  • andrax
  • andrax's Avatar
16 Dec 2025 08:38
Replied by andrax on topic StepperOnline A6 Servo
Category: EtherCAT
I can confirm that the home function works. I made a connector from an old VGA cable and tested it on one axis.
Pin 13 <- 0V
Pin 8 <- Home switch (DI3)
Reference run method: 6
I am now waiting for the cables I ordered, and then I can test and complete the other axes.
Note 1:
The DI status (U40.04) is contradictory.
The inputs do not show as switched high.
When they are activated, they go low.
The driver interprets a low as 1, which is confusing.
Note 2:
There may be a problem with cia402homecomp.comp.
Once it has started, it cannot be stopped.
This happens, for example, when the servo moves to a limit switch.
It is not possible to move freely; the error “Home movement is still active” occurs.
This error also occurs when only one axis is referenced.
After completing the home movement, it is displayed as referenced, but can no longer be moved. The error “Home movement still active” also appears here. I will see how it behaves when I perform the home movement on all axes.
Note 3:
Since recently, I have been getting an amplifier error on the Y-axes (gantry) when starting Linuxcnc (gmocappy). The error can be acknowledged and does not reappear during runtime.
However, this may have another cause.
  • gravedigger
  • gravedigger
16 Dec 2025 06:37 - 16 Dec 2025 06:39
Replied by gravedigger on topic stepgen maxvel too big and SRO problem
Category: Gmoccapy
net rro-count <= [HMOT](CARD0).7i73.0.0.enc3.count
# verbinde max Geschwindigkeit Neufestetzung Inkrement - MPG (connect max velocity override increments - MPG)
setp halui.rapid.rapid-override.direct-value false
setp halui.rapid.rapid-override.scale 0.666667
setp halui.rapid.rapid-override.count-enable true
net rro-count => halui.rapid.rapid-override.counts
Is that correct? Does PNCCONF need to be adjusted? Does MESA CT use the new values?
  • gravedigger
  • gravedigger
16 Dec 2025 06:27
Category: Gmoccapy
Note
For GMOCCAPY 3 some HAL pin names have changed when new controls have been implemented. Max velocity does not exist any more, it was replaced by rapid override due to the demand of many users.
  • NWE
  • NWE's Avatar
16 Dec 2025 06:15 - 16 Dec 2025 08:33
Replied by NWE on topic Avon 3000 Mill retrofit
Category: Milling Machines
For the record, don't repeat the mistake I made a while back. I mounted the encoder inside the belt drive housing to some shaft driven by gearbelt. If I remember right I used a hal mux switch to select encoder scale according to backgear position. It all worked pretty good, but foiled all attempts at tapping because the encoder was not at a 1:1 ratio to the spindle. I think the big problem was index changed with each spindle revolution.
I figure it would have worked better to drive the encoder at a 1:1 ratio with the actual spindle.
  • Sekai
  • Sekai
16 Dec 2025 05:48 - 16 Dec 2025 06:56
Advantech PCM 9362 freze when opening latency-test
I explain above that with every settings off the difference is about 5000-7000
Edit: Anyone know how to use gpio on the board?
Edit 2: i really hate this style off editing of the forum.
  • Sekai
  • Sekai
16 Dec 2025 05:47
I used last night the iso from youre post
www.forum.linuxcnc.org/9-installing-linu...-rtai-and-rt?start=0
Linux Mint 19.2 with the bios settings off (single core) RTai
Run it like 2 hours and it never froze.
And the latency was about 12000
  • zoeper
  • zoeper
16 Dec 2025 05:33
Replied by zoeper on topic Avon 3000 Mill retrofit
I do like your thinking!
I have been toying with putting an encoder on the spindle. (I have some spindle encoders that was salvaged off Mori-Seiki lathes in a box somewhere) Using the index marker on those should give an accurate rev counter for the MESA and HAL implementation. I would also have a solid encoder for the spindle, should I want to venture into rigid tapping...:thinking
  • unknown
  • unknown
16 Dec 2025 05:28
Considering the Atom N450 is a single core CPU I'm unsure how isolating a core that doesn't exist would work.
You may get better latency if you disable Hyperthreading.
I'm assuming you are going to use the parallel port.
  • snowgoer540
  • snowgoer540's Avatar
16 Dec 2025 02:56
Moderator Notice Regarding Links To Unsanctioned Mirrors - Clarfication.
Does this mean I should remove the link to the RPi5/4 images I've been working on. Which I have no issue with if this is the way it should be.
Cheers
Rob
If you mean the GitHub link, no, you don’t need to remove it. It’s not a mirror. It’s your own work and it’s been communicated as such.
  • unknown
  • unknown
16 Dec 2025 01:54
That is not the image I'm referring to. That image has been uploaded via one of the mods.
I don't not have access to any of the Linuxcnc resources. Even if I did I would ensure that the image was vetted and approved by others.
  • snowgoer540
16 Dec 2025 01:26
Replied by snowgoer540 on topic VOLATILE_HOME not unhoming on fault
Category: Basic Configuration
Not near a machine so i can not confirm this, but IIRC:
Yes it does Disable the machine.
No, it does not trigger e-stop.
Near as I can tell, this is correct. It disables the the machine, requiring it to be re-enabled, but it does not turn the machine state to "OFF". This is why you see the GUI turn "OFF", and halui.machine.is-on turns False. But that's not the same as toggling halui.machine.off. I don't think this is a bug, I think this is a misunderstanding of what happens when a amp-fault is triggered. If you want this to work, I think the best course of action would be to connect the pin to machine.off as suggested previously.
github.com/LinuxCNC/linuxcnc/blob/69d26e...otion/control.c#L838
  • unknown
  • unknown
16 Dec 2025 01:12
Cheers
Rob
  • snowgoer540
16 Dec 2025 00:40
Category: LinuxCNC Announcements
Posts with links to non-sanctioned mirrors of forum content, ISO downloads, and/or other LinuxCNC content are not permitted and will be removed.
Posting such links may result in moderator action which includes being banned from the forum.
Thank you for your cooperation.
Displaying 8971 - 8985 out of 13502 results.
Time to create page: 0.421 seconds
