Bob's Plasmac Build
  • bevins
  • bevins's Avatar Topic Author
  • Platinum Member
  • Platinum Member
22 Nov 2020 17:21 #190062 by bevins
Replied by bevins on topic Bob's Plasmac Build
Yes this is fine, just make sure that the cable shield is only connected at the control box
end (and that the THCAD is powered via the "encoder" cable)
OK great.
I am using 7i76, Can I use the enc0 for thcad and enc1 for mpg?
22 Nov 2020 17:48 #190063 by PCW
Replied by PCW on topic Bob's Plasmac Build
You would use the high speed encoder (TB3 pins 7 through 14) for the THCAD
and the Field I/O connection for the MPG(s) (TB5 pins 1,2,3,4)
The following user(s) said Thank You: bevins
Time to create page: 0.453 seconds
