Feature Request
- snowgoer540
- Thank you received: 895
- snowgoer540
CR Hiccups
- snowgoer540
At any rate, I did some digging on my mill PC. I found the following pertaining to clearing programs. I follow some of it, but some of it really eludes me too. If there's a reference to another script or something I can grab that as well. I am relatively sure it refers to an empty g-code file that was in their python scripts directory, so I attached that as well.
self.error_handler.write(('Loading file from recent file drop down: ' + path), ALARM_LEVEL_DEBUG)
if path == CLEAR_CURRENT_PROGRAM:
self.use_hal_gcode_timers = False
self.last_runtime_sec = 0 # we never have an estimate for the empty program
self.ensure_mode(linuxcnc.MODE_AUTO)
self.command.program_close()
self.status.poll() # Keep this in superstitiously
self.is_gcode_program_loaded = False
# clean up the temporary copy that we always create and have linuxcnc load
if os.path.exists(LINUXCNC_GCODE_FILE_PATH):
os.unlink(LINUXCNC_GCODE_FILE_PATH)
self.gcodelisting_buffer.set_text('')
self.set_current_gcode_path('')
# load the empty gcode file from the same directory as the program is running from
program_dir = os.path.dirname(os.path.abspath(inspect.getsourcefile(self.__class__)))
emptyfile_fullpath = os.path.join(program_dir, EMPTY_GCODE_FILENAME)
# FIXME consider using redraw_gremlin rather than naked empty file draw here
self.gremlin.load(emptyfile_fullpath)
# must set a view to remove the old tool path
# but default view for mill and lathe is different
if 'Y' in self.gremlin.get_geometry():
self.gremlin.set_view_p()
else:
self.gremlin.set_view_y()
self.combobox_masked = True
# sort of a hack here - add a '' name to the top
# of the list store. The previous way of doing this
# caused some wonky gtk behavior. See issue #660
sort_file_history(self.file_history_liststore, path, None)
self.file_history_liststore.prepend(['', ''])
self.combobox_masked = False
# force refresh the tool list store as we color code it based on if the tools are used by the program or not
self.gcode_program_tools_used = []
self.refresh_tool_liststore(forced_refresh=True)
self.gremlin_options.show_all_tools()
self.gremlin.clear_live_plotter()
self.set_start_line_settings(1)
else:
self.load_gcode_file(path)Please Log in or Create an account to join the conversation.
- phillc54
- Thank you received: 2100
Sorry, I forgot about the connections.hal, here is the one I am using.That doesn't exactly work... it gives me a ton of errors about my plasma_connections.hal, and when I comment all of those lines out, it will run, but I cant turn the machine on to home it to test it...
- phillc54
I am glad that you did that vid. I didn't realize that you were pausing while it was still probing while recovering, I was pausing after it had recovered. Now I know what to look for.In the meantime, I got bored and found a screen recorder... Figured I'd catch the bugger red handed!
CR Hiccups
Edit: it is a good idea when doing this sort of testing to start LinuxCNC from a terminal, that way you may see some error messages.
- phillc54
This command does not exist in LinuxCNC, maybe they rewrote some of the linuxcnc python module as well.I found the following pertaining to clearing programs.
github.com/LinuxCNC/linuxcnc/blob/master...ensions/emcmodule.cc
If you search for "program_" you will see there is an open but no close.
Conversational does it in a similar way:I am relatively sure it refers to an empty g-code file that was in their python scripts directory, so I attached that as well.
(empty program to clear tool path display) M30
(new wizard)
M2Is their GUI GPL?
I should also mention that all the above applies to "gremlin" which is the preview that conversational uses but Axis has it's own preview so work differently.
- snowgoer540
So that hal file ended up being close to mine, but when I start the sim, I still cant do anything with it because I cant turn on the "on" switch to get to homing or anything..? Do I need the regular hal file as well?Sorry, I forgot about the connections.hal, here is the one I am using.
Good deal, I apologize, I probably didn't explain it well enough. I figured it was the closest thing to a failed torch fire.I am glad that you did that vid. I didn't realize that you were pausing while it was still probing while recovering, I was pausing after it had recovered. Now I know what to look for.
Can you remind me how to run it from a terminal?
Ok, makes sense. I guess I could ask, I am part of their beta test group, I have a pretty good rapport with them (I've brought them a lot of bugs to squish tooIf you search for "program_" you will see there is an open but no close.
Correct, it goes back to a blank slate.Does theirs not display that code when it is loaded?
They use Glade. Not sure if Glade = GPL?Is their GUI GPL?
- phillc54
No, I just click estop then power and away it goes.
~/linuxcnc-dev/scripts/linuxcnc ~/linuxcnc/configs/my_sim_dir/plasma.iniI wonder how they do that. I don't think it would be possible in Axis.
Glade is just a WYSIWYG UI designer
I have just pushed some changes. When you commit to a Resume Cut then you are committed, the only way out is a stop or disable the torch and pause after the offsets are cleared. It is due to the timing constraints we have in relying on some userspace pins from halui.
- snowgoer540
Oh right, estop. I didn’t try clicking that because I don’t have to on my table...No, I just click estop then power and away it goes.
Thanks!
I’ll fire off an email tomorrow.I wonder how they do that. I don't think it would be possible in Axis.
I’m good with commitment... just ask my girlfriendI have just pushed some changes. When you commit to a Resume Cut then you are committed, the only way out is a stop or disable the torch and pause after the offsets are cleared. It is due to the timing constraints we have in relying on some userspace pins from halui.
I’m pretty sure I understand what you’re saying. Only thing I can think of off the top of my head is, is would there be a problem if the torch went to fire again and paused from failing without any movement in the X or Y? Would that clear the offsets? Or would it cause similar issues to what I’ve been seeing?
- phillc54
It would pause goto the top and give an error. You could then either fix the issue and resume or press stop which will clear the offsets.I’m pretty sure I understand what you’re saying. Only thing I can think of off the top of my head is, is would there be a problem if the torch went to fire again and paused from failing without any movement in the X or Y? Would that clear the offsets? Or would it cause similar issues to what I’ve been seeing?
