  • CNCGOOS
  • CNCGOOS
29 Jun 2024 10:00 - 29 Jun 2024 10:04
Replied by CNCGOOS on topic Duplicate settings in Pref File
Category: Gmoccapy
It by me also stil happening.
with the same strange interval. i will look if there is by mee also a connection whenn jobs ar ready.
By me was the first time after opdating to 2.9
  • andypugh
  • andypugh's Avatar
29 Jun 2024 09:54
Replied by andypugh on topic when an inch isn't
when an inch isn't
Category: Installing LinuxCNC
Did you change the microstepping number? 1.9 just doesn't make sense.
1.016 is the ratio between 5tpi and 5mm pitch. Maybe the leadscrew isn't the pitch you think it is?
  • andypugh
  • andypugh's Avatar
29 Jun 2024 09:45
Replied by andypugh on topic disable run button if door open
Category: AXIS
I no longer get errors but it still doesn't work, my pin axisui.run-disable remains on false while my input hm2_7i97.0.inmux.00.input-11-not works fine
I think that probably means that the postgui HAL file isn't being executed. Did you add the postgui file to the [HAL] section of the INI file?
  • andypugh
  • andypugh's Avatar
29 Jun 2024 09:36
Replied by andypugh on topic CNC lathe help
CNC lathe help
Category: Turning
USB to Serial isn't relevant here. I think that plug is intended for transferring G-code to the controller, not for machine control.
USB to parallel won't work either.
Do you have a PC with a physical parallel port? (some have one as headers on the motherboard, but don't connect it to the rear panel)
You could also consider using a Raspberry Pi 4 (not 5 at the moment) but there isn't a config wizard for the Pi GPIO pins.
  • andypugh
  • andypugh's Avatar
29 Jun 2024 09:19 - 29 Jun 2024 09:20
Replied by andypugh on topic REMAP M6 ERROR
REMAP M6 ERROR
Category: AXIS
Is there any more? This doesn't get as far as reporting the actual error.
  • andypugh
  • andypugh's Avatar
29 Jun 2024 09:18
Linuxcnc ignore stored position for specifix axis
There might be a way to do what you want, but I am not sure how.
What happens if you remove the reference to A from the position.txt file before you restart LinuxCNC?
You can almost certainly do his by creating a custom homing routine, but I would hope that there is a simpler way than that,
  • andypugh
  • andypugh's Avatar
29 Jun 2024 09:12
About the Fusion360 mill-turn machine's post processor for linuxcnc.
Category: Fusion 360
I think that I have looked into this in the past, and found that it was fairly easy to change the postprocessor file based on the results of a Google search.
What is the problem? Is it that the postprocessing fails when you try to create the G-code?
  • andypugh
  • andypugh's Avatar
29 Jun 2024 09:04 - 29 Jun 2024 09:06
Docs -1.1 Apt Sources Configuration Table 1 - Repository Error?
Category: LinuxCNC Documents
The best way to report an error in the docs is to raise an issue at:
github.com/LinuxCNC/linuxcnc/issues
But there is no need to do that here, as I just fixed it.
Thanks for the correction.
  • andypugh
  • andypugh's Avatar
29 Jun 2024 08:53
Replied by andypugh on topic MPCNC help with Homing switches on LPT board
Category: Basic Configuration
In Stepconf you can only pick one function for each parallel port pin, but that doesn't mean that LinuxCNC doesn't support it.
Create a config with Z-home not allocated, then when the config is finished, edit the HAL file by hand.
You will see a line looking something like:
net home_Y2 parport.0.pin-12-in joint.3.home
Edit that to say
net home_Y2 parport.0.pin-12-in joint.3.home joint.4.home
If you want you can also change the signal name (home_Y2) to something that makes more sense to you.
Also, I am guessing the joint-to-axis allocations, so the numbers above might not be right. Adapt the numbers to suit your actual config.
  • ihavenofish
  • ihavenofish
29 Jun 2024 07:05
Replied by ihavenofish on topic VFD setup help
VFD setup help
Category: Milling Machines
Soooorta.
So the drive needs to be 135v or it will toast the spindle. BUT, you are 100% right in that lowering the voltage has some some sort of math and reduced the power.
After working with the drive support people, we did a few things. ! was to boost the carrier frequency to 16khz. this reduced current a lot (over an amp at load). Then we upped the voltage bit by bit until we found a compromise where it is no longer bogging down, but also not getting more than slightly warm. Idles at 2.1A now.
As a result, I have about 600w usable power at 5A draw, no bogging down, and it's "fine" for now, until I can wrangle a high speed drive.
  • ihavenofish
  • ihavenofish
29 Jun 2024 06:52 - 29 Jun 2024 08:11
Replied by ihavenofish on topic Problems with Lichuan Ethercat servo drive
Category: EtherCAT
just subscribing to this thread...
Anyone tune these up yet and move a machine? Very curious to see how they perform. When you factor cables and psus, these come out even cheaper than JMC integrated servos, and less than half of delta b3s, so id lover to see how they actually perform.
29 Jun 2024 06:35 - 29 Jun 2024 06:39
Replied by Cant do this anymore bye all on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
Ok had a play around.Build works OKFlashing works okAfter flashing, when SPI interface not connected, no blinking lights observed.Has to create a new board called Mimas, and the config to go with.Just copied the Spartan6 stuff.After generating everything has browse thru the Ouput/Mimas/Gateware folder everthing was there, pin constraints matched what I need. Just added the "drive setup" for each pin.Still need to setup the Rpi for Linuxcnc.Included some file for you to look at.
  • pippin88
  • pippin88
29 Jun 2024 04:48
Replied by pippin88 on topic EtherCat - CATIO module Help
Category: EtherCAT
linuxcnc.org/docs/html/hal/basic-hal.html#sub:hal-addf
The addf command adds a function to a real-time thread
Addf
Then the function
Then the thread the function is assigned to
Lcec is linuxcnc ethercat
Linuxcnc has has long-standing terminology of:
Servo thread - thread/loop where position, IO etc are read / updated
Base thread - used for software step generation. Not used in setups with hardware step generation (e.g. Mesa) or ethercat
(Documentation about the real time threads is a bit poor compared to most other linuxcnc docs)
  • Miller Turner
  • Miller Turner
29 Jun 2024 04:44
Re-Retrofit Fadal VMC20 from Numatix to LinuxCNC 7i77D/5i25???
Hi msrdiesel,
It would be awesome if you could share details on how you did your retrofit.
Especially about the spindel motor and spindel drive I'd like to learn more.
Thanks,
Frans
  • BHar
  • BHar
29 Jun 2024 03:34
Replied by BHar on topic EtherCat - CATIO module Help
Category: EtherCAT
So I guess this is what I get from diving into EtherCat without already being super comfortable with LinuxCNC. I had seen it mentioned on the forum that it's a big task to work them both out at once and I have made it more complex by doing it on an RPI.
Seems my issue was while manipulating ethercat-conf.xml I was seeing seemingly good data appear in the lcec pins area of halshow, I was unable to manipulate them due to not having included the following in my Ini file.
addf lcec.read-all servo-thread
addf lcec.write-all servo-thread
Seems that it's not a servo thread but an overall thread for all IO (including servos) that these lines are referring to.
So, seems that I can operate all the digital outputs for this controller. I will continue to work on the other IO.
Thanks for the pointers on this everyone.
Displaying 25606 - 25620 out of 25742 results.
Time to create page: 0.572 seconds
