  • arijitdutta
  • arijitdutta
01 Sep 2024 18:03
Replied by arijitdutta on topic Sliders for overrides in gmoccapy
Sadly, it doesnt..
  • jimwhiting
  • jimwhiting
01 Sep 2024 17:55
Replied by jimwhiting on topic ATC: carousel.comp with Servo drive
Thanks,
I actually managed to find the correct setting (SDO 0x2222 - set to 200) to limit the initial jolt from the servo... so it looks like I can drive directly. Just getting some tuning done and I will post up the configs.
-Jim.
  • jimwhiting
  • jimwhiting
01 Sep 2024 17:52
Replied by jimwhiting on topic Marco Reps video on youtube about EtherCAT
Category: EtherCAT
Is the ethercat-conf.xml file in the ~/dev/hal-cia402 directory?
  • Yoshyluebeck
  • Yoshyluebeck
01 Sep 2024 17:48
QT Dragon Go Home was created by Yoshyluebeck
QT Dragon Go Home
Category: Deutsch
Hallo,
Ich benötige Hilfe. Wo sind die Werte für den Button Go Home hinterlegt. Wenn ich den Button drücke kommt die Fehlermeldung wie auf dem Foto zu sehen.
Gruß Yoshy
  • Evgeny
  • Evgeny
01 Sep 2024 17:26
Replied by Evgeny on topic Marco Reps video on youtube about EtherCAT
Category: EtherCAT
I too am having trouble with the ethercat install. Looks like the issue is very similar to Evgeny. I am able to see the ethercat slaves at this point but when I try to interact with lcec_conf it errors. I searched the computer and cannot find lcec_conf anywhere.
Hi. If you figure out how I can send you 10GB of data, I can send you an acronis image of my system, the drivers are already installed and the configuration runs. But I can't set up homing yet.
  • chrisfischer
  • chrisfischer
01 Sep 2024 17:08
Replied by chrisfischer on topic Marco Reps video on youtube about EtherCAT
Category: EtherCAT
kira@Kira:~/dev/hal-cia402$ halcmd loadusr -W lcec_conf ethercat-conf.xml
<commandline>:0: execv(lcec_conf): No such file or directory
<commandline>:0: waitpid failed lcec_conf lcec_conf
<commandline>:0: lcec_conf exited without becoming ready
As a noob, I was happy to get this far with the help from chatgpt. But now I am stuck. Any ideas?
  • Aciera
  • Aciera's Avatar
01 Sep 2024 16:25 - 01 Sep 2024 16:26
NGCGUI arc1 and arc2 are not adding a tool offset
Category: Mill Library
Thanks for the feedback.
However this is actually likely a case of 'it's not a bug but a feature' as the slash lets the operator activate/deactivate the cutter radius compensation using optional block delete:
  • Norman
  • Norman
01 Sep 2024 15:50 - 08 Sep 2024 20:26
Question to operatingspeed glassscales with Beckhoff/EtherCAT under Linux CNC
Good day,
I would like to carry out a retrofit on a Maho with Philips 432 control and would like to use the original glass scales as well as many other old parts of the electronics.
It should be possible to evaluate the glass scales with components from Beckhoff e.g. EL5101.
My questions are:
1.can Linux CNC process this evaluation and use it to realize the control loop to the axis controllers of the servo motors?
2. is the Beckhoff controller fast enough to carry out the evaluation in real time?
3. is it possible to calculate the maximum traversing speed above which the processing speed is no longer sufficient to work in real time?
I hope you can help me here!
Thank you very much
Guten Tag,
ich möchte ein Retrofit an einer Maho mit Philips 432 Steuerung durchführen und möchte die Originalen Glasmaßstäbe verwenden sowie viele andere alte Teile der Elektronik.
Es sollte möglich sein, mit Komponenten von Beckhoff z.B. EL5101 die Glasmaßstäbe auszuwerten.
Meine Fragen sind dazu:
1.Kann Linux CNC diese Auswertung verarbeiten und daraus den Regelkreis zu den Achscontrollern der Servomotoren realisieren?
2.Ist die Beckhoff Steuerung schnell genug um die Auswertung in Echtzeit durchzuführen?
3.Oder kann man die maximale Verfahrgeschwindigkeit ausrechnen, ab der die Verarbeitungsgeschwindigkeit nicht mehr ausreicht um in Echtzeit zu arbeiten?
Ich hoffe Ihr könnt mir hier weiter helfen!
Danke
  • Creative25
  • Creative25
01 Sep 2024 15:10
Replied by Creative25 on topic Building a chain driven Plasma table.
Hi to all so I am back after a ling break.
And I finally could start building my plasma table.
So far I got the tandem axis running which I chose to be the X axis.
Homing and everything Is running fine.
I also was able to Calibrate the Axis movement to within 2mm per 2 meters.
Dont have anything accurate to measure the movement except a tabe measure.
What is still have to do is to find out how much acceleration the Stepper motors can handle.
When i use the Motor tuning option in pnconfig. Only one of the motors is moving.
Is there a way to make both motors to move at the same time?
So far i use acceleration of 1000 and maximum Speed of 15000mm / min.
Seems to be running well without loosing steps.
What acceleration should I try to reach for good plasma cutting?
  • Aciera
  • Aciera's Avatar
01 Sep 2024 14:51
Replied by Aciera on topic Modbus VFD startup delay?
Category: Basic Configuration
There are probably ways to start the modbus component and the associated hal file through a custom Mcode but I don't see how you would be able to restart the modbus connection after an estop event.
It seems that this should really be handled in the modbus component itself.
  • JackRay
  • JackRay
01 Sep 2024 14:50
Replied by JackRay on topic 5 Axis configuration on linuxcnc
Hello, nice work.
I'm installing a 5 axis XYZBC machine driven by a berak out with a parallel port --> I want to switch to an ethernet port and raspberry pi 4. I want to add position sensor feedback at least on the B&C axes.
I'm trying to install linuxcnc 2.9.3 on my raspberry Pi 4 under raspbian. Impossible to compile/install the RT patch . see that you have a version “Linux pi 6.6.44-rt39 #1 SMP PREEMPT_RT Mon Aug 12 21:10:13 AEST 2024 aarch64 GNU/Linux” .
Can you help me with this installation?
Thanks for your help
  • Evgeny
  • Evgeny
01 Sep 2024 14:27
Category: EtherCAT
The homing mode is described in the servo manual in section 5.5.4 on page 195. I have studied it but I still don't understand what settings I have to change to make it work.
www.leadshine.com/upfiles/downloads/80d2...d8_1687682456724.pdf
  • CADdy
  • CADdy's Avatar
01 Sep 2024 14:12
Replied by CADdy on topic Which settings are currently valid?
Category: Qtvcp
I've found the infos about my QtDragon_HD:
Peter
  • PCW
  • PCW's Avatar
01 Sep 2024 13:58 - 01 Sep 2024 14:51
Replied by PCW on topic Error while Running Linuxcnc
Category: Driver Boards
The latency and ping tests look fine.
Momentary power loss could definitely cause loss of communications/latency
Also I am assuming you are running a 1 ms (1000000 ns)
servo thread, as a too fast servo  thread might also cause these symptoms
  • CADdy
  • CADdy's Avatar
01 Sep 2024 13:51 - 01 Sep 2024 13:52
Category: Qtvcp
Hi David,
Thanks for the info. I'll take a look right away and compare it with my configuration.
Peter
Displaying 22876 - 22890 out of 24270 results.
Time to create page: 0.512 seconds
