  • abs32
  • abs32
27 Dec 2025 08:17
How to fix "Queue is not empty after probing"
да пожалуйста.
According to my observations, the queue error simply replaced the error  Probe tripped during non-probe move.
  • NWE
  • NWE's Avatar
27 Dec 2025 07:33
DIY CNC Mill - Random Limit Switch Errors
Category: Milling Machines
Wow, that's a lot to take in.
Sorry, I think I made too big a deal about some of this. That is a nice mill you've got. With a few tweaks it'll be fine.
  • NWE
  • NWE's Avatar
27 Dec 2025 07:29
Do the 220v lines going from the breaker box to the VFD also emit interference?
Yes.
Not sure how I overlooked this part of your question previously.
  • NWE
  • NWE's Avatar
27 Dec 2025 06:54
Replied by NWE on topic Request to add a Chinese section
Category: Other Languages
那是正确的。
  • AndyUAZ
  • AndyUAZ
27 Dec 2025 06:42
3d kantentaster und werkzeuglängen Taste
Hallo ,
Ich möchte den 3d taster und den werkzeuglängen taster
nutzen ,die haben aber beide den gleichen Namen probe input pin. Den 3d taster habe ich auf pin 22 .funktioniert einwandfrei solange wie ich den pin 24 auskommentiert habe ,wenn ich ihn nicht auskommentiert habe startet das Programm nicht ,es kommt der Fehler probe pin bereits vergeben wie bekomme ich das gelöst .der eine wird in der Maschinen hal angegeben und der andere in der postgui.hal. Wie kann ich das Problem lösen?
  • small panda
  • small panda
27 Dec 2025 06:09
Replied by small panda on topic Request to add a Chinese section
中文是精简指令集 也封装了高压缩的复杂指令集 和英语的底层构架不一样 除了名词 其他的翻译有限失真啊
  • NWE
  • NWE's Avatar
27 Dec 2025 06:02 - 27 Dec 2025 06:19
Recommend hardware solution for multi rs485 channel?
Depends partly on how much data each device needs to transmit/receive, and how often. Theoretically, rs485 can multi-drop a large number of devices. I have used rs485 almost strictly via modbus protocol, but I see you do not mention modbus.
Using modbus rtu (rs485) with the mb2hal component, I was able to operate 1 VFD per converter/adapter. I was reading/writing approximately 16 parameters per VFD several times per second. I could not reliably run 2 VFDs on one converter. It seemed I was pushing the limits on bandwidth. But I had it running a lot slower - I think it was 9600, I needed that for better interference tolerance.
I used the ebyte NA111 ethernet bridge. They seem ok. Maybe a bit sensitive to interference. (I was using them in a large cabinet with one 30hp, one 10hp, two 5hp, and one 3hp 480VAC VFD, so there was plenty interference available and they've been running relatively reliably since about 4 month ago when they started using it.)
I also tried using the ebyte NE2-D11 but was very disappointed with it. It was so sensitive to interference it did not work with the Allen Bradley VFD I tried to interface. Well, it worked, but froze every time, the instant the VFD was started. I want to try it sometime on a sensor, or maybe even multiple sensors, I expect it might be fine for that.
I also have on another LinuxCNC installation a cheap USB to rs232 converter reading a position sensor about 50x per second nearly continuously since about 2016.
  • unknown
  • unknown
27 Dec 2025 05:47
Replied by unknown on topic 7c81 + 7i73
7c81 + 7i73
Category: Driver Boards
mesaflash --device device_name [options] --sserial
mesaflash --help gives more stuff
or you can try
man mesaflash
  • PCW
  • PCW's Avatar
27 Dec 2025 04:47
Replied by PCW on topic Mesa 6i25 not working?
Weird, the test/setuid in mesaflash is very basic:
    if (seteuid(0) != 0) {
        printf("You need root privileges (or setuid root) to access PCI hardware\n");
        return -1;
No idea how that can not fail for a normal user...
  • heaven
  • heaven
27 Dec 2025 04:10
I have three RS485 devices (each operating at 115200 baud) and one BNO08x IMU, which supports UART at 3,000,000 baud, as well as I2C and SPI.Currently, I am using three USB-to-RS485 adapters and one USB-to-UART adapter to connect these devices. This setup is bulky and inconvenient.I am looking for a more integrated solution, such as a single controller or I/O board, that can communicate with all these devices independently and reduce cabling and USB usage.Any recommendations?
  • NWE
  • NWE's Avatar
27 Dec 2025 03:07
I have most of the electronics mounted to a piece of sheet metal, which is connected to main ground by the green/yellow terminal block by the contactor. Should I not do this?
That should be fine. I mount a lot of stuff to DIN rail like that on top of metal plate, seems to me sheet metal should be about the same. I try to keep low voltage DC circuits completely separate from AC circuits. Sometimes it is inconvenient to do so then I run them together a bit like you did. And then sometimes it just doesn't work then I have to separate them.
It seems as soon as there are some electronics directly connected to a PC's parallel port or PCIe slots a bit like these BOBs work, things get a lot more sensitive. Lately I've been using mostly ethernet connected 'BOBs' Mesa electronics or Beckhoff etherCAT because I rarely have interference troubles with those. (ethernet has very good isolation)
I used a BOB some years ago on a cnc plasma cutting table retrofit, I was happy with it. I probably went to the extreme shielding that BOB. Mounted it inside a die cast aluminum box that cost more than the BOB. All shielded cords to the die cast box, and no AC power into it. You should not need to go to that extreme. Plasma cutters make more interference than most VFDs.
  • tar_san
  • tar_san
27 Dec 2025 02:44 - 27 Dec 2025 02:56
Ver 2.9.4 iso clean install Trouble when disabling EOE
Category: EtherCAT
Thank you so much.
Result:
A12 Servo driver alarm has vanished.
I could "ServoOn", "Jog move". without any error in Servo Driver LED.
Buf I got this  message "Failed to get reference clock time: Input / Output error"  many times. (screenshot)
I attached dmesg log.
But you see automata's posts here? Do not be surprised if it still does not work.
Thankfully, automata has kindly posted the solution here.
Please report back how it goes and if there are problems with lcec
I hope automata will guide you to use his solution.
Thanks, I will report back as much as I can for a while.  ( I'm borrowing Yaskawa-Sigma-X motors for just a few weeks)
But I'm not familier about EtherCAT master, I'm not sure what to do next, so please guide me, everyone
And I'd like to summerize procedures what I have done with your great help to get Yaskawa worked with LinuxCNC for those who are not so familier with EtherCAT master in detail like me.
  • NWE
  • NWE's Avatar
27 Dec 2025 02:42
A couple years ago I bought two BOBs and never did anything with them. Just now dug them out for a closer look. So I have two different BOBs, both look different from yours. It seems to me, if your BOB had a ground screw that had direct connection to the metal shell of the parallel cable, that would be a prime location to connect the shields of any cables connected to the BOB. That is what I am referring to as frame ground.
  • sorokin_pro
  • sorokin_pro's Avatar
27 Dec 2025 00:43
Replied by sorokin_pro on topic Mesa 6i25 not working?
That's really odd
You are not running as root are you?
is this a normal Linux installation?
What does
uname -a
report?
user@denc:~$ uname -a
Linux denc 6.12.57+deb13-rt-amd64 #1 SMP PREEMPT_RT Debian 6.12.57-1 (2025-11-05) x86_64 GNU/Linux
This is a fresh installation from LinuxCNC website.
But I downloaded  www.linuxcnc.org/iso/linuxcnc_2.9.7-amd64.hybrid.iso instead of provided  www.linuxcnc.org/iso/linuxcnc_2.9.4-amd64.hybrid.iso  by replacing 4 with 7 in the URL.
I am NOT running as root, because other commands require sudo.
  • PCW
  • PCW's Avatar
27 Dec 2025 00:21
That's really odd
What does
uname -a
report?
Displaying 8596 - 8610 out of 13507 results.
Time to create page: 0.357 seconds
