  • 858PSJ
  • 858PSJ
28 Jul 2026 14:39
Replied by 858PSJ on topic o codes and grbl
o codes and grbl
Category: Mill Library
The log file produced by the polygon pocketing program  produces g-code linear moves as its output.  If you stick a few m2 and percents and a few setup commands in that file and change its name to a .ngc file you can  mill simple things.
(maybe)   (I'm assuming you have some other machine that you can run that program on)
  • djdelorie
  • djdelorie
28 Jul 2026 14:20
Replied by djdelorie on topic DIY CNC
DIY CNC
Category: Milling Machines
If you have access to a PC with a parallel port, it's a cheap and easy way to get started in CNC using knockoff breakout boards from Amazon and some cheap stepper/driver kits. That's what I did. However, this is not a robust solution. I had many problems with port pins getting fried, for example. Getting any one of the Mesa cards (I used the 7i76E) is a bit more of an investment but the electronics are much more robust, and you get to enter the worlds of "industrial lego". At that point, you'd need LinuxCNC anyway, so might as well start there.
Also, it looks like GRBL is designed to run on an embedded board, not a PC, so if you want the lowest cost-of-entry, go LinuxCNC.
  • PCW
  • PCW's Avatar
28 Jul 2026 13:24
Retrofitting a 3-axis VMC with DC servos - guidance needed
Category: Driver Boards
The 7I97T enable outputs should be able to drive that directly.
If you worry, you can always measure the current with a DVM
  • tuxcnc
  • tuxcnc
28 Jul 2026 13:14
Replied by tuxcnc on topic installing of linxcnc
Category: Installing LinuxCNC
The recommended Linux distribution for the latest version of LinuxCNC.
Download latest Debian iso image (current 13.6) and install. (There are thousands guides at the net.)
It is a good idea to manually partitioning and don't use swap partitions (Modern computers with at least few GB of RAM not need swap.)
LinuxCNC without CAD/CAM fits in 8 GB of disk space, 16 GB is better, more will be never used.
You should chose some lightweight window manager. (I preffered xfce4.)
LinuxCNC installation is simple, but I don't have the time or inclination to check now whether I made a mistake, but it should be like this:
apt-get update
apt-get dist-upgrade
apt-get install linux-image-rt-amd64
reboot
apt-get install build-essential dpkg-dev git
cd ~
git clone https://github.com/LinuxCNC/linuxcnc.git linuxcnc-source
cd linuxcnc-source
./debian/configure
apt-get build-dep .
dpkg-checkbuilddeps
# install unmet dependencies if some
dpkg-buildpackage -b --jobs=12
cd ..
apt-get install ./linuxcnc-doc-en_2.10.0~pre1_all.deb
apt-get install ./linuxcnc-uspace_2.10.0~pre0_amd64.deb
apt-get install ./linuxcnc-uspace-dev_2.10.0~pre0_amd64.deb
I don't remember the apt-get build-dep should be before or after ./debian/configure, the rest seems be properly.
  • csec0128
  • csec0128
28 Jul 2026 12:46
Replied by csec0128 on topic Precix Retrofit Project
Yes. This is actually one of the hard copies I currently have. Mainly looking for additional details for the other components, especially the control board for these machines.
  • tuxcnc
  • tuxcnc
28 Jul 2026 12:32
Replied by tuxcnc on topic Help Controller for a Lathe ?
Category: CNC Machines
It might even be a thing to do a "virtual taper attachment" when moving the encoder driving z and x at the same time. :-)
Just because something can be done doesn't mean it's worth doing or that it will work as expected.
MPG is intended for positioning movements, not working movements.
There are many reasons why you should not use MPG for turning, but I will give you just one - you can turn the handle faster than the axis is moving, in other words, when you are done turning, the axis will continue to move until it reaches the commanded position.
MPG is not a mechanical crank rigidly connected to the tool and giving the operator a feedback signal.
It's just a stupid idea, even if someone does it and is happy with it...
  • andypugh
  • andypugh's Avatar
28 Jul 2026 12:10
Replied by andypugh on topic USB haas operator panel interface
Category: Other User Interfaces
Mesa smart-serial is open, all Mesa firmware is open.
But keeping the USB panel as USB is almost certainly easier and may be technically better.
  • andypugh
  • andypugh's Avatar
28 Jul 2026 12:07
Replied by andypugh on topic installing of linxcnc
  • The installation steps for a fresh system.
On a fresh system:
(more details here linuxcnc.org/docs/stable/html/getting-st...etting-linuxcnc.html)
Download this file: www.linuxcnc.org/iso/linuxcnc_2.9.10-amd64.hybrid.iso
Write the file to a USB stick (at least 4.1GB) using the instructions here:
linuxcnc.org/docs/stable/html/getting-st...to_a_bootable_device
Plug the USb drive into the PC, turn it on, go to the BIOS screen (often by pressing F2 during boot) to set the USB stick as the boot device, save and exit, then follow the on-screen instructions.
  • andypugh
  • andypugh's Avatar
28 Jul 2026 11:58
Replied by andypugh on topic Help Controller for a Lathe ?
On my lathe:
bodgesoc.blogspot.com/2016/08/holbrook08.html
I installed a 7i73 inside the apron to handle the limit switches, handwheels and a jog-rate select knob (which is also a switch that selects manual mode to enable jogging).
Your 7i96 has a smart-serial port, so you would connect a 7i73 to that.
It means simpler cabling in the cable chain, but you need to use suitable cat5 cable to handle the continuous flexing. (eg Igus chainflex / LAPP Etherline FD)
I don't see anything in the photo to exclude the possibility that you are in the UK (I look at mains sockets) so if you are, Rapid Electronics sell a lot of these expensive industrial cables by the metre. www.rapidonline.com/lapp-0028308-liyy-pe...e-8-x-0-25mm-63-6718
  • timo
  • timo
28 Jul 2026 11:24
Replied by timo on topic Help Controller for a Lathe ?
I mean I cannot prove 100% right now, but I do not see it cannot be run with two hand encoders (at the same time)
I should get going...
  • Japoo_Ness
  • Japoo_Ness
28 Jul 2026 10:43 - 28 Jul 2026 10:46
If it takes all this just to run the enable signal, I'm thinking it's better to wire it directly to the drive. Is there any good reason to keep it isolated with an extra relay? The 7i97T outputs are already opto-isolated, and my servo drive has a 10kΩ input impedance anyway. Adding a relay isn't really worth it, right?
  • Japoo_Ness
  • Japoo_Ness
28 Jul 2026 10:38
I'm having some trouble with the servo enable relays.My relays have flyback diodes, but the datasheet is giving me a headache. The coil draws 40mA, but the flyback module includes an LED with no specified current draw. Since I can't be sure of the total load, I'm guessing I can't use it.Would you guys just change the module for these specific commands, or is there a better workaround?
These are the Finder 55 Series
i think its better to use other relays for these ones like interface relays isnt?
  • Logthor
  • Logthor
28 Jul 2026 08:13
DIY CNC was created by Logthor
DIY CNC
I recently acquired a Sherline CNC-ready mill, and I've been thinking about finally getting around to getting it setup. The problem is that I can't decide on what path I should go down (GRBL or LinuxCNC). I'm quite a novice when it comes to CNC machines, so LinuxCNC seems quite daunting. However, the features the software provides are very enticing. I was wondering what you guys think I should do. Additionally, if I do go down the LinuxCNC route, should I go with a 7I96S or an old computer with a parallel port (I haven't tested its latency, but it should be fine; it is a Dell Optiplex)? The reason I'm considering using my old computer is that I can back out if I get way too in over my head (I figure I won't waste as much money).
Thanks,
Logan
  • robh
  • robh
28 Jul 2026 06:53
Sliding Head Lathe for sale - maybe grate devlopment tool for linuxcnc ? UK
Category: User Exchange
willing to give this away for free now
now offering this Free to a keen linuxcnc developer
i did try to reload parameters but the PLC board does not boot, could be as simple as a voltage issue on the PCB.. i dont have the time to fix it, but i am willing to let this go to a good home and more so to someone who can use it develope linuxcnc to such a machine and give back to the community
i can load to transport,
can give away a magazine bar feed with machine also that will need interfacing (LNS BRand)
  • motionmasterupgrade
28 Jul 2026 04:02
Replied by motionmasterupgrade on topic Retrofitting a 3-axis VMC with DC servos - guidance needed
I am working through retroftting a motionmaster. I kept all my relays. My goal was slightly different, I wanted to keep the wiring as stock as possible because there was a chance of the whole upgrade not working and I would want to sell it stock, but I think I'm far along enough that its worth more as a linuxcnc box now.
Displaying 2116 - 2130 out of 12539 results.
Time to create page: 0.348 seconds
