  • WKS-3D
  • WKS-3D's Avatar
15 Jul 2024 07:13
Brauche bitte Hilfe bei der Steuerung des Werkzeugrevolvers
Category: Deutsch
The tool tip moves exactly to the center of the workpiece at 45 degrees. It is the same as if you had a normal support, only from the other side and at 45 degrees.
@ CHEROKEE-Laredo
Danke, schaue ich mir an.
  • ihavenofish
  • ihavenofish
15 Jul 2024 07:03
Replied by ihavenofish on topic Mini wannabe datron build
Category: CNC Machines
Tool mag for the direct collet spindle on the prototype machine.
Seems pretty easy. I want to use one of the little 100w lichuan ethercat servos with absolute encoder.
In my head this should basically work the same as a static tray atc, commanding the magazine to rotate as a W axis to a position from an o-sub.
  • Aciera
  • Aciera's Avatar
15 Jul 2024 06:50 - 15 Jul 2024 06:51
Replied by Aciera on topic 2-speed spindle configuration - help
How can block spindle from rotating when hydraulic tool holder cluch is open?
Try:
spindle.M.inhibit IN BIT
When TRUE, the spindle speed is set and held to 0.
linuxcnc.org/docs/2.9/html/man/man9/motion.9.html#MOTION%20PINS
  • rthorntn
  • rthorntn
15 Jul 2024 06:45
I'm guessing that RISC V production costs more because the manufacturers don't have the advantage of massive discounts when they order millions of them. Beagle stuff has never really been cheap for what it is.
  • vre
  • vre
15 Jul 2024 06:39
Replied by vre on topic 2-speed spindle configuration - help
I don't want change gear when spindle is run so gearchange.
Does this done automatically by iocontrol v2 ?
15 Jul 2024 06:32
Replied by tommylight on topic Linuxcnc on my machine?
Mesa 7i96S can drive 10 steppers, 5 on its screw terminals and another 5 on the 26 pin header.
Using a BOB and an adapter cable from IDC26 to DB25 is prefferable for ease of use/installation.
Might need firmware flashing, though, so use mesaflash to read the existing firware, and if needed, to flash the new firmware.
Mesaflash is included with the official ISO.
15 Jul 2024 06:28
Problem Installing LINUXCNC 2.9.2 (Faild to copy file from installation media)
Category: Installing LinuxCNC
What are you using to write the image to USB?
And how are you writing them?
Simple copy does not work.
Try win32diskimager, balena etcher, rufus, and if all fails, give DD a try.
Also, disable UEFI in BIOS and enable compatibility mode, if possible.
15 Jul 2024 06:23
Sorry, Another 'Which Mesa?' Post. (Yes, I read Spumco's magnificient guide)
Category: Driver Boards
Yes and yes, probably, it is 8:20AM here and i have not slept yet, so i might be hallucinating.
As for switches, i never worry about them, usually a single resistor is enough to make them work, whatever the type and input.
15 Jul 2024 06:19
Replied by tommylight on topic Has Anyone used DeskProto
Category: CAD CAM
No.
Rant:
A while back a client was not satisfied with using Inkscape for Plasma, so he went on a journey to find something better, and after paying nearly 4000 Euro for several licences, he is still using Inkscape.
What was strange for me is that he did not like SheetCAM at all, his words "looks to cheap".
Personally, only open source, so have you checked BlenderCAM?
No idea what it does or how far has development come, Blender is a beast so taming it takes time.
15 Jul 2024 06:10
Replied by tommylight on topic Automatic tool change arm stepgen
There are probably several ways of doint it, but i would stick to using a stepgen with preset values, or set the arm as U or V or W axis and use gcode to run it in the tool change macro or remap.
15 Jul 2024 06:06 - 15 Jul 2024 06:07
Neues Projekt (Drehbank) - Machbar, aber wie am schlauesten?
Category: Deutsch
Weis ich nicht uber Remora, sorry.
Fuhr das oberflache nutze ich die Axis GUI mit Andy's wizard:
forum.linuxcnc.org/41-guis/26550-lathe-macros
Fuhr die gewinde zu schneided, muss die spindel ein encoder mit ABZ signale haben, die normale Incremental encoder mit single ended oder differential ausgange soll OK sein.
Edit:
Ich vurde ein Mesa 7i96S mit ein gebrauchte PC nutzen.
  • GeckoWorks
  • GeckoWorks
15 Jul 2024 06:04
If there is a choice, I  prefer sourcing outputs and sinking inputs
IF, big if, I read some other posts correctly, a sinking input on the board would need to be fed a sourcing output "on the other end". Is this correct?
So, thinking ahead to perhaps buying some new limit switches, they would need to be PNP for sinking inputs on the board...?
On that same note, if the board outputs are sourcing, the inputs on the servo drive would need to be wired in the sinking way?
15 Jul 2024 05:59
Stepconfig wont set up tandem y axis limit and home?
Category: StepConf Wizard
At the very start did you choose XYZ or XYZA machine?
Choose XYZ.
You can also manualy edit the hal and ini files, but requires a bit of attention, although LinuxCNC is very good at pointing what is wrong.
15 Jul 2024 05:54
Category: Deutsch
Another look and, still the same.
The X axis moves at a 40-45 degree to spindle center point, it does not move perpendicular to it.
  • CHEROKEE-Laredo
  • CHEROKEE-Laredo
15 Jul 2024 05:30
Category: Deutsch
Schaue Dir mal das Video
an.Habe einen ähnlichen Werkzeugwechsler wie Du und folgende Subroutinen verwendet
o<wzwneu> sub
#4001=45 (bei 8 WZ-Halter 360 Grad durch 8)
#4000=1 (Wartezeit in Sekunden für die Eingänge)
M61 Q#4999 (Werkzeug aus Speicher setzen)
o500 if[#<_current_tool> EQ #<_selected_tool>]
(DEBUG,Tool bereits in Spindel)
o500 elseif [#<_current_tool> NE #<_selected_tool>]
G0 G90 G53 X200 U100 Z300
o501 if[#<_current_tool> EQ 0] (aktuelles WZ ist T0)
o<ventil_an> call
(Endposition)
G0 B[#<_selected_tool> * #4001-#4001] (Karusell drehen)
M6 G43
#4999=#5400 (WZ dauerhaft merken)
o<ventil_aus> call
o501 elseif [#<_current_tool> GT 0] (aktuelles WZ nicht T0)
o502 if [#<_selected_tool> EQ 0] (gewähltes WZ T0)
o<ventil_an> call
G0 B[#<_current_tool> * #4001-#4001] (Karusell drehen)
(Endposition)
M6 G43
o<ventil_aus> call
o502 elseif [#<_selected_tool> NE 0] (gewähltes WZ nicht T0)
o<ventil_an> call
(wieder runter neues wz)
M6 G43
o<ventil_aus> call
o502 endif
o501 endif
o500 endif
o<wzwneu> endsub
m2
o<Ventil_an> sub
M66 P0 (Eingang ob Druck ausreichend ?)
M64 P0 (Ausgang setzen für Ventil an)
G4 P2
o100 if [#5399 EQ -1] (Stop falls kein Druck. M0)
(DEBUG,STOP: kein Druck!)
(DEBUG,Druckluft einschalten dann weiter mit Start oder Programm abbrechen! Crash Gefahr!)
M0 (Porgrammstop, mit Start geht es weiter)
o100 endif
o<Ventil_an> endsub
m2
o<Ventil_aus> sub
(M66 P0 L4 Eingang ob Klappe geschlossen?)
M65 P0 (Ausgang setzen für Ventil aus )
G4 P2
o100 if [#5399 EQ -1] (Stop falls Klappe nicht geschlossen. M0)
M0 (Stop falls Ventil nicht aus. M0)
o100 endif
o<Ventil_aus> endsub
m2
Displaying 24991 - 25005 out of 25551 results.
Time to create page: 0.828 seconds
