mach3 interface board) 5Axis Breakout Board.
  • JT
  • JT's Avatar
28 Dec 2025 23:22
Replied by JT on topic Disable pushbutton
Disable pushbutton
Category: Flex GUI
Let me verify how to do that, it should be simple but I want to test first.
JT
  • MaHa
  • MaHa
28 Dec 2025 23:17
Replied by MaHa on topic Disable pushbutton
Disable pushbutton
Category: Flex GUI
With function mdi and command M66E0L0 the button is disabled while running a program and that doesn't affect its initial functionality. But still hoping there is another way to do that.
  • PCW
  • PCW's Avatar
28 Dec 2025 21:50
LinuxCNC + Mesa 7i43 – Axis A stepper (stepgen), error
Category: HAL
By error I mean:
What does LinuxCNC report?
Can you post the complete hal file?
  • manny
  • manny
28 Dec 2025 21:45
Category: HAL
I meant it as an error — I’m not sure how to configure it, what I’m doing wrong, and why the AXIS_A code is written incorrectly. please
  • Thllll
  • Thllll
28 Dec 2025 21:11
Replied by Thllll on topic Probe Error causes Jog lockout
Category: QtPyVCP
Axis works fine, QT dragon also works fine. Its just Probe Basic
  • Thllll
  • Thllll
28 Dec 2025 21:01
  • andypugh
  • andypugh's Avatar
28 Dec 2025 20:28
Replied by andypugh on topic Probe Error causes Jog lockout
Category: QtPyVCP
I don't see this in 2.9.7 with Axis (I don't have a Probe Basic setup to test with)
Can you see if you see the same issue in Axis with one of the sim configs? (This won't affect your real config)
  • MaHa
  • MaHa
28 Dec 2025 19:01
Disable pushbutton was created by MaHa
Disable pushbutton
Category: Flex GUI
I am looking at disable a pushbutton during program runtime. No idea how to do. It is connected to python module, and should not
be enabled during runtime. Is there a setting, it gets greyed out, eg. like mdi-button?
  • cmorley
  • cmorley
28 Dec 2025 18:45
Category: Qtvcp
What version of linuxcnc are you using?
  • cmorley
  • cmorley
28 Dec 2025 18:17
LatheEasyStep – experimental QtVCP macro for step-by-step lathe programming
Category: Qtvcp
There is a version of nativecam in a linuxcnc branch that mostly works.
It's a work in very slow progress. It's based on Qt.
github.com/LinuxCNC/linuxcnc/tree/qt_ncam
There is also another project I've seem on the forum that keeps it gtk based and just updates it to python3 and whatever pygtk is called now.
But I would suggest you just finish what you have built, as it seems you are pretty far along.
You could always convert it to another platform later.
  • RotarySMP
  • RotarySMP's Avatar
28 Dec 2025 17:12
How to install simplescreenrecorder on old version of Debian?
Thanks guys.
I did do:
apt-get update
before I started.
I just ran it update again to check, and the distro is wheezy.
I watched Rods video, but don't want to update to LCNC 2.8 or above as I have had a working system, and don't have the time to play around getting it configured again for the joints change, mesa card latency etc.
Cheers,
Mark
  • Thllll
  • Thllll
28 Dec 2025 16:52
Freelancer wanted to get tool sensor working (software)
Category: User Exchange
Mr.Rodw big fan of your work! I wouldnt disagree with that however if there is solution to continue to use ER16 tooling (I should have mentioned that in the og post) then I would rather do that then invest in a TTS spindle and TTS collets. I know there is a solution to this
Displaying 8536 - 8550 out of 13506 results.
Time to create page: 0.683 seconds
