  • cakeslob
  • cakeslob
23 Aug 2024 00:01 - 23 Aug 2024 03:05
// calculate the output value
vel_cmd = pgain * error + data->cmd_d[i] * ff1gain;
Hey Scott, sorry to bother you with this, but can you explain this a bit more? Im wondering how we can just do a math to figure it out. Ive been bruteforcing pid stuff for a few days but i cant get my overshoot down to less than 5 steps, but this question comes up on discord a bunch also.
using a 1mm distance for the example to make it easier(?)
ff1 * cmd_d + error * pgain = velcmd
ff1 = number in ini file
cmd_d = old pos - new data? this is the D ?
error = ?
pgain = ini number
edit, holy shit it my issue was a typo this whole time.
my issue is typo related, but the question still stands, is there a math way to figure it out?
  • zmrdko
  • zmrdko's Avatar
22 Aug 2024 21:56
Replied by zmrdko on topic refclockSyncCycle question
Category: EtherCAT
IIRC 5 means every 5 cycles
  • atomicmill
  • atomicmill's Avatar
22 Aug 2024 21:00
Raspberry Pi CNC hat circuit board was created by atomicmill
Hello,
I wanted to replace the external Linuxcnc control PC on my mill with a dedicated control inside the electrical cabinet, but I needed something compact that is easy to wire inside an enclosure, which is why I thought of using the RPi5 and a custom designed GPIO breakout board.
The board is intended to be used as a 5 axis step/dir platform with 6 extra outputs and 10 inputs. All the Raspberry pins are digitally isolated and the outputs are buffered with 5V @ ~20 mA drive capability. The board has dedicated power connectors for the 5V RPi supply and 24V isolated bus. A 5V step down converter connected to the 24V bus provides the necessary voltage to run the digital isolators and buffer gates.
Here's the new repository with the Kicad design files: github.com/atomicmill/raspberry-pi-5-Linuxcnc-hat
So far I tested the board with LCNC 2.9 and the Probe Basic and PlasmaC UIs. I hope this board is of use to anyone looking for a low cost all in one LinuxCNC control.
  • RyanB
  • RyanB's Avatar
22 Aug 2024 20:56
Tool resets to Z0 when starting program without being told to
Category: AXIS
I removed the tool change portion of the Gcode and didn't see a plunge to 0, so that narrowed the culprit down.
This is the EMCIO portion of my INI
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
TOOL_CHANGE_QUILL_UP = 1
Not sure what the quill up means, but there's no position for the tool change to go to, so I guess it defaults to G53.
I didn't find anything for M30.
I suppose the work around is to generate the Gcode and remove the tool change stuff (fusion restricts multiple operations with tool changes for free users) and then add a bit to raise the spindle above the work piece before starting. Because I needed more reasons to dislike fusion.
Thanks for the answer.
  • avive
  • avive
22 Aug 2024 20:50 - 22 Aug 2024 20:54
Replied by avive on topic Problems with Lichuan Ethercat servo drive
Category: EtherCAT
Has anyone managed to get DO to work?
I added the following lines inside <pdo idx="1600">, but to no avail.
<pdoEntry idx="60FE" subIdx="01" bitLen="32" halType="complex">
    <complexEntry bitLen="16"/>
    <complexEntry bitLen="1" halPin="do-0" halType="bit"/>
    <complexEntry bitLen="1" halPin="do-1" halType="bit"/>
    <complexEntry bitLen="1" halPin="do-2" halType="bit"/>
</pdoEntry>
  • besriworld
  • besriworld
22 Aug 2024 19:51
Replied by besriworld on topic OLD Lathe conversion to a CNC
Category: Turning
I'm making chips again :) . It was difficult to deal with the removal of the chips.
Aluminum is 6082 t6
  • Todd Zuercher
  • Todd Zuercher's Avatar
22 Aug 2024 19:09 - 22 Aug 2024 19:18
  • Todd Zuercher
22 Aug 2024 18:55 - 22 Aug 2024 18:56
Category: AXIS
Have you remapped any of your G-codes? (specifically M6)
Other than possibly something hidden in the M6 settings or an M6 remap, I don't see anything that could even move the Z axis at all.
Do you have anything configured in the EMCIO section of your ini file for the tool changer settings? Specifically "TOOL_CHANGE_POSITION = 0 0 0" or anything pertaining to M30?
If you don't have anything configured for the tool change position, (assuming your are using manual tool changes.) Linuxcnc may be assuming a manual tool change position of absolute Z0 (same as issuing a G53Z0 command) for the tool change position. And if you don't have the machine Z0 position configured as the top of Z travel, then I think we have found your problem. Otherwise I have no idea what could be going on.
  • papagno-source
  • papagno-source
22 Aug 2024 18:53
Replied by papagno-source on topic refclockSyncCycle question
Category: EtherCAT
By increasing the value of refClock to for example 5 ms, what actually happens, do I update the data on the bus every 5 ms or is the data updated every 1 ms of the appTimePeriod anyway?
  • schuetzbuilds
  • schuetzbuilds
22 Aug 2024 18:43
Replied by schuetzbuilds on topic Retrofitting a MAHO MH600T
Category: Milling Machines
It's still a work in progress, but the computer is now mounted on the tray where the original controller used to be. It's quite convenient since the tray folds out of the cable cabinet, making the computer easily accessible.
Good on you. Nice work getting another Maho going.
Cheers,
Mark
Thank you, Mark. Your MAHO videos are actually the reason we decided to get a MAHO and go ahead with the retrofit.
  • Moutomation
  • Moutomation
22 Aug 2024 18:27 - 23 Aug 2024 06:39
Replied by Moutomation on topic İnstall glade
İnstall glade
Category: Gmoccapy
Aciera,
Thanks to your help, my project is almost finished now. I couldn't have done it without you. First of all, I would like to thank you very much. I am currently planning to put the limits and axis calibrations in the gui, but I do not know where the settings page is, I can change the home page, but I cannot access pages other than the home page.
  • gardenweazel
  • gardenweazel's Avatar
22 Aug 2024 18:24 - 22 Aug 2024 18:31
QTDragon HD spindle incrementally increase/decrease speed
Category: Qtvcp
The documentation located here indicates the following:
To have the manual spindle buttons also incrementally increase/decrease speed:
#action_spindle_fwd{
qproperty-spindle_up_action: true;
#action_spindle_rev{
qproperty-spindle_down_action: true;
Is this correct?
I've not been able to find a file where this (#action_spindle_fwd) is located?
If it doesn't exist is there a specific file or block that I should add it to in order to get this functionality working?
I did find this entity in the qtdragon_hd.ui file:
<item>
<widget class="ActionButton" name="action_spindle_fwd">
</item>
Is this where it should be added?
  • spontarelliam
  • spontarelliam
22 Aug 2024 18:21
Replied by spontarelliam on topic XHC WHB04b-6 - Disconnects / freezes?
Category: Basic Configuration
I have the same problem. I've noticed that Linux itself has actually lost connection with the device, which I can see by running $lsusb while the pendant is working and again when it's not. The odd thing is that restarting LinuxCNC seems to mount the usb device in Linux.
I don't know the solution, but I'll continue taking notes and report back if I figure it out.
  • PCW
  • PCW's Avatar
22 Aug 2024 18:01
Replied by PCW on topic Driver NUM GEC MK2S
Driver NUM GEC MK2S
Category: Driver Boards
Those seem to be unused so irrelevant
  • greg23_78
  • greg23_78
22 Aug 2024 17:59
Replied by greg23_78 on topic Driver NUM GEC MK2S
Driver NUM GEC MK2S
ANALOG_SCALE_MAX = 133
ANALOG_MIN_LIMIT = -133
ANALOG_MAX_LIMIT = 133
Is correct ?
Displaying 23461 - 23475 out of 24335 results.
Time to create page: 0.603 seconds
