  • Creative25
  • Creative25
18 Jan 2025 14:05
Replied by Creative25 on topic Building a chain driven Plasma table.
I have been busy the last few days.
It looks like IRQ coalescing is disabled by default.
Just reinstalled ethtool.
No error message so far.
Just waiting to see if the error appears at random.
  • User_paulvdh_42
  • User_paulvdh_42
18 Jan 2025 14:03
Replied by User_paulvdh_42 on topic help to compensate for changes in the rack
A few days ago I read in the manual this should be possible, You once do some measurements and create a table, and then you enter that table in LinuxCNC's setup. "lead screw compensation" (ball screw, or rack & pinion, or whatever is all the same for the software) is apparently a special case, you do not need customized kinematics because it's built into each axis.
I'm planning on experimenting with this. My idea is to add a glass scale temporarily along each of the ball spindles, and have a microcontroller measure the position at set intervals. Partly to check accuracy of cheap chinese spindles, and if LinuxCNC can add some correction, that's even better.
But I do wonder about your big deviantions. 2mm is a lot. I suspect your machine has mechanical issues.
  • JT
  • JT's Avatar
18 Jan 2025 13:06
Replied by JT on topic Age of the website and forum
Category: Forum Questions
The current OS
root@forum:~# lsb_release -a
No LSB modules are available.
Distributor ID:    Ubuntu
Description:    Ubuntu 20.04.6 LTS
Release:    20.04
Codename:    focal
When I log in I see this message but I don't feel comfortable running that command.
New release '22.04.5 LTS' available.
Run 'do-release-upgrade' to upgrade to it.
JT
  • JT
  • JT's Avatar
18 Jan 2025 12:54
This is the root directory listing
root@forum:~# ls
access.log          do-dns-mirror      make-plot               PHPMailer-5.2.14        update-plot
bin                 error.log          monitor-memory          plug_reCAPTCHA.rc1.zip  v5.2.14.zip
cb_recaptchav2.zip  expire-session.sh  pflogsumm-1.1.1         requests.gnuplot
count-requests      flo.sql            pflogsumm-1.1.1.tar.gz  SHOW
data                letsencrypt        PHPMailer               simp_le
  • User_paulvdh_42
  • User_paulvdh_42
18 Jan 2025 12:29
Replied by User_paulvdh_42 on topic Ballscrew articulation, has anybody had success?
Normally you get better answers on a forum if you show you've put in some effort yourself, and then ask more specific questions.
You can start by reading about Kinematics in LinuxCNC
linuxcnc.org/docs/2.8/html/motion/kinematics.html
In short: You write your custom kinematics in C, and "halcompile" compiles it into something compatible with LinuxCNC.
  • phillc54
  • phillc54's Avatar
18 Jan 2025 11:59
Path display glitching - QTPlasmaC - v1.235.265 QtVCP LinuxCNC v2.9.0
Category: Plasmac
That version of QtPlasmaC is from Feb 2023 and is known to have issues, you should update to the latest version.
  • rodw
  • rodw's Avatar
18 Jan 2025 11:18
Category: Plasmac
At a crazy guess, your home switches are enabled by default. If that's the case, use the -not pins from your Mesa card.
Can't jog any joints while homing.
emc/task/taskintf.cc 976: Error on joint 0, command number 106
joint 3 on limit switch error
Consider running pnccconf again from scratch.
  • rodw
  • rodw's Avatar
18 Jan 2025 11:02
Replied by rodw on topic Age of the website and forum
Here in lies a problem because I don't have access to the server for the forum so I can't ask them up change the PHP.
Edit: I can ssh into the forum as root and upgrade the OS and I do that when I think about it.
JT
If you can SSH in as root to upgrade the OS you should also have root access to the server.
Its so long since I played with Joomla but configuration.php in the website's root folder contains the Database name, user name and password which is all you really need to upgrade the instance.
Ref: www.joomlashack.com/blog/joomla/guided-t...nfigurationphp-file/
Whilst a Cpanel interface is nice for users, its not really necessary to host a web server (usually whats called a a LAMP stack) and Joomla. I managed my webserver for years without a cpanel
From memory, usually a new user is defined for the web site and there should be a WWW folder in that user's home folder. As root you could see this.
Just focus on the forum would be my advice.
  • TOLP2
  • TOLP2
18 Jan 2025 11:02
RPi + Sipeed Tang Nano 20 k: new breakout board for LitexCNC
Category: Driver Boards
With the 5A-75B and 5A-75E we have a low cost way of creating a driver board for Linux-CNC. Based on the work of Romanetz, the project  LiteX-CNC  was started, providing a easy customizable firmware and driver to use these boards. The down-side however is that these boards require some soldering work to be done to accept inputs; I've messed up some boards in the process....
Therefore, Litex-CNC is going to be expanded to accept more FPGA's, starting with the Sipeed Tang Nano 20k. Compared with the 5A-75B it has less outputs (28 compared to 48 for the 5A-75B), but this is still enough for a simple 3 axis machine. The big advantage is that no SMT soldering skills are required to get this board up and running.
For the Raspberry-Pi I've designed a HAT, which provides:
  • 7 extended PMOD-connectors. Each connector has 4 GPIO, power rails (+5V, max 200 mA) and a buffered enable signal;
  • RS489 connector for communicating with for example a VFD;
  • communication between Raspberry PI and FPGA using SPI in bidirectional mode (3-wire) to save on pins;
  • conforms to the HAT+ specification , including a EEPROM with settings.
With the PMOD-connectors one can easily connect to break-out boards providing stepgen, GPIO (12V/24V inputs and outputs), differential encoders, etc. I'm also working to provide support for shifting data out (74HC595) and in (74HC165).
An estimation of the HAT will be around 7 Euro's, excluding the Tang Nano 20k. Inlcuding the FPGA, the price would be around the 40 Euro price point.
  • IB_CnC
  • IB_CnC
18 Jan 2025 10:59 - 18 Jan 2025 11:06
ProbeBasic and sidemount, retractable 3D Probe
Category: QtPyVCP
Great, got it to work, thanks a lot!
You are the creator of Probe Basic right?
I must say it's really impressive this user interface which you have created, on par or better than many OEM software I have seen.
I haven't made a tool changer carousel yet, but plan to make one with geneva wheel.
When I combine the side-probe with the carousel, if I understand correctly the sequence would be:
- Unload the currently mounted tool in the ATC-carousel tab
- Load the Probe via the Tool tab (only in gui)
- Probe the stock
- Unload probe in Tool tab
- Load tool with ATC-carousel tab or start program.
18 Jan 2025 10:45
Replied by Cant do this anymore bye all on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Give it a go. Take it slow and don't skip any steps. Good Luck.
  • Nserega.90
  • Nserega.90
18 Jan 2025 10:38
Thank you very much for taking my time. I think I should be able to handle this task. Yes, I will start by studying this thread. I will study, try, and study again. Maybe I will share my results based on my successes and failures. Thanks again!!!
  • Dave2024
  • Dave2024's Avatar
18 Jan 2025 10:11 - 18 Jan 2025 10:22
Replied by Dave2024 on topic Spindle Load feedback in LinuxCNC
Category: Basic Configuration
Ok awesome! Nice setup. I wish I had a dialed machine setup like your running. Unfortunately I don't have an inverter though in my situation. I have a AC servo spindle. I wanted a VFD and BLDC but nothing would fit my machine and it needed to be running before my EOL LOL. Anyways my idea is if I could get a lesson on what's needed to make a readout like you've got and somehow program it so that if the load is too high it would alter the feed/speed so that a chip size of set value would never exceed the capabilities of the motor. That and another possible feature would be an estop trigger if the load was too high and RPM lower than a set threshold. Is any of this possible or am I just crazy? Anyways sorry for the weirdness. Thanks
  • feng
  • feng
18 Jan 2025 09:55
I like to translate the Qtvcp UI button into the local language
Category: Qtvcp
How should I translate the Qtvcp UI button into the local language, such as the STOP button
Displaying 19591 - 19605 out of 21695 results.
Time to create page: 0.489 seconds
