  • PCW
  • PCW's Avatar
19 Dec 2025 21:00 - 19 Dec 2025 21:09
7i96S card arrived what setup is recomended
Category: Driver Boards
PNP for mixed voltages...
But I don't think you really need mixed input voltages, as the Enable is an output
and the ALM signal is just an OPTO output
For 24V NPN proximity switches:
+24V --> 7I96S input common
NPN proximity switch 0utputs --> 7I96S isolated inputs
ALM+  --> 7i96S isolated input
COM- 24V COMMOM
Note that you could parallel the ALM outputs to save inputs
  • kello711
  • kello711's Avatar
19 Dec 2025 20:42
Replied by kello711 on topic 7i96S card arrived what setup is recomended
You can mix  7I96/7I96S input voltages if the inputs are wired in sinking mode,
that is if the input common (TB3 pin 12)  is wired to ground and the sources
(switches, alarm signals etc) supply a positive voltage relative to this ground,
in this case, the input will respond to positive voltages between 5V and 36V
so
Home/limit switch:
+24V  --> SWITCH COM  --> SWITCH NC --> 7I96S isolated input
 5V alarm signal:
 +5V alarm signal --> 7I96S isolated input
7I96/7i96S input common --> 24V GND and 5V GND
Note the the enable signal is a 7I96S output so can either be driven from a free step/dir output
or an isolated output
Yeah I realized what I said about ENA after I posted. Thanks for the clarification. So, should my prox sensors be NPN or PNP in this case? Crossing fingers for NPN.
  • PCW
  • PCW's Avatar
19 Dec 2025 20:27 - 19 Dec 2025 20:29
so
Home/limit switch:
 5V alarm signal:
  • kello711
  • kello711's Avatar
19 Dec 2025 19:53
I would use all 5V signals for the step motor drive interface
and possibly 24V for limit switches .
How does one go about mixing 24v limit switch inputs with the 5v ENA/ALM inputs?
  • masawee
  • masawee
19 Dec 2025 19:27
Replied by masawee on topic Linuxcnc Image for Raspberry Pi 3
what is kernel and what is compiler, how use or how install and use. what is repos and scratch. not understand code nerd super engineer language. (translator not help this)
  • masawee
  • masawee
19 Dec 2025 19:11
Installing on RPi with GPIO and software stepping
Category: Installing LinuxCNC
but were is rpi 3 and 4 linuxcnc os.
  • EdWorks
  • EdWorks's Avatar
19 Dec 2025 18:49 - 19 Dec 2025 18:58
Byte2Bot Daughter Board/ Raspberry Pi5 issue: creating a 0-10v Spindle Voltage
It appears to work fine. Any further suggestions would be appreciated.
Full HAL file attached.
  • EdWorks
  • EdWorks's Avatar
19 Dec 2025 18:48
And here is the Snippet:
# --- SPINDLE PWM CONFIGURATION ---
# Load and Add Functions
# (Ensure loadrt pwmgen and loadrt scale are at the top of your file)
addf pwmgen.make-pulses base-thread
# 3. Connect Spindle Enable
# This turns the PWM generator on only when the spindle is active and needs to be eliminated.
# (removed) net spindle-on spindle.0.on => pwmgen.0.enable
#Inverted Voltage Corrections
# First you need to add the next two lines above
# loadrt not count=1
# addf not.0 servo-thread
# set the Frequency
# first we need to set a frequency for the PWM in order for it to smooth the output
setp pwmgen.0.pwm-freq 100.0
# Calibration
# When using a 0-10v output signal, you may need to invert the PWM output
# so that the 5 axis breakout board will output 0V at spindle off,and
# 10v when the spindle is full on. The Negative sign before the 60000 usually does this.
# unfortunately the resting (spindle off) voltage is 10.0V - bad -very bad!
# rather we leave everything alone and creat a not.0 variable that reverses the values
setp pwmgen.0.scale 60000
setp pwmgen.0.offset 0.0
setp pwmgen.0.enable 1
# Connect Spindle Speed Command
# This signal carries the RPM requested by G-code (S command)
net spindle-speed-cmd spindle.0.speed-out => pwmgen.0.value
# Prepare to invert it
net spindle-pwm-raw pwmgen.0.pwm => not.0.in
# Connect and invert the PWM Output to Physical GPIO
# This is the "Writer" for GPIO18
net spindle-pwm-final not.0.out => hal_gpio.GPIO18-out
#End Spindle Code
  • EdWorks
  • EdWorks's Avatar
19 Dec 2025 18:34 - 19 Dec 2025 18:47
I wanted to create a control voltage for my spindle using a Raspberry Pi 5 connected to a Byte2Bot parallel daughter board (Misnomer Alert – it is actually a DB25 daughterboard and has little to do with a parallel port) connected to a parallel port breakout board provided by Byte2Bot.  The parallel port breakout board has a terminal for PWM that will produce a voltage. The question is how to do it. Here is what I discovered:
This issue continues in the attachments:
LinuxCNCQuestionA
LinuxCNCQuestionB
LinuxCNCQuestionC
  • PCW
  • PCW's Avatar
19 Dec 2025 18:13
Bitfile for Mesa 7i96s + 7i85 (+Modbus (PKT-Pin))
Yes, the sserial pinouts on the 7I85 and 7I96S are similar except the 7I85 uses 8 pins and the 7I96S uses 6
You can plug a 6 pin sserial connector into the 7I85 if you center it, that is with  a 1 pin gap in each side.
The 8 pin connection uses duplicated power and ground pins. On the 6 pin connector, you must terminate
2 wires in the single power and ground pins.
  • PCW
  • PCW's Avatar
19 Dec 2025 18:06
  • mmt
  • mmt
19 Dec 2025 17:45
Linuxcnc 2.9.x and Glade GTK3 display issue
Category: Gmoccapy
thank you for reply
error says:
**** GLADE VCP ERROR: with xml file: motion_control_gtk3_.ui : gi.repository.Gtk' object has no attribute 'glade'
  • Cristip1357
  • Cristip1357
19 Dec 2025 17:37
USED ATC HSK32 SPINDLE JAEGER Z100-H540 +6pcs chuck for sale
Category: User Exchange
Please let me know if spindle is stillavailable?
Criistian
19 Dec 2025 17:12
Replied by tommylight on topic FreeCAD 1.0 Who's using it?
Category: CAD CAM
30 reasons to use FreeCAD in 2026
  • jmelson
  • jmelson
19 Dec 2025 15:44
Pico Universal PWM Won't boot Random pins not working
That report lists 4 PPMC boards at "slots" 0, 1, 2 and 3. That is pretty odd. Are you sure this machine has a PWM controller? Are you sure the parallel port is set up correctly? Did the CMOS battery go dead? If so, the BIOS settings for the parallel port would have gotten lost. Make sure the BIOS peripheral settings for the parallel port are set to EPP mode.
Those are the first things that come to mind.
Report back if these hints don't fix it.
Jon
Displaying 8851 - 8865 out of 13502 results.
Time to create page: 0.416 seconds
