Bob's Plasmac Build
03 Dec 2019 12:41 - 03 Dec 2019 12:42 #151844
Replied by andypugh on topic Bob's Plasmac Build
If you 3D print them, though, you can incorporate standoffs and clips specific to your PCB mounting hole centres.
www.thingiverse.com/thing:4018328
For example.
(I just designed those based on the drawing in the Mesa THCAD manual, but I have not printed them, and have no THCAD to try them with)
For example.
Last edit: 03 Dec 2019 12:42 by andypugh.
- Chris J
30 Jul 2020 12:00 #176493
by Chris J
Replied by Chris J on topic Bob's Plasmac Build
Hi Bob,
Beautiful build!
Did you ever get it finished?
Beautiful build!
- bevins
- Thank you received: 338
30 Jul 2020 12:23 #176496
by bevins
No, not finished. I have to finish it. I am working on it now in parallel with a Chinese machine. The Chinese router is done with exception of the Racktoolchanger. That I am trying to figure out the NGC code.
I just have to power up the control panel. I was going to use gmocappy but there was a bug that never got fixed so I am using axis.
I have two THCAD's and everything to finish it. Just have to get it done....lol
Replied by bevins on topic Bob's Plasmac Build
Hi Bob,
Beautiful build!
- bevins
30 Jul 2020 12:32 #176497
by bevins
Andy, mind if I print these? Can I use them on commercial machne?
For example.
30 Jul 2020 13:32 #176508
The designed them and put them on Thingiverse specifically for you...
- bevins
18 Nov 2020 21:09 - 18 Nov 2020 21:11 #189730
by bevins
Machine running. Getting ready to configure Plasmac.
DYN4 750 watt AC servo's with Planetary gearboxes.
Last edit: 18 Nov 2020 21:11 by bevins.
The following user(s) said Thank You: rodw, dvn4life1972
- bevins
18 Nov 2020 21:13 #189731
by bevins
The following user(s) said Thank You: tommylight, Clive S, rodw, dvn4life1972
- bevins
21 Nov 2020 15:50 - 21 Nov 2020 15:50 #189979
by bevins
Getting it dialed in and ready for Plasmac config.
Sorry shaky video....
Last edit: 21 Nov 2020 15:50 by bevins.
The following user(s) said Thank You: dvn4life1972
- bevins
22 Nov 2020 15:12 #190050
by bevins
Is there an issue if I mount the THCAD in a box on the machine and run the encoder inputs to the mesa card?
That way I can keep the high voltage out of the control panel. Would it need to be shielded and it is about 20 feet maybe 15.
- Thank you received: 5330
22 Nov 2020 15:30 #190053
Replied by PCW on topic Bob's Plasmac Build
Yes this is fine, just make sure that the cable shield is only connected at the control box
end (and that the THCAD is powered via the "encoder" cable)
Time to create page: 0.265 seconds
