  • HalaszAttila
  • HalaszAttila
19 Aug 2024 05:59
Replied by HalaszAttila on topic SoE Ethercat
SoE Ethercat
Hello,
Did you manage to get the NCT plc and Linuxcnc working together?
  • __Tom
  • __Tom
19 Aug 2024 05:33
Replied by __Tom on topic Getting an error on starting a machine
Thanks a lot for your afford.
  • scotth
  • scotth
19 Aug 2024 04:24 - 19 Aug 2024 04:26
difference between machine coordinate systems and CAD software
Category: AXIS
With no hardware info, this is just a guess. If you have encoder feedback, swap A and B to reverse count.
For steppers, invert direction.
Be ready with E-STOP when you test, things can go very wrong quickly.
  • Hauligali22
  • Hauligali22
19 Aug 2024 04:17
Learning HAL and external offsets was created by Hauligali22
Category: HAL
Hello,I have a project where I want to apply changes to a cnc toolpath in realtime based on object tracking data from a camera. I have been told that while uncommon, that it is possible. Particularly, to use a hardware abstraction layer to apply external offsets so that the original g-code remains unchanged and the toolpath can still be updated. However, as a novice and having done a deep dive into this topic, I find it very difficult to complete this project because of the lack of information on these topics. Can anyone direct me or recommend how I can learn how to use HAL and external offsets? I have also been suggested that parametrized g-code is dynamic and can work. That Fanuc controls have a feature called real time macro and Siemens controls have a feature called parallel program execution, which I may be able to code in linuxcnc. Thanks!
  • Mecanix
  • Mecanix
19 Aug 2024 01:32
W5500
Level-Shifter (TXS0108E)
RGB-LED
Modbus
I2C - 5V (hope this will work via the level-shifter)
Maybe a good and cheap universal-board
That's just awesome!! Never thought of using the w5500 lite module as a board add-on, great idea. That would have simplified a whole lot. In the other board gossips, here's another fully functional/tested Gowin based RIO Motion Control Board. Surprisingly everything works flawlessly and so I'm upgrading this from a prototype rev 1.0 to alpha, and getting ready to start on a beta release (revision 1.1). Should be out and avail for testing in a week.
  • my1987toyota
  • my1987toyota's Avatar
19 Aug 2024 00:16
Replied by my1987toyota on topic Video about shielding cnc machine wiring
I was hoping he would have shown a twisted pair in comparison, oh well. I usually do twisted pair wires more to
keep things tidy, though shielded cable is best.
Something to note if a cable is to be continuously flexed a braided shield is better suited for things like drag chain
cable carriers at least in the long run and industrial settings where the machine maybe operating 24/7 365 for
years on end.
Still it was a good video showing the scenario.
  • MarkoPolo
  • MarkoPolo
18 Aug 2024 21:40
Replied by MarkoPolo on topic Error in tool_offsetview.py
Category: Qtvcp
Yes, that's how it works. Just make the buttons bigger. I  improwed the file.
  • cmorley
  • cmorley
18 Aug 2024 20:28
Versa probe Z height after automatic tool length measure
Could you supply a small sample program for testing?
I've never actually used auto tool probe but i could try testing on my little mill.
  • PCW
  • PCW's Avatar
18 Aug 2024 19:49
Replied by PCW on topic Voltage encoder with 7i97T board
Category: Driver Boards
The 7I97T has 6 hardware encoders, you do not use the software
encoder.  Your sample looks like a parallel port configuration.
I would suggest using MesaCT to create a hal/ini configuration file set.
  • PedPEx
  • PedPEx
18 Aug 2024 19:30
LCEC creating Danfoss VFD config was created by PedPEx
Category: EtherCAT
Hey folks,
i'm trying to retrofit an old Maho400E in the near future with a Beckhoff EM7004 in combination with a costum adaptor-board for the 3 axis and wanted to prepare the electronics as far as possible. In addition to that i also want to implement a Danfoss VFD FC302 with its EtherCAT optioncard MCA124. I started to read out all the PDO mappings and so on, like in many other forum posts described, but now i don't know how to proceed with the Flag E and the dmesg output, that the VFD would not support distributed clocks. You can find all configs and readouts of the VFD on my Github . The most important stuff is also attached here.
Thank you guys for your help
Best regards
Patrick
EtherCAT network (ethercat slaves output while machine is running)
0  0:0  PREOP  E  FC-302
1  0:1  OP     +  EK1100 EtherCAT-Koppler (2A E-Bus)
2  0:2  OP     +  EM7004 4-Achs Interface
dmesg output of EtherCAT related messages
[    5.972506] EtherCAT: Master driver 1.6.0 1.6.0.gcafd367-1+1.1
[    5.972663] EtherCAT: 1 master waiting for devices.
[    5.993635] ec_generic: EtherCAT master generic Ethernet device module 1.6.0 1.6.0.gcafd367-1+1.1
[    5.993664] EtherCAT: Accepting F8:75:A4:86:9A:F4 as main device for master 0.
[    6.025021] EtherCAT 0: Starting EtherCAT-IDLE thread.
[    8.676976] EtherCAT 0: Link state of ecm0 changed to UP.
[    8.961049] EtherCAT 0: 3 slave(s) responding on main device.
[    8.961055] EtherCAT 0: Slave states on main device: PREOP.
[    8.961492] EtherCAT 0: Scanning bus.
[    9.035903] EtherCAT WARNING 0-0: Received mailbox protocol 0x02 as response.
[    9.035906] EtherCAT ERROR 0-0: Failed to read number of assigned PDOs for SM2.
[    9.044901] EtherCAT ERROR 0-0: Received upload response for wrong SDO (0x1C12:00, requested: 0x1C13:00).
[    9.044904] EtherCAT DEBUG: 00 30 4F 12 1C 00 01 00 00 00
[    9.585876] EtherCAT 0: Bus scanning completed in 624 ms.
[    9.585880] EtherCAT 0: Using slave 1 as DC reference clock.
[    9.585883] EtherCAT 0: Starting EoE thread.
[    9.626324] EtherCAT ERROR 0-0: Failed to set SAFEOP state, slave refused state change (PREOP + ERROR).
[    9.626621] EtherCAT ERROR 0-0: AL status message 0x001E: "Invalid input configuration".
[    9.636234] EtherCAT 0-0: Acknowledged state PREOP.
[   24.746151] EtherCAT: Requesting master 0...
[   24.746156] EtherCAT: Successfully requested master 0.
[   24.748381] EtherCAT 0: Domain0: Logical address 0x00000000, 64 byte, expected working counter 6.
[   24.748385] EtherCAT 0:   Datagram domain0-0-main: Logical offset 0x00000000, 64 byte, type LRW.
[   24.748399] EtherCAT 0: Master thread exited.
[   24.748402] EtherCAT 0: Stopping EoE thread.
[   24.748416] EtherCAT 0: EoE thread exited.
[   24.748417] EtherCAT 0: Starting EoE thread.
[   24.748455] EtherCAT 0: Starting EtherCAT-OP thread.
[   24.748492] EtherCAT WARNING 0: 33 datagrams TIMED OUT!
[   24.773374] EtherCAT ERROR 0-0: Mailbox error response received - Unknown error reply code 0x0000.
[   24.773380] EtherCAT WARNING 0-0: Invalid mailbox response for eoe0s0.
[   36.885422] EtherCAT WARNING 0-0: Slave seems not to support distributed clocks!
[   36.887420] EtherCAT ERROR 0-0: Failed to set DC cycle times: No response.
[   36.940945] EtherCAT 0: Slave states on main device: PREOP, OP.
ethercat-conf.xml file:
<masters>
        <master idx="0" appTimePeriod="1000000" refClockSyncCycles="5" name="m0">
                <!-- Danfoss FC302 in CiA402/DSP402 mode -> needs CiA402 mode vl -->
                <slave idx="0" type="generic" vid="0200008d" pid="00000064" configPdos="true" name="2001_FC302">
                        <dcConf assignActivate="300" sync0Cycle="*1" sync0Shift="0"/>
                        <syncManager idx="2" dir="out">
                                <pdo idx="1616">
                                        <pdoEntry idx="6040" subIdx="00" bitLen="16" halPin="ControlWord" halType="u32"/>
                                        <pdoEntry idx="6042" subIdx="00" bitLen="16" halPin="TargetVelocity" halType="s32"/>
                                </pdo>
                        </syncManager>
                        <syncManager idx="3" dir="in">
                                <pdo idx="1a16">
                                        <pdoEntry idx="6041" subIdx="00" bitLen="16" halPin="StatusWord" halType="u32"/>
                                        <pdoEntry idx="6044" subIdx="00" bitLen="16" halPin="ActualVelocity" halType="s32"/>
                                        <!-- <pdoEntry idx="6061" subIdx="00" bitLen="8" halPin="ModeOfOperationDisplay" halType="u32"/>-->
                                </pdo>
                        </syncManager>
                </slave>
                <!-- Beckhoff IO modules -->
                <slave idx="1" type="EK1100" name="0501_EK1101"/>
                <slave idx="2" type="EM7004" name="0501_EM7004"/>
        </master>
</masters>
  • CNCFred
  • CNCFred's Avatar
18 Aug 2024 19:15
Plasmac2QTplasma gives error not a Plasmac configuration /solved
Category: Plasmac
Thank you for you kind reply and offer, no worries , the error is on my side not being up to date, you are all busy enough.
I had a 7i76e.pncconf file which I was able to open with pncconf and my settings were there at least seems ok for the default machine.
I was using a xbox controller, a two button crane control with emergency stop and the laser was with a M7 command- button set to the mist hal output.
I will read the documentation and hopefully get all working with the qtplasmac machine setup again.
I assume the additional config is the same, custom hal etc.
thank you
Roman
18 Aug 2024 18:52
Replied by tommylight on topic Getting an error on starting a machine
ip a
If you only changed from 10 to 11 it will not work
Change to 10.10.10.11
  • greg23_78
  • greg23_78
18 Aug 2024 18:49 - 18 Aug 2024 18:51
Replied by greg23_78 on topic Voltage encoder with 7i97T board
wanting to configure my spindle encoder and reading linuxcnc doc for Spindle Synchronized Motion I found out that the encoder must be connected to mesa card inputs and not to encoder input 5 (7i97T).
Do I have to change my encoder wiring or is it possible to do the same as
# Add the encoder to HAL and attach it to threads.
loadrt encoder num_chan=4
addf encoder.update-counters base-thread
addf encoder.capture-position servo-thread
# Set the HAL encoder to 100 pulses per revolution.
setp encoder.3.position-scale 100
# Set the HAL encoder to non-quadrature simple counting using A only.
setp encoder.3.counter-mode true
# Connect the HAL encoder outputs to LinuxCNC.
net spindle-position encoder.3.position => spindle.0.revs
net spindle-velocity encoder.3.velocity => spindle.0.speed-in
net spindle-index-enable encoder.3.index-enable <=> spindle.0.index-enable
# Connect the HAL encoder inputs to the real encoder.
net spindle-phase-a encoder.3.phase-A <= parport.0.pin-10-in
net spindle-phase-b encoder.3.phase-B
net spindle-index encoder.3.phase-Z <= parport.0.pin-11-in
with the encoder cable on encoder input 5
  • greg23_78
  • greg23_78
18 Aug 2024 18:40
Category: AXIS
it's actually my mistake, I didn't remember that the Machine coordinate was related to the spindle displacement (I'm used to it with cnc gantry).
What would be the quickest and easiest way to correct my mistake?
Displaying 23716 - 23730 out of 24347 results.
Time to create page: 0.872 seconds
