  • PCW
  • PCW's Avatar
21 Apr 2025 13:59
Replied by PCW on topic Proxxon CU4
Proxxon CU4
Its parallel port compatible (uses the common "Mach 5 Axis BOB" inside)
So would work with a parallel port or Ethernet/SPI/GPIO/etc device that has a
parallel port like interface.
  • vre
  • vre
21 Apr 2025 13:59
Replied by vre on topic spindle with encoder
Category: Basic Configuration
To mechanically adjust the exact same ratio is very difficult
Also with counter chips division maybe can not be integer multiple
so the only real option is to mount and aluminum disk to spindle shaft
and because my spindle shaft from top has the hydraulic cylinder that locks the tool
the only place can put this is only to the downside of spindle shaft.
How many lines must have the disc for rigid tapping ?
Also must have disc with A B and Z signals or only A is enough ?
  • dctrytsman
  • dctrytsman
21 Apr 2025 13:40
Replied by dctrytsman on topic Lathe with C axis
Lathe with C axis
I had a look at it today again and realized I won't be able to make it work. The backlash in the gearbox will not allow me to machine the part accurately. I'm won't be attempting this any further. Unfortunately this machine was not designed to have a c-axis.
  • pgf
  • pgf
21 Apr 2025 13:33
After homing X and Y, can I auto move to a non 0,0 location?
That would be great -- but I'd also be happy with simply max-X and max-Y.
  • spumco
  • spumco
21 Apr 2025 13:16
OP-
Thank you, that helps.
Would you like the table to be as close to the operator as possible (max Y) as well as centered on X when the homing routine is complete?  This is how I've configured my moving-table mill.
  • qaywsxedc
  • qaywsxedc
21 Apr 2025 13:14
Replied by qaywsxedc on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Hi Guys,
as easter project, i tried to put 32v von my nvem v2... damn it ...a capacitor blew up
can someone please give the values of it?
i can not read it anymore.
thanks in advance
best wishes
  • pgf
  • pgf
21 Apr 2025 12:16
Okay, I think a picture will help.
Homing on 0 works, as in the upper diagram.  But it leaves the bed far from me.  In the title of the thread, I asked whether there's a way to automatically move after homing, so that I end up as in the lower diagram.  I haven't yet tested whether simply setting "HOME" to 12, rather than 0, would accomplish this.  That's because since homing (and even rapids, on my mill) are very slow, I'd really rather skip the extra bed travel, and have it home directly to 12, and stayed there.
  • jjdege
  • jjdege's Avatar
21 Apr 2025 11:43
Hello
I ran a test to verify the problem I have,
that is: on the A-AXIS output (join 3) there is no signal
I enabled all the axes in the .ini .hal file inverted in the nvem-rt1052.txt file, the joint 3 pins (A-AXIS) with the joint 4 pins (B-AXIS)
it happens that joint 3 and joint 4 are inverted and on the B-AXIS output I find the joint 3 signals working, while on the A-AXIS output the join 4 signals do not work,
on the C_AXIS joint 5 output the signals work
it seems that the A-AXIS output on the NVEM card is physically interrupted, is it possible?
File Name: nvem-rt1052.hal
File Size:3 KB
File Name: nvem-rt1052.ini
File Size:5 KB
File Name: nvem-rt1052-inv.txt
File Size:7 KB
  • vre
  • vre
21 Apr 2025 11:31
So i must attach encoder of encoder disk to spindle shaft because all other places
i can mount the encoder are not 1:1 gear ratio with spindle shaft.
  • jdowsonjr
  • jdowsonjr
21 Apr 2025 10:56
Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
Category: Installing LinuxCNC
i was able to bench test the image with the ethercat master installed from the repositories and it works. The only thing i found peculiar was that when jogging with the keyboard i could notice some random jitter in the drive. This did not happen with the amd64 cpu i was using before. I suspect this could just be an issue with the keyboard input on the pi though as that jitter is not present with commands from the MDI
  • rodw
  • rodw's Avatar
21 Apr 2025 09:54
See how you go with the position.
Regards shared himing switches, there is a pin joint.n.is_homing ot similar (check man motion).
If you and2 that with your physical limit switch and use the output to your homing input, the non homing joint will ignore the switch input.
  • rodw
  • rodw's Avatar
21 Apr 2025 09:48
First time to try build my xml for not listed ethercat in-out component
Category: EtherCAT
Seems what I expected.
What happens if you change bitlen to 32 and add ports 9 to 16?
You would need to get rid of the bitlen=8 line too.
  • bkt
  • bkt's Avatar
21 Apr 2025 09:12
Category: EtherCAT
these seems to work ... But I'm in remote so can not verify hardware result ....  halshow show all work correctly .... only never see op-state of lcsc ... but work on demo-sim-classicladder .... never check if on sim lcec go on op-state or not .....
<masters>
<master idx="0" appTimePeriod="8000000" refClockSyncCycles="1">
    <slave idx="0" type="generic" vid="0x00000b3d" pid="0x29c9f7b1" name="D1">
      <!--S1-M20-->
      <syncManager idx="0" dir="in"/>
      <syncManager idx="1" dir="out"/>
      <syncManager idx="2" dir="out">
        <pdo idx="1600">
          <!--Output Data-->
          <pdoEntry idx="7000" subIdx="01" bitLen="16" halType="complex">
            <complexEntry bitLen="1" halPin="out-1" halType="bit"/>
            <complexEntry bitLen="1" halPin="out-2" halType="bit"/>
            <complexEntry bitLen="1" halPin="out-3" halType="bit"/>
            <complexEntry bitLen="1" halPin="out-4" halType="bit"/>
            <complexEntry bitLen="1" halPin="out-5" halType="bit"/>
            <complexEntry bitLen="1" halPin="out-6" halType="bit"/>
            <complexEntry bitLen="1" halPin="out-7" halType="bit"/>
            <complexEntry bitLen="1" halPin="out-8" halType="bit"/>
            <complexEntry bitLen="8"/>
          </pdoEntry>
      </pdo>
      <pdo idx="1601">
          <!--Output Data-->
          <pdoEntry idx="7010" subIdx="01" bitLen="16" halType="complex">
            <complexEntry bitLen="1" halPin="out-9" halType="bit"/>
            <complexEntry bitLen="1" halPin="out-10" halType="bit"/>
            <complexEntry bitLen="1" halPin="out-11" halType="bit"/>
            <complexEntry bitLen="1" halPin="out-12" halType="bit"/>
            <complexEntry bitLen="1" halPin="out-13" halType="bit"/>
            <complexEntry bitLen="1" halPin="out-14" halType="bit"/>
            <complexEntry bitLen="1" halPin="out-15" halType="bit"/>
            <complexEntry bitLen="1" halPin="out-16" halType="bit"/>
          </pdoEntry>
      </pdo>
      </syncManager>
      <syncManager idx="3" dir="in">
        <pdo idx="1a00">
          <!--Input Data-->
          <pdoEntry idx="6000" subIdx="01" bitLen="16" halType="complex">
            <complexEntry bitLen="1" halPin="in-1" halType="bit"/>
            <complexEntry bitLen="1" halPin="in-2" halType="bit"/>
            <complexEntry bitLen="1" halPin="in-3" halType="bit"/>
            <complexEntry bitLen="1" halPin="in-4" halType="bit"/>
            <complexEntry bitLen="1" halPin="in-5" halType="bit"/>
            <complexEntry bitLen="1" halPin="in-6" halType="bit"/>
            <complexEntry bitLen="1" halPin="in-7" halType="bit"/>
            <complexEntry bitLen="1" halPin="in-8" halType="bit"/>
          </pdoEntry>
      </pdo>
        <pdo idx="1a01">
          <!--Input Data-->
          <pdoEntry idx="6010" subIdx="01" bitLen="16" halType="complex">
            <complexEntry bitLen="1" halPin="in-9" halType="bit"/>
            <complexEntry bitLen="1" halPin="in-10" halType="bit"/>
            <complexEntry bitLen="1" halPin="in-11" halType="bit"/>
            <complexEntry bitLen="1" halPin="in-12" halType="bit"/>
            <complexEntry bitLen="1" halPin="in-13" halType="bit"/>
            <complexEntry bitLen="1" halPin="in-14" halType="bit"/>
            <complexEntry bitLen="1" halPin="in-15" halType="bit"/>
            <complexEntry bitLen="1" halPin="in-16" halType="bit"/>
          </pdoEntry>
      </pdo>
      </syncManager>
    </slave>
  </master>
</masters>
  • bkt
  • bkt's Avatar
21 Apr 2025 08:24
Category: EtherCAT
i Try to use these config and seems to work ...
<masters>
      <!--S1-M20-->
        <pdo idx="1600">
          <!--Output Data-->
          <pdoEntry idx="7000" subIdx="01" bitLen="8" halPin="out1" halType="u32"/>
      </pdo>
      <pdo idx="1601">
          <!--Output Data-->
          <pdoEntry idx="7010" subIdx="01" bitLen="8" halPin="out2" halType="u32"/>
      </pdo>
      </syncManager>
        <pdo idx="1a00">
          <!--Input Data-->
          <pdoEntry idx="6000" subIdx="01" bitLen="8" halPin="in1" halType="u32"/>
      </pdo>
        <pdo idx="1a01">
          <!--Input Data-->
          <pdoEntry idx="6010" subIdx="01" bitLen="8" halPin="in2" halType="u32"/>
      </pdo>
      </syncManager>
    </slave>
  </master>
</masters>
no w try to divide byte to bit .... hope it work
  • bkt
  • bkt's Avatar
21 Apr 2025 08:10
Category: EtherCAT
Please post the output of lcec_configgen.
is these ..... as you can see little bit too long ...
File Name: S1-M20.xml
File Size:389 KB
Displaying 16231 - 16245 out of 17612 results.
Time to create page: 0.448 seconds
