  • Lcvette
  • Lcvette's Avatar
15 Feb 2026 00:35
Replied by Lcvette on topic Some problems with probe basic lathe
Category: QtPyVCP
You maybe could check the lathe macros uo files using editvcp and fine the lathe macros in the probe basic widgets directory and verify the parsee widhet entry names correspond correctly with the macros being used. From a glance it appears they may not be the same.
github.com/kcjengr/probe_basic/tree/main...dgets/conversational
You need to make sure those variables are get ng from the ui to the subroutine at the top.
  • NT4Boy
  • NT4Boy
15 Feb 2026 00:30
Replied by NT4Boy on topic select jog axis
select jog axis
Category: AXIS
There is no need for a GUI to get involved with external hardware. Thats what halui is for.
When GUIs extendRod their scope, we get a mess with differing configs for no reason.
Rod, I use the Axis GUI as representing what the hardware controls on my Three axis mill have done and are doing. In particular when setting the tool offsets using the touch off gui buttons, If the X or Y axis instead of the z is selected, then the tool table gains an unexpected x or y offset. If you control the machine by the gui that's my lookout, but to move a big machine around you must use a pendant. I have mpg and three momentary buttons to select the axis for the mpg to drive. It is very easy for me to move the machine only with the pendant, and lastly touch down the z direction for work and tool touch off with the x still selected because my jog buttons are not reflected in the gui. Done it too many times.
But, today, I found the forum.linuxcnc.org/38-general-linuxcnc-q...ns/50151-axis-select  python script, and its transforming. The radio buttons move with the last jog axis selected, and I can stop worrying quite so much about stray tool table entries.
  • Looby
  • Looby
15 Feb 2026 00:10
Lenovo T14 Gen2 AMD - CRAZY High Latency - Am I screwed?
Sorry for not responding but Ive been trying other distributions (Mint, Ubuntu, and some wonky 3rd one I cant remember) hoping for better results and all end in either failed installs or crappy results.
I have another pc im hoping to try but havent gotten to it yet. Ill try the clock correction thing tomorrow and see if that yields anything better.
  • Looby
  • Looby
15 Feb 2026 00:03 - 15 Feb 2026 00:12
Electrical Contactors/Relay Help? was created by Looby
Category: Milling Machines
Good Evening All,
I am building an electronics enclosure for my CNC router project and need some education on relays/contactors.  I have a couple salvaged components from an industrial bandsaw that I am integrating such as safety relays, e-stops, buttons, terminal blocks, and maybe contactors…  I preface all the below with I don’t know much about how electrical components work so PLEASE point out even something basic that I might have gotten wrong because I honestly do not know.
The very basic question of this is how do you size relays/contactors for inductive loads such as Makita RT0701C and 48vdc power supplies to run the steppers?  I will be running two separate circuits but if I hit the e-stop I want to cut power to these components while leaving other things like PC, Mesa card, fans, and the e-stop system itself powered.
* Circuit 1 - Makita – 6.5 amp 120vac in
* Circuit 2 - 2x 48vdc PSUs 5amp 120vac in (6amp 3sec surge)
My research says you have to go 5-10x the load when sizing relays/contactors but does that mean I would need a 120amp contactor for my steppers that are a 10 amp regular load?!  the 10x number was more related to solid state relays but this just seems nuts.
I found a McMaster-Carr table that shows a 1.5 hp motor drawing 20amps at full load (Makita claims 1.25) and I would need up to a 200 amp contactor?!  www.mcmaster.com/7603KAC/
As stated electricity and I are not the best of friends so we avoid each other as much as possible.  I could be (and hope I am) missing something very basic here.
Components I have:
* Idec SJ2S-07LW 8amp icecube type relays – 24vdc coil draws 0.025 amp when closed
* Mitsubishi S-T10 Contactors – 24vdc coil draws a MASSIVE 1.3amps when closed (not sure I want or even CAN use these also WHY would this draw so much?)
* TWTADE/JQX-62F-2Z 80 amp contactor - 24vdc coil draws 0.088 amp when closed
* LCTC Solid State Relay 80amp – Its in the mail but don’t know if its any good.
The below is the basic plan I have for wiring power.  If anything in this looks wonky let me know as well please :)
  • endian
  • endian's Avatar
14 Feb 2026 22:01
Replied by endian on topic LinuxCNC S-Curve Accelerations
New PR from YangYang is ready, hopefully will be merged soon in master
This adds ruckig in the planner type 1
if you want to test it get the binary from
github.com/LinuxCNC/linuxcnc/actions/runs/21975584400
or build source from my repo
github.com/grandixximo/linuxcnc
Testers are welcome to report here or in github, thanks!
Hello gentlemen,
movement are incredible smooth ... basic shaping what I have tested till now is pretty ... but during movement at more points during simulation of rotation interpolation its jumping or woobing ... kind off braking and next accelleration
most spiking during cloud of points are gone ... some spiking are still present but it a huuuuge step forward
testing setup 2ms benchtop profibus master 3axis geany gui ... 3 servo axis with synchronized speed control loop at 2ms
some testing fault popups triggered during the movement of file 3_1001.ngc
I am still testing at default simulation file from past but splitted to separated operations ..
thanks a lot for your progress ... I am watching it every single day with mount open and box of popcorn to reading the edits ...
regards E.
I have noticed the slowing during the round movement too but I forgot to noticed it here.... yes it is present and its present during 100% feed value ...
crashes are not present during the 100% feed just if its not 100% ...
crash log is in the attachement if somebody are interested ...
  • Ismacr63
  • Ismacr63
14 Feb 2026 20:30 - 14 Feb 2026 21:25
Replied by Ismacr63 on topic Some problems with probe basic lathe
Category: QtPyVCP
I’ve updated AndyPugh macros to the latest version, and now it seems to work, but it shows the tool change tab and doesn’t go any further.
  • grandixximo
  • grandixximo's Avatar
14 Feb 2026 20:25
Replied by grandixximo on topic LinuxCNC S-Curve Accelerations
if you don't touch the feed override, the errors can still come up?
  • tar_san
  • tar_san
14 Feb 2026 20:25 - 14 Feb 2026 23:57
Ver 2.9.4 iso clean install Trouble when disabling EOE
Category: EtherCAT
I used previous PC,
1. Installed by 2.9.4 iso ,
2. Upgraded 2.9.5
3. EOE recompile, r8168-dkms
4. Worked.
5. Upgraded 2.9.8
6. Some command(attached previous)
5. This trouble.
Speaking of r8168,already installed in this PC. But
What should I write in
 /etc/ethercat.conf,DEVICE_MODULES="generic"?
Is "generic' Ok?
Some of settings may have been initialized by upgrade... I attached what I did after upgrade.
I found some post about upgrade trouble EtherCAT,
forum.linuxcnc.org/ethercat/45336-etherc...tep?start=180#293489
Should I go back to previous version ?  (But 2.9.5 have some bugs for Jog movement )
I can also reinstall using 2.9.8 iso from the begining next time with another PC.
  • ruediger123
  • ruediger123
14 Feb 2026 20:12
Replied by ruediger123 on topic LinuxCNC S-Curve Accelerations
My initial tests showed no violations of the limits for jerk and acceleration.
Has the track speed for circles G2/G3 been reduced in the past?
The speed with G2/G3 seems very low to me.
Regards,
Rüdiger
  • PCW
  • PCW's Avatar
14 Feb 2026 20:07
Replied by PCW on topic Mesa 7i76EU - how to enable mode 2?
sserial_port_0=20000000
In the driver config string will set the mode to 2 which will enable both
the MPG encoder inputs and analog inputs.
Note that the encoder inputs are intended for MPG use and
1. Are fairly slow
2. Do not support index
You would normally use the 7I76EU high speed encoder input for the
spindle (TB3 pins 7..15)
  • PCW
  • PCW's Avatar
14 Feb 2026 19:45
Integrating a BCL-AMP capacitive sensor to LinuxCNC
Category: Plasma & Laser
Those values need a massive offset (-22900), has that been applied?
  • decor82
  • decor82
14 Feb 2026 19:37 - 14 Feb 2026 19:38
Probe Basic Tool Setter touch off pos Y not set
Category: QtPyVCP
LinuxCNC 2.9.8, QtPyVCP 5.0.6, Qt 5.15.8 and Probe Basic 0.6.2
Updated everything like a week ago. Went with the stable release of Probe Basic because my linuxcnc computer is not connected to the internet and I have to unmount it and take it to a place where i have Internet to update it. So I do not update it that often and wanted the most stable version.
Should I update to the dev version?
  • Bari
  • Bari's Avatar
14 Feb 2026 19:20 - 14 Feb 2026 19:21
Jones and shipley cylindrical grinder CNC conversion, grinding camshafts, cranks
@ m.ruefenacht
Do you have anything that you can share? I have a LCNC CAM grinder on my list of things to build.
  • Ismacr63
  • Ismacr63
14 Feb 2026 19:06 - 14 Feb 2026 19:30
Category: QtPyVCP
I’ve been reading through AndyPugh thread, but honestly I still have no idea how to get it working in Probe Basic Lathe.
Displaying 6991 - 7005 out of 12578 results.
Time to create page: 0.667 seconds
