  • nanowhat
  • nanowhat
08 Jan 2026 23:10 - 08 Jan 2026 23:18
Replied by nanowhat on topic Ethercat Motion Problem
Category: EtherCAT
Which error are you referring to?
 833.377534 pcieport 0000:00:1d.0: AER: Corrected error message received from 0000:00:1d.0
seems to be caused by PCI-express link power management
 8933.654387EtherCAT WARNING 0-4: Other mailbox protocol response for eoe0s4.
Which version of the ethercat library are you using? 1.6 by default has ethernet over ethercat active, and it doesn't seem to be compatible with linuxCNC. With 1.6, one must compile the library from source to disable EoE.
  • PCW
  • PCW's Avatar
08 Jan 2026 21:41 - 09 Jan 2026 08:58
Replied by PCW on topic LinuxCNC S-Curve Accelerations
it was true:
16 bit IN TRUE ini.traj_arc_blend_enable
I was running the torus gcode (from the torus.png --> image to gcode with whatever defaults)
EDIT: here's the gcode that triggered the bug:
File Name: torus.ngc
File Size:51 KB
  • mika
  • mika's Avatar
08 Jan 2026 20:55
Replied by mika on topic LinuxCNC S-Curve Accelerations
Which G-code did you use for the test? I'd like to try it myself.
  • grandixximo
  • grandixximo's Avatar
08 Jan 2026 20:42
Replied by grandixximo on topic LinuxCNC S-Curve Accelerations
Could you try again with arc blend enable to true?
  • PCW
  • PCW's Avatar
08 Jan 2026 20:02 - 08 Jan 2026 20:05
OK so the bad ini values seem to be LinuxCNC defaults (they were not specified in my ini file)
With more reasonable values set the errors are of much smaller magnitude bu there are still accel violations:
Note that the acceleration (green) which has a constraint of 200 IPS/S sometimes obeys this constraint
(right side of screen) but sometimes ignores it (spikes toward center of screen reaching more than 1500 IPS/S)
ini file settings:
File Name: ini1.txt
File Size:5 KB
  • soehlrich
  • soehlrich
  • ihavenofish
  • ihavenofish
08 Jan 2026 19:30
Replied by ihavenofish on topic LinuxCNC S-Curve Accelerations
These are in inches.
So my understanding would be:
So 20 IPS max Velocity
200 Max accel (~1/2g) so 1/10 second to maxvel with no jerk limit (old TP)
2000 Max jerk  so 1/10 second to full accel
Which (jerk=2000) actually sounds a bit low
I was doing some math to create paths (not real time) a little while back and on my machine with 0.5G (5000mm/s/s) a jerk of like 50000mm/s/s/s was the starting point of usefulness, and 500000 would probably be where I end up. So your 10:1 seems a logical place to start.
BUT, it shouldn't matter. Jerk should never create a following error, it should be mathematically precise, even if its comically low for real life machines.
  • PCW
  • PCW's Avatar
08 Jan 2026 18:57
Those ini values do not cause an issue with the old TP (0)
I'll check your suggestions in a bit...
  • PCW
  • PCW's Avatar
08 Jan 2026 18:54
  • grandixximo
08 Jan 2026 18:49
Thank you Peter for looking at this.
I see a few issues with your ini.txt
16 float IN 1e+99 ini.traj_default_acceleration
16 float IN 0 ini.traj_default_jerk
16 float IN 1 ini.traj_default_velocity
16 float IN 1e+99 ini.traj_max_acceleration
16 float IN 0 ini.traj_max_jerk
16 float IN 1e+99 ini.traj_max_velocity
these settings seems a bit waky, if you want to have jerk control you need
and
ini.traj_max_jerk
to be more than 0
and the 1e+99 max acc and velocity, is this something people actually run with? is it something is supported without f-error on TP0 aka old TP?
  • andypugh
  • andypugh's Avatar
08 Jan 2026 18:46
Replied by andypugh on topic LinuxCNC S-Curve Accelerations
Is a jerk of 2000 reasonable? What units is your config?
  • soehlrich
  • soehlrich
08 Jan 2026 18:02 - 08 Jan 2026 19:55
Replied by soehlrich on topic Qtdragon_hd Zero button not zeroing
Hi, Apologies, did some more testing. If I start at ABS of Zero then Job axis 5mm at a time slowly (ie 100mm/min) every 3rd or 4th jog the counter will increment by .001 ie instead of reading 15.000 it will read 15.001, then if I keep joging it will then stay with the .001 until 35 then it will read 35.002.After some more testing here are my job results (jogging at 30mm/min and incr of 5mm)starts at ABS 0 G54=00->5->10->15->20->25.001->20->25.001->20->25.001->20->25.001->30.001...all .001 till 70.002jogging -ve from 70.002->65.001 ...all .001 til 25.000 .. all the way back to 0.000Feels like some sort of rounding / fp / devision error creaping inI have attached a HALShow screen - after joggin in cnrements of 5mm the first count was correct at 6400, then after a few it added an extra count then another at 30mm so now shows 30.001 as it must be rounding upHope this helps
  • HansU
  • HansU's Avatar
08 Jan 2026 15:54 - 09 Jan 2026 01:57
Linuxcnc 2.9.x and Glade GTK3 display issue
Category: Gmoccapy
Works for me as well with the change Aciera suggested.
  • TripleM
  • TripleM
08 Jan 2026 15:20 - 08 Jan 2026 15:20
Bitfile for Mesa 7i96s + 7i85 (+Modbus (PKT-Pin))
Category: Driver Boards
We seem to have strayed from the topic...
I tried again today and simply tried other serial channels. When I was at SSerial 5 (7i85 TB1, pin 17-24), my 7i84 was found. So it seems that either there is something wrong with the DB25 - ID24 connection cable (I measured it pin by pin) or with the 7i85 itself. I'm not sure how to check that yet...
 But back to the topic. The bit files work.
Thank you very much for your help.
  • PCW
  • PCW's Avatar
08 Jan 2026 15:05 - 08 Jan 2026 17:50
Just a quick test and I got large following errors:
ini setting are:
File Name: ini.txt
File Size:5 KB
Displaying 9121 - 9135 out of 11218 results.
Time to create page: 0.313 seconds
